Router Password Recovery Procedure
Answered Question
Apr 8th, 2012
  • Blue, 1500 points or more
hi all,
i just wanna know if it's possible to perform a router password recovery using the reload command and then issue the break sequence instead of doing an off/on on the power switch. i often find in the docs to use the latter.
also, is there a way to retain the startup-config on a router when we re-enable the password recovery functionality (no service password-recovery). i've just tried this on one of our 877 and when i hit the break sequence, it went back to factory default setting.
System Bootstrap, Version 12.3(8r)YI3, RELEASE SOFTWARE
Copyright (c) 2006 by cisco Systems, Inc.
C870 series (Board ID: 1-148) platform with 131072 Kbytes of main memory
PASSWORD RECOVERY FUNCTIONALITY IS DISABLED
Booting flash:/c870-advsecurityk9-mz.124-9.T1.bin
Self decompressing the image :
######### [OK]
Username: cisco
Password:
yourname#
Correct Answer by Leo Laohoo about 4 years 11 months ago
Not it won't.  Someone must've hit the "Reset" button when you did the power reboot.
Correct Answer by Jeff Van Houten about 4 years 11 months ago
If you are attempting to disallow password recovery, then you cannot recover the startup-config. The point of no service password-recovery is to keep your configs private even if someone has physical access to the device. I believe the STRONG recommendation in the documentation associated with this command is to keep a backup of your configs.
Correct Answer by Reza Sharifi about 4 years 11 months ago
Hi John,
In order to do a password recovery, you have to console to the router.  Once you are consoled to the router, as Roman noted, you can power cycle or reload.
regarding your section question, if you have enabled "no service password-recovery" than you can't recover the start-up config.  You can only reset to factory default.
http://www.cisco.com/en/US/products/hw/routers/ps274/products_configuration_example09186a00801d8113.shtml
Correct Answer by Roman Rodichev about 4 years 11 months ago
if you don't know router's password and can't get into it, how can you issue reload command? Otherwise, issuing reload and power cycling can both be used for password recovery.
Overall Rating: 5 (4 ratings)
Correct Answer
Roman Rodichev Sun, 04/08/2012 - 08:05
  • Gold, 750 points or more
Correct Answer
Jeff Van Houten Sun, 04/08/2012 - 08:35
  • Silver, 250 points or more
johnlloyd_13 Sun, 04/08/2012 - 16:29
Hi Roman,
Thanks for pointing that out! I've forgotten you'll need to be in privileged mode in order to do that.
Correct Answer
Reza Sharifi Sun, 04/08/2012 - 08:33
  • Cisco Designated VIP,
    2017 LAN
Hi John,
Correct Answer
Leo Laohoo Sun, 04/08/2012 - 16:14
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
johnlloyd_13 Sun, 04/08/2012 - 16:33
Hey Leo,
I guess you're right. I've actually pressed the reset button a few times before the break sequence. I've read somewhere that hitting the break sequence would re-enable password recovery.
Appreciate everyone's feedback! Cheers!
Leo Laohoo Mon, 04/09/2012 - 15:28
  • Hall of Fame,
    2017 LAN, Wireless
Thanks for the ratings John.
Related Content
