9971 Firmware upgrade issue.
Apr 10th, 2012
We are using CUCM 8.5
When I upgrade firmware I see below information on Phone.
Is this successfully upgraded to ver sip9971.9-2-4-19?
Why do I see ver 9.1 under Phone device ? What is this download status shows Failed?
I would like to know, whether this phone firmware is successfully loaded with ver sip9971.9-2-4-19 ?
Active Load IDsip9971.9-2-4-19
Inactive Load IDsip9971.9-1-1SR1
Download StatusFailed
Requested Load IDsip9971.9-2-2SR1-9
Download Server10.1.9.27
Inactive Load Failure ReasonFile Not Found
Active Network InterfaceEthernet
MAC Address64AE0CF6BDFB
WLAN MAC Address405539AD4872
Host NameSEP64AE0CF6BDFB
Phone DN818
Versionsip9971.9-2-4-19
Device default configured with active and inactive load.
Cisco 9971 SIP sip9971.9-2-4-19
Rgds
Rajesh
Overall Rating: 5 (4 ratings)
rajesh.kumar Tue, 04/10/2012 - 02:03
Under device default inactive load information is : sip9971.9-2-2SR1-9
Active load information is : sip9971.9-2-4-19
ronpatel Tue, 04/10/2012 - 02:27
Hi Rajesh,
Inactive Load information :- appears only if a load is in the process of downloading or if the download failed
I think your download is failed.
Have you installed any new files in CUCM to get this firmwre. If yes was required services were restarted.
regards
Ronak patel
Rate helpful posts.
rajesh.kumar Tue, 04/10/2012 - 03:47
Dear Ronak patel
I have loaded new firmware ie sip9971.9-2-4-19 on CUCM as well as restarted TFTp service.
All this error, I got it after doing as per the procedure.
Question is Phone Active load shows sip9971.9-2-4-19
If firmware download failed, what could be the issue?
I have attached debug display log from phone previously for get more hint.
Pls. suggest
Rgds
Rajesh
Jeremy Brown Mon, 04/25/2016 - 11:16
I have had this issue. Look at the network setup on the phones and make sure they have a TFTP defined. Mine were in a subnet that did not get it from option 150 (they were VPN phones). I was able to specify the CUCM server itself in the phone configs "load server" and it was then able to find the file and upgrade. Its a workaround but it works. Remember to remove the load server when you are done.
rajesh.kumar Tue, 04/10/2012 - 09:08
Dear All
Seems like 9951, 9971 series phones are Cisco's one more flop phones.
Releases to trouble end user and open many TAC cases.
So many issues.
Cisco introdues it as latest phone. But customer faces many issues. And there is no much support document available for these phones.
As I know all the customer had different issues with this Phone.
Currently I am facing problem in one of the 9971 phone, missed call details not displying on the phone. Just "More" button bottom of the screen. But if we restart the phone, missed call numbers appear on the screen display. After few days same problem comes back.......! Cisco's SIP version........!!!!!!
abarkalg Tue, 04/10/2012 - 02:30
Hi Rajesh,
                 Restart the TFTP services, it will get the active load in the device defaults.
Abdul
Please rate helpful posts!!!
rajesh.kumar Tue, 04/10/2012 - 09:09
Dear All
So many issues.
ronpatel Wed, 04/11/2012 - 00:54
Missed call details will be shown in the right hand side buttons. Are you not seeing it??
Is it only happening to one 9971 phone or you are facing issue with other phones also?
Ronak Patel
ronpatel Wed, 04/11/2012 - 00:59
HI
Also when you press line button in the right hand side of phone screen, Are you able to see call history in the 9971 phone.
regards
Ronak Patel
rajesh.kumar Wed, 04/11/2012 - 01:29
Dear Ronak Patel
It is only happening for 9971 Phone.
If there are example 12 missed calls, on top of the display, it shows 12 missed calls.
When we press relevent botton display shows blank and I can still press "More" button on botton, but all screen blank.
When we restart phones, it works perfectly, but after day or two, problem still exists.
I thought it could be  bug issue. But firmware upgradation also failing.....!
Since these phones are expensive being used by executives......finger points at entire Cisco IP Telephony system instability.
Rgds
Rajesh Kumar
ronpatel Wed, 04/11/2012 - 01:35
This is a bug.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCti27403
We can not certify whole Cisco IPT product line up as instable if we have some issue with ip phone. Let us frist see where is the problem. Let me know the firmware of the IP phone which you are running.
Ronak patel
Please rate all helpful posts by clicking the stars below the answer.
rajesh.kumar Wed, 04/11/2012 - 12:23
Dear Ronak Patel
Before upgrade firmware version was sip9971.9-1-1SR1
Do you have any clues that why firmware upgrade failed from sip9971.9-1-1SR1 to sip9971.9-2-4-19
Rgds
Rajesh
ronpatel Wed, 04/11/2012 - 21:32
Hi Rajesh,
What file you have used to get to this firmware.
Also give me the screen shot of the device defauly section of CUCM admin page where we have information for 9971 phone.
Ronak Patel
rajesh.kumar Thu, 04/12/2012 - 00:36
I have used file:cmterm-9971.9-2-4-19.cop.sgn
After upload and restatred tftp service, restarted phones, upgrade was showing failed.
Next day, I tried with sip9971.9-2-2SR1-9, that also didnt work.
Mihail Petreski Mon, 07/09/2012 - 15:57
Hi all,
Has this been solved? I am getting a similar issue.
I'm trying to upgrade a 9971 to sip9971.9-2-4-19 but the phone just sits there. The phone is registered, and I can use the phone, but it doesnt upgrade.
Although, via CUCM Admin I do see that the phone is saying "Download Status: Upgrading"
10 mins later it says "Download Status: Successful"
Then the phone resets and it again says "Download Status" Upgrading"
The Debug Display shows
8:51:30a DeviceImageDownloadSuccess DeviceName=SEP8CB64F57EC82 IPAddress=172.X.1X.X Method=3 Active=sip9971.9-0-3 Inactive= Server=0.0.0.0
Mihail Petreski Mon, 07/09/2012 - 17:38
sip9971.9-0-3 doesn’t go directly to sip9971.9-2-4-19.
I managed to get to sip9971.9-2-4-19 through a two-step process. First I went to sip9971.9-2-1 and then to sip9971.9-2-4-19.
Felipe de Mello Wed, 05/01/2013 - 08:02
Do you have the TFTP service on multiple nodes? You need to install the COP file on every node you have the TFTP service running and restart the TFTP service.
T Lee Thu, 12/05/2013 - 13:45
We also ran into the same issue. We have multiple nodes and FDEMELLO's suggestion helped. The only other step we forgot to do was to go into the CUCM and copy over the new SIPxxxx file name (without the .load .spn etc extension) in place of the old load name. Device > Device Settings > Device Defaults
Related Content
