[ACS 5.2.0.26] How to install cumulative update?
Answered Question
Apr 10th, 2012
I want to install cumulative patch 9 for Cisco ACS 5.2.0.26
I found installation guide:
http://www.cisco.com/web/software/282766937/37718/Acs-5-2-0-26-9-Readme.txt
Instructions on how to install the patch  ========================================
1. open CLI console
2. define new repository in which the 5-2-0-26-9.tar.gpg resides
3. issue: 'acs patch install 5-2-0-26-9.tar.gpg repository YOUR_REPOSITORY'
We have configured 2 ACS appliances in "Split ACS Deployment"
How to install cumulative patch on 2 servers?
If I install on primary server, does the patch replicate on secondary?
Thanks for your help,
Patrick
Correct Answer by jrabinow about 4 years 9 months ago
There is no need to deergister the secondary server. Can run with different patch versions for release
This would not work with running with two different releases (5.2 versus 5.3) in which case would need to be deregistered
Correct Answer by Jagdeep Gambhir about 4 years 9 months ago
Patrick,
Patch needs to be install on both ACS saprately via CLI. It will not replicate.
~JG
Do rate helpful posts
Overall Rating: 5 (2 ratings)
Correct Answer
Jagdeep Gambhir Tue, 04/10/2012 - 06:12
Patrick,
~JG
Patrick Tran Wed, 04/11/2012 - 00:17
Does secondary server need to be deregistered before patch installation ?
Patrick
Correct Answer
jrabinow Wed, 04/11/2012 - 00:21
