EIGRP all FD are infinite.
Apr 10th, 2012
  • Bronze, 100 points or more
Hi All,
Planning a migration from OSPF to EIGRP. I'm firing up the EIGRP on my devices with an AD of 120 for internal and 170 for external. I was hoping to check the topology tables and verify the correct routes are being learned, metrics look correct etc. to my Surprise, all of the FD in my routing tables say Infinite/Infinity/Inaccessible (depending on platform). OSPF is fine. I guess i'm confused, should I not see an FD if EIGRP route isn't being used?
I have 2x Nexus 5548 as my cores with L3 card. I have 2x 3945E (3900-1 and 3900-2) connected to the Nexus' via routed links.
All my peerings are up. The Nexus' are peered to eachother, a couple of L3 switches are peered to the Nexus' and my 3945Es are peered as well. All the subnets from the Nexus switches appear on my 3900s in the topology table, but FD is infinite. I have a 3rd 3945E (3900-3) peered to 3900-2. The 3rd 3900 isn't getting any topology information from 3900-2 for any routes that are sourced off the Nexus boxes. It's getting topology for the /30 interfaces on 3900-2 going to the Nexuses though and the loopback on 3900-2. I have not tweaked any delays / bandwidths yet. I need to get past this hurdle before I do that. Thanks.
here's Nexus EIGRP config (from one of them, both are identical):
version 5.1(3)N1(1)
feature eigrp
router eigrp 10
  distance 120 170
  redistribute static route-map redistribution
  address-family ipv4 unicast
    authentication mode md5
    authentication key-chain EIGRP-Keychain
interface loopback1
  ip router eigrp 10
  ip passive-interface eigrp 10
interface Vlan59
  ip router eigrp 10
interface Vlan90
  ip router eigrp 10
interface Vlan99
  ip router eigrp 10
interface Vlan101
  ip router eigrp 10
interface Vlan102
  ip router eigrp 10
interface Vlan103
  ip router eigrp 10
interface Vlan104
  ip router eigrp 10
interface Vlan105
  ip router eigrp 10
interface Vlan106
  ip router eigrp 10
interface Vlan108
  ip router eigrp 10
interface Vlan110
  ip router eigrp 10
interface Vlan111
  ip router eigrp 10
interface Vlan112
  ip router eigrp 10
interface Vlan113
  ip router eigrp 10
interface Vlan114
  ip router eigrp 10
interface Vlan116
  ip router eigrp 10
interface Vlan120
  ip router eigrp 10
interface Vlan121
  ip router eigrp 10
interface Vlan131
  ip router eigrp 10
interface Vlan141
  ip router eigrp 10
interface Vlan151
  ip router eigrp 10
interface Vlan250
  ip router eigrp 10
interface Vlan799
  ip router eigrp 10
interface Ethernet1/9
  ip router eigrp 10
interface Ethernet2/7
  ip router eigrp 10
EIGRP Config from 3900-2 connects to E2/7 on the Nexus above
router eigrp 10
network 66.194.154.252 0.0.0.3
network 192.168.100.12 0.0.0.3
network 192.168.100.16 0.0.0.3
network 192.168.100.28 0.0.0.3
network 192.168.250.38 0.0.0.0
distance eigrp 120 170
passive-interface default
no passive-interface GigabitEthernet0/0
no passive-interface GigabitEthernet0/1
no passive-interface Tunnel1
Here's a small part of the topology table from 3900-2; Its enough to illustrate my point.
P 192.168.99.0/24, 0 successors, FD is Infinity
        via 192.168.100.17 (3072/2816), GigabitEthernet0/1
        via 192.168.100.13 (3072/2816), GigabitEthernet0/0
P 192.168.116.0/24, 0 successors, FD is Infinity
P 192.168.151.0/24, 0 successors, FD is Infinity
P 192.168.101.0/24, 0 successors, FD is Infinity
Debug on 3900-3 for incoming topology information. debug ip eigrp
This output i'd expect... Routing table not updated, but the info is put into the topology table. The networks learned are that directly connected to 3900-2. The ones being advertised are in the topology on 3900-3.
Apr 10 11:17:17.136: %DUAL-5-NBRCHANGE: EIGRP-IPv4 10: Neighbor 192.168.100.29 (Tunnel1) is up: new adjacency
Apr 10 11:17:19.138: EIGRP-IPv4(10): table(default): 66.194.206.76/30 - do advertise out Tunnel1
Apr 10 11:17:19.138: EIGRP-IPv4(10): table(default): 192.168.95.0/25 - do advertise out Tunnel1
Apr 10 11:17:19.138: EIGRP-IPv4(10): table(default): 192.168.95.128/25 - do advertise out Tunnel1
Apr 10 11:17:19.138: EIGRP-IPv4(10): table(default): 192.168.100.24/30 - do advertise out Tunnel1
Apr 10 11:17:19.138: EIGRP-IPv4(10): table(default): 192.168.100.28/30 - do advertise out Tunnel1
Apr 10 11:17:19.138: EIGRP-IPv4(10): table(default): 192.168.250.18/32 - do advertise out Tunnel1
Apr 10 11:17:19.138: EIGRP-IPv4(10): table(default): 192.168.100.20/30 - do advertise out Tunnel1
Apr 10 11:17:19.142: EIGRP-IPv4(10): table(default): 66.194.206.76/30 - do advertise out Tunnel1
Apr 10 11:17:19.142: EIGRP-IPv4(10): table(default): 192.168.95.0/25 - do advertise out Tunnel1
Apr 10 11:17:19.142: EIGRP-IPv4(10): table(default): 192.168.95.128/25 - do advertise out Tunnel1
Apr 10 11:17:19.142: EIGRP-IPv4(10): table(default): 192.168.100.24/30 - do advertise out Tunnel1
Apr 10 11:17:19.142: EIGRP-IPv4(10): table(default): 192.168.100.28/30 - do advertise out Tunnel1
Apr 10 11:17:19.142: EIGRP-IPv4(10): table(default): 192.168.250.18/32 - do advertise out Tunnel1
Apr 10 11:17:19.142: EIGRP-IPv4(10): table(default): 192.168.100.20/30 - do advertise out Tunnel1
Apr 10 11:17:19.152: EIGRP-IPv4(10): Int 192.168.100.12/30 M 11008 - 250000 30000000 SM 2816 - 2524971008 152
Apr 10 11:17:19.152: EIGRP-IPv4(10): table(default): 192.168.100.12/30 routing table not updated thru 192.168.100.29
Apr 10 11:17:19.152: EIGRP-IPv4(10): Int 192.168.100.16/30 M 11008 - 250000 30000000 SM 2816 - 2524971008 152
Apr 10 11:17:19.152: EIGRP-IPv4(10): table(default): 192.168.100.16/30 routing table not updated thru 192.168.100.29
Apr 10 11:17:19.152: EIGRP-IPv4(10): Int 192.168.250.38/32 M 138752 - 250000 5020000000 SM 128256 - 4060086272 76293
Apr 10 11:17:19.152: EIGRP-IPv4(10): table(default): 192.168.250.38/32 routing table not updated thru 192.168.100.29
Apr 10 11:17:19.152: EIGRP-IPv4(10): Int 66.194.154.252/30 M 28672 - 100000 120000000 SM 28160 - 3774873600 1525
Apr 10 11:17:19.152: EIGRP-IPv4(10): table(default): 66.194.154.252/30 routing table not updated thru 192.168.100.29
Apr 10 11:17:19.152: EIGRP-IPv4(10): Int 192.168.100.28/30 M 11008 - 250000 30000000 SM 10496 - 2524971008 152
Apr 10 11:17:19.152: EIGRP-IPv4(10): table(default): 192.168.100.28/30 routing table not updated thru 192.168.100.29
I know I'm not giving full configs, but I think this is enough to get the idea of the problem im facing. Is what I'm seeing normal? How can I remedy? Thanks.
Overall Rating: 5 (1 ratings)
Peter Paluch Tue, 04/10/2012 - 13:50
  • Cisco Employee,
If the EIGRP is unable to insert an EIGRP-learned route into the routing table because of higher AD, it will mark its FD as infinite in the topology table. The reason is that each distance vector routing protocol advertises a network only if it has been successfully installed into the routing table (i.e. a router running EIGRP advertises an EIGRP-learned network only if it is using it itself). If an EIGRP-learned route is not used by the router, it will not be advertised further.
Because you have set the AD of internal EIGRP routes to 120, you have made them less preferred than the OSPF routes using the AD of 110. That prevents the EIGRP from installing its own routes into the routing table, and marking all EIGRP-learned routes as unreachable. Why did you modify the EIGRP's AD in the first place?
Best regards,
Peter
Richard Burts Tue, 04/10/2012 - 14:12
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Peter
The original poster was pretty clear about why he changed the AD for EIGRP. He is currently running OSPF and does not want to disrupt his live environment while he checks out EIGRP. And I believe that this is a sound approach. However it is not as simple a thing to accomplish as he had thought. He was assuming that he would be able to check out the metrics of advertised routes. But as you so accurately point out EIGRP does not advertise a learned route that does not get inserted into its routing table as an EIGRP route.
So when you look in the topology table you would see entries for the local subnets matching network statements, and you would see entries for subnets learned from its immediate neighbors. But you would not see anything from an EIGRP router more than one hop away. And you would not be able to check the propagation of the routing metric.
Rick
rtjensen4 Wed, 04/11/2012 - 06:44
Thanks for everyone's input. Yeah, it was just a matter of making the EIGRP routes active. It's been a good 4-5 years since I've used EIGRP... i forgot how much more "user-friendly" it is.
Richard Burts Wed, 04/11/2012 - 10:50
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
I am glad that you got it worked out. Thank you for posting back to the forum and giving us the updated status.
Rick
qstyk Wed, 08/07/2013 - 07:57
Neither is more or less user-friendly; it is just based around familiarity. I cut my teeth on OSPF, but have worked with many clients using EIGRP.
After working with both protocols and having completed my R&S CCIE, I really don't give a RIP.
-Jon
Related Content
