Warning message
Call Forward All to International Number
Apr 9th, 2012
I noticed when calling International numbers it works, when call forward all to local numbers it works. Tried to call forward all to an International number and the after 10 Seconds the call is released. I checked the T310 timers and it is set to 60 seconds. On the international end the phone will ring once but not enough for the call to go through. On my end I get the provider tone that the call in not available.
I am running IOS (C2800NM-ADVIPSERVICESK9-M), Version 12.4(24)T2, I am running Cisco Unified Communications Manager 7.1.2
Also I unchecked outbound redirecting ie and still nothing. On 10 seconds and we Receive disconnect on timer expiry every time.
The provider says that the problem is on my end, but I asked them if they could increase their T310 timer, but they refuse to.
Any Ideas to get around my problem ?
paolo bevilacqua Tue, 04/10/2012 - 05:20
  • Hall of Fame,
    Founding Member
Calling directly that number works?
Take "debug isdn q931" with "terminal monitor" for both a working and-non working international call.
Post it here, do not take other debugs. do not use attachements
paolo bevilacqua Tue, 04/10/2012 - 05:30
  • Hall of Fame,
    Founding Member
Need to see the traces to understand what's the difference. It may have to do with number plan/type, etc.
Also need to speficy ig MGCP or H.323
antzoulis Wed, 04/11/2012 - 13:58
Normal Good Call:
HO-VOICE-GW#
*Apr 11 21:09:29.535: ISDN Se0/2/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 22506095
*Apr 11 21:09:29.535: ISDN Se0/2/0:15 Q931: Sending SETUP  callref = 0x55D8 callID = 0xD55B switch = primary-net5 interface = User
*Apr 11 21:09:29.535: ISDN Se0/2/0:15 Q931: TX -> SETUP pd = 8  callref = 0x55D8
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Display i = '095 - TEST PHONE'
        Calling Party Number i = 0x0081, '22506095'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '0027118214000'
*Apr 11 21:09:29.743: ISDN Se0/2/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0xD5D8
*Apr 11 21:09:36.911: ISDN Se0/2/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xD5D8
*Apr 11 21:09:41.235: ISDN Se0/2/0:15 Q931: RX <- PROGRESS pd = 8  callref = 0xD5D8
        Progress Ind i = 0x8282 - Destination address is non-ISDN
        Progress Ind i = 0x8288 - In-band info or appropriate now available
*Apr 11 21:09:41.595: ISDN Se0/2/0:15 Q931: RX <- ALERTING pd = 8  callref = 0xD5D8
*Apr 11 21:09:46.727: ISDN Se0/2/0:15 Q931: RX <- CONNECT pd = 8  callref = 0xD5D8
        Date/Time i = 0x0C040B173200
                Date (dd-mm-yr)   = 12-04-11
                Time (hr:mnt:sec) = 23:50:00
*Apr 11 21:09:46.731: %ISDN-6-CONNECT: Interface Serial0/2/0:0 is now connected to 0027118214000 N/A
*Apr 11 21:09:46.731: ISDN Se0/2/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x55D8
*Apr 11 21:09:46.871: ISDN Se0/2/0:15 Q931: RX <- FACILITY pd = 8  callref = 0xD5D8
        Facility i = 0x91A115020118020122300DA1083006020101020101820100
                Protocol Profile = Remote Operations Protocol
                0xA115020118020122300DA1083006020101020101820100
                Component = Invoke component
                        Invoke Id = 24
                        Operation = AOCDChargingUnit
*Apr 11 21:09:48.263: %ISDN-6-DISCONNECT: Interface Serial0/2/0:0  disconnected from 0027118214000 , call lasted 1 seconds
*Apr 11 21:09:48.263: ISDN Se0/2/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x55D8
        Cause i = 0x8090 - Normal call clearing
*Apr 11 21:09:49.103: ISDN Se0/2/0:15 Q931: RX <- RELEASE pd = 8  callref = 0xD5D8
        Facility i = 0x91A11D0202038902012430143012A11030060201010201013006020100020102
                0xA11D0202038902012430143012A11030060201010201013006020100020102
                        Invoke Id = 905
                        Operation = AOCECharging Unit
*Apr 11 21:09:49.111: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x55D8
Call Forward All that does not work:
HO-VOICE-GW#
*Apr 11 21:07:21.844: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8  callref = 0x756E
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA9839D
                Exclusive, Channel 29
        Date/Time i = 0x0C040B173000
                Time (hr:mnt:sec) = 23:48:00
        Calling Party Number i = 0x0183, '99541628'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0xA1, '22506095'
                Plan:ISDN, Type:National
*Apr 11 21:07:21.844: ISDN Se0/2/0:15 Q931: Received SETUP  callref = 0xF56E callID = 0x2FFE switch = primary-net5 interface = User
*Apr 11 21:07:21.948: ISDN Se0/2/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0xF56E
*Apr 11 21:07:21.972: ISDN Se0/2/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 99541628
*Apr 11 21:07:21.972: ISDN Se0/2/0:15 Q931: Sending SETUP  callref = 0x55D7 callID = 0xD55A switch = primary-net5 interface = User
*Apr 11 21:07:21.976: ISDN Se0/2/0:15 Q931: TX -> SETUP pd = 8  callref = 0x55D7
                Standard = CCITT
        Display i = 'TEST USER'
        Calling Party Number i = 0x0081, '99541628'
*Apr 11 21:07:22.192: ISDN Se0/2/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0xD5D7
*Apr 11 21:07:29.368: ISDN Se0/2/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xD5D7
*Apr 11 21:07:32.320: ISDN Se0/2/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x756E
        Cause i = 0x82E6 - Recovery on timer expiry
*Apr 11 21:07:32.324: ISDN Se0/2/0:15 Q931: TX -> RELEASE pd = 8  callref = 0xF56E
*Apr 11 21:07:32.344: ISDN Se0/2/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x55D7
        Cause i = 0x80FF - Interworking error; unspecified
*Apr 11 21:07:32.400: ISDN Se0/2/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x756E
*Apr 11 21:07:32.628: ISDN Se0/2/0:15 Q931: RX <- RELEASE pd = 8  callref = 0xD5D7
        Facility i = 0x91A11D020201B602012430143012A11030060201000201013006020100020102
                0xA11D020201B602012430143012A11030060201000201013006020100020102
                        Invoke Id = 438
*Apr 11 21:07:32.632: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x55D7
paolo bevilacqua Wed, 04/11/2012 - 17:01
  • Hall of Fame,
    Founding Member
The forwarded call goes out with the orignal calling number and that may not be acceptable by telco.
see CUCM service parameter
display original calling name for forward, to disabled.
Calling Party Selection field , set to
Last Redirect Number
antzoulis Fri, 04/13/2012 - 00:08
Tried it out and still not working. Will get a debug after working hours when the voice gateway is less busy.
antzoulis Fri, 04/13/2012 - 12:50
No Luck!
HO-VOICE-GW#
*Apr 13 10:37:15.748: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8  callref = 0x75E7
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA9838C
                Exclusive, Channel 12
        Date/Time i = 0x0C040D0D1100
                Date (dd-mm-yr)   = 12-04-13
                Time (hr:mnt:sec) = 13:17:00
        Calling Party Number i = 0x2183, '99541628'
*Apr 13 10:37:15.752: ISDN Se0/2/0:15 Q931: Received SETUP  callref = 0xF5E7 callID = 0x3077 switch = primary-net5 interface = User
*Apr 13 10:37:15.840: ISDN Se0/2/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0xF5E7
*Apr 13 10:37:15.856: ISDN Se0/2/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 22506095
*Apr 13 10:37:15.860: ISDN Se0/2/0:15 Q931: Sending SETUP  callref = 0x5681 callID = 0xD604 switch = primary-net5 interface = User
*Apr 13 10:37:15.860: ISDN Se0/2/0:15 Q931: TX -> SETUP pd = 8  callref = 0x5681
                Standard = CCITT
        Display i = 'TEST PHONE'
*Apr 13 10:37:16.084: ISDN Se0/2/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0xD681
*Apr 13 10:37:23.260: ISDN Se0/2/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xD681
*Apr 13 10:37:26.120: ISDN Se0/2/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x75E7
*Apr 13 10:37:26.124: ISDN Se0/2/0:15 Q931: TX -> RELEASE pd = 8  callref = 0xF5E7
*Apr 13 10:37:26.140: ISDN Se0/2/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x5681
*Apr 13 10:37:26.204: ISDN Se0/2/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x75E7
*Apr 13 10:37:28.464: ISDN Se0/2/0:15 Q931: RX <- RELEASE pd = 8  callref = 0xD681
        Facility i = 0x91A11C02013202012430143012A11030060201000201013006020100020102
                0xA11C02013202012430143012A11030060201000201013006020100020102
                        Invoke Id = 50
*Apr 13 10:37:28.468: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x5681
dwtcp Wed, 05/06/2015 - 07:41
Hi all,
is there a solution for that/
Could it be a Telephony ISP issue?
I am having the same behavior:
i am running c2800nm-adventerprisek9-mz.151-4.M3.bin and CUCM 9.1
But the same occurs even if i redirect the call  directly on the router.
Antonis
antzoulis Wed, 05/06/2015 - 09:09
It was an ISP issue. They blocked direct call forward all to international. They uncapped it for me, but I had to sign some agreement that they hold no responsibility for toll fraud. Anyways, the newer IOS has toll fraud prevention feature.
dwtcp Thu, 05/07/2015 - 05:37
Thanks mate!
That is what i was suspecting!
Cheers,
Antonis
Related Content
