ACE Cookie insert behavior
Answered Question
Apr 8th, 2012
Hi ,
My requirement is as follows
i have following url
http://x.x.x.x/abc
http://x.x.x./dce
http://x.x.x.x/fgh
only for http://x.x.x.x/abc should be using stickiness based on http cookie insert remaining all it should use ip based stickiness.
problem what i am facing is ,
if i access http://x.x.x.x/dce , it is not showing any COOKIE in the header ( which is as expected ) and when i access http://x.x.x./abc it showing the inserted COOKIE (again expected) , but when i am accessing the url http://x.x.x.x/dce or fgh again , it is still showing the INSERTED COOKIE  is it a known behaviour?.
as far as i understand , before the session  request , ACE maintains the insert cookie values in the cookie database and thus it is less processing intensive.
However , why is it inserting to all request , even though i am not configuring as such .
following is my configuration  , is it a known behaviour or is it the way it should work?
serverfarm host SF-FOR-DCE
  probe TCP_8032
  rserver MYSERVER1 8032
    inservice
  rserver MYSERVER2 8032
    inservice
serverfarm host SF-FOR-FGH
  probe TCP_8083
  rserver MYSERVER1 8083
    inservice
  rserver MYSERVER2  8083
    inservice
serverfarm host SF-FOR-ABC
  probe TCP_8081
  rserver MYSERVER1 8081
    inservice
    inservice
sticky http-cookie COOKIE-SKYCHAIN STICKY-ABC
  cookie insert browser-expire
  timeout 720
  replicate sticky
  serverfarm SF-FOR-ABC
sticky ip-netmask 255.255.255.0 address source STICKY-DCE
  timeout 720
  replicate sticky
  serverfarm SF-FOR-DCE
sticky ip-netmask 255.255.255.0 address source STICKY-EFG
  timeout 720
  replicate sticky
  serverfarmSF-FOR-FGH
class-map type http loadbalance match-all CM7-1
  2 match http url /dce/*.*
class-map type http loadbalance match-all CM7-2
  2 match http url /fgh/*.*
class-map type http loadbalance match-all CM7-3
  2 match http url /abc*.*
policy-map type loadbalance first-match PM7-1
  class CM7-1
    sticky-serverfarm STICKY-DCE
  class CM7-2
    sticky-serverfarm STICKY-EFG
  class CM7-3
    sticky-serverfarm STICKY-ABC
class-map match-any CM3-VIP
  3 match virtual-address x.x.x.x tcp eq www
policy-map multi-match PM34-VIP
class CM3-VIP
    loadbalance vip inservice
    loadbalance policy PM7-1
    loadbalance vip icmp-reply
Assistance appreciated.
thanks
-PMD
Correct Answer by jsirstin about 5 years 3 months ago
Are you seeing the client still send the cookie when going to the other locations /DCE or /FGH, or are you seeing the ACE insert the cookie? If you are only seeing the client still sending the cookie this is expected behavior. The cookie is issued for the path / so if the client learned the cookie from the domain x.x.x.x it will send the cookie any time it goes to that domain regardless of the path that is being used.
Jim
Overall Rating: 5 (1 ratings)
gaursin2 Sun, 04/08/2012 - 22:34
  • Bronze, 100 points or more
you are  missing 'persistence rebalance' parameter-map in your confiugration. This parameter-map will tells ACE to inspect every request of a TCP connection
try that........
Correct Answer
jsirstin Mon, 04/09/2012 - 07:36
  • Cisco Employee,
Jim
Borys Berlog Wed, 04/11/2012 - 02:12
  • Cisco Employee,
As Jim wrote , it's correct behavior, but it shouldn't cause any inconveniences for you, as for /dce and /fgh cookies are not checked (those requests are coming to different sticky groups as per your config), so only "problem" you should have is that HTTP header will contain one extra cookie.
