AP1252 can´t join on WLC
Apr 9th, 2012
WLC software 7.2.103.0
1. first problem: AP1252 can´t join on WLC. MAC was add on mac filter properly.
170Mon Apr 9 15:37:32 2012Mesh Node '2c:3f:38:be:53:ef' failed to join controller, MAC address not in MAC filter list.
171Mon Apr 9 15:37:32 2012AAA Authentication Failure for UserName:2c3f38be53e0 User Type: WLAN USER
172Mon Apr 9 15:37:32 2012Coverage hole pre alarm for client[1] 40:a6:d9:ef:87:68 on 802.11b/g interface of AP 2c:3f:38:bf:0c:80 (AP2c3f.38bf.0c80). Hist: 46 7 5 4 2 1 0 0 2 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
173Mon Apr 9 15:37:32 2012Coverage hole pre alarm for client[1] 8c:7b:9d:05:a0:67 on 802.11b/g interface of AP 2c:3f:38:bf:0c:80 (AP2c3f.38bf.0c80). Hist: 50 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
174Mon Apr 9 15:37:30 2012Interference Profile Failed for Base Radio MAC: 2c:3f:38:bf:1e:40 and slotNo: 0
175Mon Apr 9 15:37:28 2012Mesh child node 'd4:d7:48:6d:48:2f' has changed its parent to mesh node '2c:3f:38:bf:ef:60' from mesh node 'd4:d7:48:6c:7d:80'.
176Mon Apr 9 15:37:28 2012Mesh Node '2c:3f:38:bf:1d:2f' failed to join controller, MAC address not in MAC filter list.
177Mon Apr 9 15:37:28 2012AAA Authentication Failure for UserName:2c3f38bf1d20 User Type: WLAN USER
178Mon Apr 9 15:37:28 2012Mesh child node '2c:3f:38:bf:1d:2f' has changed its parent to mesh node 'd4:d7:48:6c:70:e0' from mesh node '2c:3f:38:be:55:00'.
179Mon Apr 9 15:37:28 2012Interference Profile Updated to Pass for Base Radio MAC: 2c:3f:38:bf:4b:20 and slotNo: 0
180Mon Apr 9 15:37:27 2012Interference Profile Failed for Base Radio MAC: d4:d7:48:6c:81:60 and slotNo: 0
Several APs can´t join on WLC and all are added on MAC filter, but they are showing this messages.
2 . Second problem.:  Operational Status = UNKNOWN
Some Access Point are in UNKNOWN status. I tried but I can´t do the reboot.
I can access Web config the APs using WLC, but when I applied the reset, it wasn´t working properly.
Leo Laohoo Mon, 04/09/2012 - 15:07
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Console into the WAP and reboot.  Post the entire bootup and controller discovery process.
Also post the following command output:
1.  WLC:  sh sysinfo;
2.  WAP:  sh inventory
3.  WAP:  sh version
Amjad Abdullah Tue, 04/10/2012 - 02:43
  • Blue, 1500 points or more
Murlio:
Is the AP model 1522 or 1252? I think you mean outdoor AP 1522 (which needs a mac filter). right?
please double check the mac filter you added. Try to delete then add it again if necessary.
it is obvious that it is a mac filter problem. be sure that you add the correct mac address and it is written correctly with the correct format and the mac filter created for "any WLAN" and the interface Name is "management".
Hope this will solve the issue.
Amjad
