IS-IS configured over a trunk link between l3 switches
Apr 10th, 2012
I have got two switches s1 and s2 which are connected through a trunk port. SVIs are configured on two switches along with ISIS. Problem is switches are not able to route the SVIs or networks configured on other switches. I dont know if it can be done on trunk link, so  I need help in this. I am copying the configuration of two switches:
This is the trunk link:
S1(3/3) <--->S2(7/1)
I have checked this scenario by making the the ports 3/3 and 7/1 on both switches as l3 ports and it was working fine. So just wanted to confirm if this can be done or not.
Switch 1
Switch#sh run
Building configuration...
Current configuration : 2852 bytes
! Last configuration change at 06:50:48 UTC Tue Apr 10 2012
version 15.1
no service pad
service compress-config
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
hw-module system max-queue-limit 7000
vtp domain cisco
vtp mode transparent
power redundancy-mode redundant
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 6-7,10,20,30
interface Loopback1
ip address 3.3.3.3 255.255.255.255
ip router isis
interface FastEthernet1
no ip address
shutdown
speed auto
duplex auto
interface TenGigabitEthernet1/1
interface TenGigabitEthernet1/2
interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface GigabitEthernet1/5
interface GigabitEthernet1/6
interface GigabitEthernet3/1
interface GigabitEthernet3/2
interface GigabitEthernet3/3
switchport mode trunk
interface GigabitEthernet3/4
interface GigabitEthernet3/5
interface GigabitEthernet3/6
interface GigabitEthernet3/7
interface GigabitEthernet3/8
interface GigabitEthernet3/9
interface GigabitEthernet3/10
interface GigabitEthernet3/11
interface GigabitEthernet3/12
interface GigabitEthernet3/13
interface GigabitEthernet3/14
interface GigabitEthernet3/15
interface GigabitEthernet3/16
interface GigabitEthernet3/17
interface GigabitEthernet3/18
interface GigabitEthernet3/19
interface GigabitEthernet3/20
interface GigabitEthernet3/21
interface GigabitEthernet3/22
interface GigabitEthernet3/23
interface GigabitEthernet3/24
interface GigabitEthernet3/25
interface GigabitEthernet3/26
interface GigabitEthernet3/27
interface GigabitEthernet3/28
interface GigabitEthernet3/29
interface GigabitEthernet3/30
interface GigabitEthernet3/31
interface GigabitEthernet3/32
interface GigabitEthernet3/33
interface GigabitEthernet3/34
interface GigabitEthernet3/35
interface GigabitEthernet3/36
interface GigabitEthernet3/37
interface GigabitEthernet3/38
interface GigabitEthernet3/39
interface GigabitEthernet3/40
interface GigabitEthernet3/41
interface GigabitEthernet3/42
interface GigabitEthernet3/43
interface GigabitEthernet3/44
interface GigabitEthernet3/45
interface GigabitEthernet3/46
interface GigabitEthernet3/47
interface GigabitEthernet3/48
interface Vlan1
no ip address
interface Vlan10
ip address 10.0.0.2 255.0.0.0
ip router isis
interface Vlan30
ip address 30.0.0.1 255.0.0.0
ip router isis
router isis
net 49.0001.0000.0000.000c.00
nsf cisco
nsf interval 0
nsf interface wait 30
maximum-paths 8
no ip http server
line con 0
stopbits 1
speed 38400
line vty 0 4
login
end
Switch#
Switch 2
Switch#sh run
Current configuration : 4604 bytes
! Last configuration change at 04:45:49 UTC Tue Apr 10 2012
version 15.1
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
ip vrf mgmtVrf
vtp domain cisco
redundancy
mode sso
vlan 7-11,14-15,20,30
interface Loopback0
no ip address
interface Loopback1
ip address 1.1.1.1 255.255.255.255
ip router isis
ip vrf forwarding mgmtVrf
no ip address
speed auto
duplex auto
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface GigabitEthernet1/7
interface GigabitEthernet1/8
interface GigabitEthernet1/9
interface GigabitEthernet1/10
interface GigabitEthernet1/11
interface GigabitEthernet1/12
interface GigabitEthernet1/13
interface GigabitEthernet1/14
interface GigabitEthernet1/15
interface GigabitEthernet1/16
interface GigabitEthernet1/17
interface GigabitEthernet1/18
interface GigabitEthernet1/19
interface GigabitEthernet1/20
interface GigabitEthernet1/21
interface GigabitEthernet1/22
interface GigabitEthernet1/23
interface GigabitEthernet1/24
interface GigabitEthernet1/25
interface GigabitEthernet1/26
interface GigabitEthernet1/27
interface GigabitEthernet1/28
interface GigabitEthernet1/29
interface GigabitEthernet1/30
interface GigabitEthernet1/31
interface GigabitEthernet1/32
interface GigabitEthernet1/33
interface GigabitEthernet1/34
interface GigabitEthernet1/35
interface GigabitEthernet1/36
interface GigabitEthernet1/37
interface GigabitEthernet1/38
interface GigabitEthernet1/39
interface GigabitEthernet1/40
interface GigabitEthernet1/41
interface GigabitEthernet1/42
interface GigabitEthernet1/43
interface GigabitEthernet1/44
interface GigabitEthernet1/45
interface GigabitEthernet1/46
interface GigabitEthernet1/47
interface GigabitEthernet1/48
interface TenGigabitEthernet3/1
interface TenGigabitEthernet3/2
interface TenGigabitEthernet4/1
interface TenGigabitEthernet4/2
interface GigabitEthernet4/3
interface GigabitEthernet4/4
interface GigabitEthernet4/5
interface GigabitEthernet4/6
interface GigabitEthernet7/1
interface GigabitEthernet7/2
interface GigabitEthernet7/3
interface GigabitEthernet7/4
interface GigabitEthernet7/5
interface GigabitEthernet7/6
interface GigabitEthernet7/7
interface GigabitEthernet7/8
interface GigabitEthernet7/9
interface GigabitEthernet7/10
interface GigabitEthernet7/11
interface GigabitEthernet7/12
interface GigabitEthernet7/13
interface GigabitEthernet7/14
interface GigabitEthernet7/15
interface GigabitEthernet7/16
interface GigabitEthernet7/17
interface GigabitEthernet7/18
interface GigabitEthernet7/19
interface GigabitEthernet7/20
interface GigabitEthernet7/21
interface GigabitEthernet7/22
interface GigabitEthernet7/23
interface GigabitEthernet7/24
interface GigabitEthernet7/25
interface GigabitEthernet7/26
interface GigabitEthernet7/27
interface GigabitEthernet7/28
interface GigabitEthernet7/29
interface GigabitEthernet7/30
interface GigabitEthernet7/31
interface GigabitEthernet7/32
interface GigabitEthernet7/33
interface GigabitEthernet7/34
interface GigabitEthernet7/35
interface GigabitEthernet7/36
interface GigabitEthernet7/37
interface GigabitEthernet7/38
interface GigabitEthernet7/39
interface GigabitEthernet7/40
interface GigabitEthernet7/41
interface GigabitEthernet7/42
interface GigabitEthernet7/43
interface GigabitEthernet7/44
interface GigabitEthernet7/45
interface GigabitEthernet7/46
interface GigabitEthernet7/47
interface GigabitEthernet7/48
interface Vlan1
no ip address
interface Vlan10
ip address 10.0.0.1 255.0.0.0
ip router isis
interface Vlan20
ip address 20.0.0.1 255.0.0.0
ip router isis
router isis
net 49.0001.0000.0000.000b.00
nsf cisco
nsf interval 0
maximum-paths 8
no ip http server
line con 0
stopbits 1
speed 38400
line vty 0 4
login
end
Switch#
Krishna,
Employee Id:-496777,
Cisco Systems, Inc,
Bangalore.
Kyle McKay Fri, 04/13/2012 - 08:46
Does a routing adjacency establish between the two routers?
If I am understanding you correctly, the issue is that you cannot route to the other switch from the local switch - meaning you are not recieving routes from the neighbor ?
kpvnss Fri, 04/13/2012 - 09:13
Yes Kyle I am not recieving routes from the neighbor
kpvnss Fri, 04/13/2012 - 09:19
Kyle I forgot to mention something If I configure the ports that are linked between the switches as access ports adding them to some vlan and configure SVI on both of the switches for that particular vlan and also configure ISIS on this SVI and remaining SVIs/L3 ports, I am able to see the routes of neighbouring switch. I could see problem only with configuring the ports as trunk.
Reza Sharifi Fri, 04/13/2012 - 10:36
I know your ports are trunked and therefore all vlans are allowed, but can you add the specific vlans and test again?
kpvnss Sun, 04/15/2012 - 00:18
Yes Reza I did that using "sw trunk   allowed ", but not able to see the routes of another switch.
Peter Paluch Sun, 04/15/2012 - 03:10
Reza, Krisha,
Please allow me to join the discussion. This is an interesting issue.
Krisha, can you please provide the output of the following commands from both switches? It's going to be quite a list but possibly it will help us narrow down the scope of the problem.
  • show cdp neighbor
  • show interfaces trunk
  • show isis neighbors
  • show clns
  • show clns protocol
  • show clns neighbors
  • show ip protocols
  • show ip route
Thank you!
Best regards,
Peter
kpvnss Sun, 04/15/2012 - 23:53
Peter, I am sending you the info which you asked me.
Switch 1:-
s1#sh cdp neigh
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
                  D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
gsgsw-labswitch16
                 Fas 1             162             R S I  WS-C4948  Gig 1/13
s2               Gig 3/1           127             R S I  WS-C4503- Gig 3/1
s1#sh run int gi3/1
Current configuration : 93 bytes
switchport trunk allowed vlan 10
end
s1#sh ip int br | i up
FastEthernet1          unassigned      YES unset  up                    up
GigabitEthernet3/1     unassigned      YES unset  up                    up
GigabitEthernet3/2     unassigned      YES unset  up                    up
GigabitEthernet3/3     unassigned      YES unset  up                    up
GigabitEthernet3/4     unassigned      YES unset  up                    up
Loopback1              1.1.1.1         YES manual up                    up
Vlan1                  unassigned      YES unset  up                    up
Vlan10                 10.0.0.1        YES manual up                    up
Vlan20                 20.0.0.1        YES manual up                    up
s1#sh inter
s1#sh interfaces tru
s1#sh interfaces trunk
Port        Mode             Encapsulation  Status        Native vlan
Gi3/1       on               802.1q         trunking      1
Port        Vlans allowed on trunk
Gi3/1       10
Port        Vlans allowed and active in management domain
Gi3/1       10
Port        Vlans in spanning tree forwarding state and not pruned
Gi3/1       10
s1#sh
s1#show isi
s1#show isis neigh
s1#show isis neighbors
System Id      Type Interface   IP Address      State Holdtime Circuit Id
s1#sh
s1#show clsn
s1#show clns
Global CLNS Information:
  3 Interfaces Enabled for CLNS
  Configuration Timer: 60, Default Holding Timer: 300, Packet Lifetime 64
  ERPDU's requested on locally generated packets
  Running IS-IS in IP-only mode (CLNS forwarding not allowed)
  NET: 49.0001.0002.0002.0002.00
s1#sh clns proto
s1#sh clns protocol
IS-IS Router: 2
  System Id: 0002.0002.0002.00  IS-Type: level-1-2
  Manual area address(es):
        49.0001
  Routing for area address(es):
        49.0001
  Interfaces supported by IS-IS:
        Loopback1 - IP
        Vlan20 - IP
        Vlan10 - IP
  Redistribute:
    static (on by default)
  Distance for L2 CLNS routes: 110
  RRR level: none
  Generate narrow metrics: level-1-2
  Accept narrow metrics:   level-1-2
  Generate wide metrics:   none
  Accept wide metrics:     none
s1#sh
s1#show clns
s1#show clns neigh
s1#show clns neighbors
System Id      Interface   SNPA                State  Holdtime  Type Protocol
s1#sh ip protocols
*** IP Routing is NSF aware ***
Routing Protocol is "isis 2"
  Outgoing update filter list for all interfaces is not set
  Incoming update filter list for all interfaces is not set
  Redistributing: isis 2
  Address Summarization:
    None
  Maximum path: 4
  Routing for Networks:
    Vlan10
    Vlan20
    Loopback1
  Routing Information Sources:
    Gateway         Distance      Last Update
  Distance: (default is 115)
s1#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is not set
      1.0.0.0/32 is subnetted, 1 subnets
C        1.1.1.1 is directly connected, Loopback1
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.0.0.0/8 is directly connected, Vlan10
L        10.0.0.1/32 is directly connected, Vlan10
      20.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        20.0.0.0/8 is directly connected, Vlan20
L        20.0.0.1/32 is directly connected, Vlan20
s1#
s1#
Switch 2:-
s2#sh cdp neigh
s1               Gig 3/1           122             R S I  WS-C4503  Gig 3/1
s2#sh run int gi3/1
end
s2#sh ip int br | i up
Loopback1              2.2.2.2         YES manual up                    up
Vlan10                 10.0.0.2        YES NVRAM  up                    up
Vlan30                 30.0.0.1        YES manual up                    up
s2#sh inter
s2#sh interfaces tru
s2#sh interfaces trunk
Gi3/1       10
Gi3/1       10
Gi3/1       10
s2#sh
s2#show isi
s2#show isis neig
s2#show isis neighbors
s2#sh
s2#show clns
s2#show clns
  NET: 49.0001.0001.0001.0001.00
s2#sh clns pro
s2#sh clns protocol
IS-IS Router: 2
  System Id: 0001.0001.0001.00  IS-Type: level-1-2
        49.0001
        49.0001
        Loopback1 - IP
        Vlan30 - IP
        Vlan10 - IP
  Redistribute:
  RRR level: none
s2#sh
s2#show clns
s2#show clns neigh
s2#show clns neighbors
s2#sh ip
s2#sh ip pro
s2#sh ip protocols
    None
  Maximum path: 4
    Vlan10
    Vlan30
    Loopback1
s2#sh ip
s2#sh ip route
s2#sh ip route
      2.0.0.0/32 is subnetted, 1 subnets
C        2.2.2.2 is directly connected, Loopback1
L        10.0.0.2/32 is directly connected, Vlan10
      30.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        30.0.0.0/8 is directly connected, Vlan30
L        30.0.0.1/32 is directly connected, Vlan30
s2#
kpvnss Mon, 04/16/2012 - 00:06
Hi Peter,
Another small thing which I wanted to mention if I make the ports which are linked between switch 1 and switch 2 as access instead of trunk then everything works fine, I am sending you the required info for that also please look into it.
Switch 1:-
s1#sh cdp neigh
gsgsw-labswitch16
                 Fas 1             179             R S I  WS-C4948  Gig 1/13
s2               Gig 3/1           144             R S I  WS-C4503- Gig 3/1
s1#sh run int gi3/1
Current configuration : 87 bytes
switchport access vlan 10
switchport mode access
end
s1#sh isis niegh
s1#sh isis neigh
s1#sh isis neighbors
s2             L1   Vl10        10.0.0.2        UP    8        s2.01
s2             L2   Vl10        10.0.0.2        UP    8        s2.01
s1#sh clns
s1#sh clns proto
s1#sh clns protocol
IS-IS Router: 2
        49.0001
        49.0001
        Loopback1 - IP
        Vlan20 - IP
        Vlan10 - IP
  Redistribute:
  RRR level: none
s1#sh clns neigh
s2             Vl10        0021.d8ce.51ff      Up     8         L1L2 IS-IS
s1#sh ip proto
s1#sh ip protocols
    None
  Maximum path: 4
    Vlan10
    Vlan20
    Loopback1
    2.2.2.2              115      00:06:19
s1#sh ip route
i L1     2.2.2.2 [115/20] via 10.0.0.2, 00:07:25, Vlan10
i L1  30.0.0.0/8 [115/20] via 10.0.0.2, 00:07:25, Vlan10
s1#
Switch 2:-
s2#
s2#sh cdp neigh
s1               Gig 3/1           160             R S I  WS-C4503  Gig 3/1
s2#sh run int gi3/1
end
s2#sh isis neigh
s1             L1   Vl10        10.0.0.1        UP    24       s2.01
s1             L2   Vl10        10.0.0.1        UP    29       s2.01
s2#sh clns
s2#sh clns
s2#sh clns neig
s2#sh clns pro
s2#sh clns protocol
IS-IS Router: 2
        49.0001
        49.0001
        Loopback1 - IP
        Vlan30 - IP
        Vlan10 - IP
  Redistribute:
  RRR level: none
s2#sh clns
s2#sh clns neigh
s1             Vl10        000d.ed4a.49ff      Up     29        L1L2 IS-IS
s2#sh ip pro
s2#sh ip protocols
    None
  Maximum path: 4
    Vlan10
    Vlan30
    Loopback1
    1.1.1.1              115      00:00:03
s2#sh ip route
i L1     1.1.1.1 [115/20] via 10.0.0.1, 00:09:00, Vlan10
i L1  20.0.0.0/8 [115/20] via 10.0.0.1, 00:09:00, Vlan10
s2#
Krishna.
Peter Paluch Mon, 04/16/2012 - 00:13
Hello Krishna,
I will go over your outputs in more detail later today - thanks for uploading them.
The difference in the behavior caused by the trunk reminds me of a possible problem related to system MTU. Can you please enter the following command on the interface Vlan10 on both switches and see if it makes the IS-IS work through the trunk?
interface Vlan 10
  no isis hello padding
Thank you!
Best regards,
Peter
kpvnss Mon, 04/16/2012 - 01:43
Hi Peter,
I checked it by adding "no isis hello padding" this to the "int vlan 10" of both switches. Still it is not working...
krishna.
Peter Paluch Mon, 04/16/2012 - 01:54
Hello Krishna,
I'd say it's time to do some debugging
Set the ports between the switches to access mode, and issue the debug isis adj-packets and debug isis protocol-errors. Observe the buildup of the adjacency and possibly record the sequence of steps taken for the routers to become adjacent.
Then, set the ports between the switches to trunk mode and again, observe the debug output. Try to find the spot where the debug begins to differ.
Best regards,
Peter
kpvnss Mon, 04/16/2012 - 23:45
Hi Peter,
After changing the native vlan of trunk ports using (sw trunk native vlan 10), I could see the routes and ISIS is working fine.
switchport trunk native vlan 10
end
Thanks a lot everyone :-)
krishna.
Peter Paluch Tue, 04/17/2012 - 00:20
Krishna,
Thank you for updating us! But frankly, the solution does not make any sense Why should a native VLAN modification cause the IS-IS to miraculously start working?
I am suspecting some problem with STP here. Can you put back the native VLAN 1, wait 20-30 seconds, and check the output of show spanning-tree and show spanning-tree inconsistentports if there is any issue related to some STP-discovered inconsistency?
Once again, this solution is weird - and we've got to know the exact mechanism behind it.
Best regards,
Peter
kpvnss Wed, 04/18/2012 - 06:42
Hi Peter,
I tested it and I am sure that this is not the problem of Spanning tree protocol. What I understand from my knowledge and after discussing with my teammates that as we need atleast one l3 channel on the top of  which we can configure a routing protocol so that the routes can be exchanged using that l3 channel.
In my setup the intention was to create an SVI for vlan 10 on both of the switches which resembles configuring l3 interfaces between the switches. As we know that it is working fine if I make it as access port of the vlan 10. Problems come with trunk port whose default native vlan is 1, and all the untagged packets(including the packets which carry is-is routes info) are tagged with vlan 1, which shouldn't be the case and get dropped at other switch  as there is no virtual l3 channel configured on vlan 1(i.e., configuring SVIs for vlan 1 at both ends), as we are creating a virtual l3 channel using SVIs of vlan 10. So if we change the native vlan of the trunk to vlan 10, the untagged packets will be tagged with vlan 10 info and as the  SVIs are configured at both ends, routing info is exchanged and it is working successfully.
I hope that this makes sense. Once again thank you very much Peter.
Krishna.
