Connection Profile for IPads
Scott Payne
Hello everyone!
I am trying to create a connection profile only for iPads. The problem that i have is that regardless fo how it is setup. Other users will be able to select that profile and log in even if they are a laptop.  How can I set it up so that only iPads can access that connection profile?
vabruno
You can either uncheck the option to allow users to choose all available connection profiles which doesn't stop them if they happen to find the name of the profile ( /name-of-profile) or you can use certificates for your iPads, this will prevent anyone else from using that profile unless they have the correct certificate
MarkoTanaskovic
Use the DAP ( Dynamic Access Policies) to distinguish between different OS's, i.e. Different AnyConnect client versions. DAP will allow you to set up additional, local authorization, based on various parameters.
Marko
