CUBE 15.1(4)M4 Help - SIP Redirect
Apr 10th, 2012
All,
I am trying the get CUBE to work with a SIP proxy sending 3xx messages to the CUBE. The CUBE appears to never consider the redirect message. The same configuration works on a LAB CME. The following are verified:
rediection is allowed under SIP-UA
KIHQ1M1APVGR02#show sip-ua status
SIP User Agent Status
SIP User Agent for UDP : ENABLED
SIP User Agent for TCP : ENABLED
SIP User Agent for TLS over TCP : ENABLED
SIP User Agent bind status(signaling): DISABLED
SIP User Agent bind status(media): DISABLED
SIP early-media for 180 responses with SDP: ENABLED
SIP max-forwards : 70
SIP DNS SRV version: 2 (rfc 2782)
NAT Settings for the SIP-UA
Role in SDP: NONE
Check media source packets: DISABLED
Maximum duration for a telephone-event in NOTIFYs: 2000 ms
SIP support for ISDN SUSPEND/RESUME: ENABLED
Redirection (3xx) message handling: ENABLED
Reason Header will override Response/Request Codes: DISABLED
Out-of-dialog Refer: DISABLED
Presence support is DISABLED
protocol mode is ipv4
SDP application configuration:
Version line (v=) required
Owner line (o=) required
Timespec line (t=) required
Media supported: audio video image
Network types supported: IN
Address types supported: IP4 IP6
Transport types supported: RTP/AVP udptl
Voice service voip allows sip to sip and supplementary service redirect. Is there a magic command needed that differs between CME and CUBE on the same IOS?
Thanks All,
Pete
anchoudh Tue, 04/10/2012 - 20:32
  • Red, 2250 points or more
Hi Pete,
Reference:
http://www.cisco.com/en/US/docs/ios/voice/cube/configuration/guide/vb_1380_ps5640_TSD_Products_Configuration_Guide_Chapter.html
The following sample output shows that the time interval between consecutive NOTIFY messages for a telephone event is the default of 2000 ms:
Router# show sip-ua status
SIP max-forwards : 6
Role in SDP: NONE
Didn't find any modifications required from your config, wondering what is the issue here.
Hope it helps.
Anand
Please rate helpful posts !!
