Movi not connecting from outside
Apr 9th, 2012
  • Green, 3000 points or more
Hi Team,
I have a small Telepresence solution all set but still a little problem.
The Movi client works internally when I connect it to the VCS-Control and is able to talk to other endpoints.
The problem is when trying to connect the Movi client from the Internet to the VCS-Expressway (has a public IP).
Traffic gets to the VCS, but I don't see where to authenticate the Movi (locally or against LDAP).
In other words, the Movi client registers succesfully against the VCS-Control internally, but won't register against the VCS-Expressway from the outside (and is not a connectivity or filtering problem). I don't see how the VCS-Expressway is supposed to authenticate the Movi credentials.
Can someone point me in the right direction?
Thank you!
Federico.
Jens Didriksen Mon, 04/09/2012 - 15:27
  • Blue, 1500 points or more
Take a look at these threads, should clear up a few things (there are some other threads covering this as well):
https://supportforums.cisco.com/message/3425760#3425760
https://supportforums.cisco.com/message/3599742#3599742
This doc shows you the different authentication options and how to implement them - this is for X7.1:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Authenticating_Devices_Deployment_Guide_X7-1.pdf
/jens
Alok Jaiswal Thu, 04/12/2012 - 09:48
  • Silver, 250 points or more
Hi Federico,
If you still facing problem then do port here.. However i think what Jens has pointed out you should be able to solve it.
I would suggest to porxy the request from expressway to control and let control take care of registration part.
Alok
Federico Coto F... Thu, 04/12/2012 - 12:58
I'm still having the problem, but those are great links you sent me... I'm looking at those.
I should have an update shortly.
Thank you both!
Federico.
