Warning message
NetFlow Layer2 on nexus 7k
Apr 10th, 2012
Hi guys,
Ive tried to configure NetFlow on layer 2 without success.
I configured the recond\monitor\exporter like the configuration guide said.
but still i dont receive any netflow traffic.
I checked the firewall on the VM and it looks fine.
Anyone have any idea??
i have done  the command under the ethernet interface :" layer2-switch flow monitor TEST input" - for layer2 input.
Liad Dayan Tue, 04/10/2012 - 22:51
Thanks for the fast replay!!
iam using version 5.1
here is sample of the configuration:
flow exporter scrutinizer
description netflow-tester
destination 192.168.1.212 - the netflow analyzer server ip address
version 9
source vlan 3 (192.168.1.211)
flow monitor TESTER
flow record netflow-original
** i did try to create my wn record for only layer2 data - without success.
After ive done this i start to add the interfaces i want to check.
int ethernet 2/1-2 - this is the uplink we want to test
layer2-switch flow monitor TESTER input
any idea`s?
Liad Dayan Wed, 04/11/2012 - 02:25
Here is the configruation on the Nexus 7k
  description export netflow to scrutinizer
  destination 10.100.212.111
  transport udp 6343
  source Vlan3
  version 9
flow monitor LIAD
  record netflow layer2-switched input
interface port-channel1
  layer2-switched flow monitor LIAD input
Adam Casella Sun, 02/09/2014 - 12:31
  • Bronze, 100 points or more
Hey,
Did you put "mac packet-classify"  on the layer 2 link?  SInce you are esentially placing a MAC ACL on the layer 2 interface when netflow is applied. This would be required to see IP traffic exported.   Other wise only "non-ip" traffic will be exported, which I would imagine would not be very helpful here.
Also keep in mind that the netflow-original recorder is really designed for layer 3 traffic and doesn't have any relevant layer 2 information, See below:
Flow record netflow-original:
    Description: Traditional IPv4 input NetFlow with origin ASs
    No. of users: 1
    Template ID: 258
    Fields:
        match ipv4 source address
        match ipv4 destination address
        match ip protocol
        match ip tos
        match transport source-port
        match transport destination-port
        match interface input
        match interface output
        match flow direction
        collect routing source as
        collect routing destination as
        collect routing next-hop address ipv4
        collect transport tcp flags
        collect counter bytes
        collect counter packets
        collect timestamp sys-uptime first
        collect timestamp sys-uptime last
This may not matter if you are putting this in between two routers, where the MAC's don't change, but you probably want to create you own recorder:
flow record layer2-netflow
  match datalink mac source-address
  match datalink mac destination-address
  match datalink vlan
You can also add in any of the above information as well from netflow orginal depending on what you actually want to see.
Adam
