Warning message
Error while applying the Service Policy
Apr 9th, 2012
I am getting the below error while applying the service policy to the Interface.
I have set the mpls exp 4 as well as want to limit the bandwidth to 1Mbps
PE#sh policy-map setexp-GBoIP
  Policy Map setexp-GBoIP
    Class GBoIP-traffic
      set mpls experimental imposition 4
     police cir 1024000 bc 32000
       conform-action transmit
       exceed-action drop
PE(config-if)#int vlan 2007
PE(config-if)#service-policy input setexp-GBoIP
QoS-ERROR: Addition/Modification made to policymap setexp-GBoIP and class GBoIP-traffic is not valid, command is rejected
As well as I have created new clas--map with priority and Bandwidth and applied in output direction, I got the belwo error while applying the Service policy in
PE(config-if)#service-policy out TEST
bandwidth command is not supported in output direction for this interface
PE(config-if)#service-policy output TEST
priority command is not supported in output direction for this interface
Any idea why so ?
Thanks in Advance.
Nilesh
