running BGP on WS-C3750X-24T-S using IP Services IOS
Apr 11th, 2012
Hi All,
Im planning to install a WAN Switch on our network basically this WAN switch will be the core WAN switch in our WAN segments where all WAN connections coming in and will use EBGP peering to every CE WAN router.
is Advanced BGP supporeted in WS-C3750X-24T-S?
thanks
Marlon
Marlon Malinao Thu, 04/12/2012 - 07:10
Hi, can anyone confirm this? Tnx
Marlon Malinao Mon, 04/16/2012 - 18:14
Hi Guys,
thanks for the reply, yeah im quite confused as well, as my colleague also mentioned to me it is not supported.
im planning to use to include in the bundle the "IP Base to IP Services Factory IOS Upgrade"
advanced features like the BGP routing policy, usual AS prepend, MED etc.
jay.ocampo Mon, 04/16/2012 - 19:05
Hi Marlon,
Nice to see you here after you left a few months back....
I agree 3750X supports BGP with IP services feature set, Just that ip services feature set is only available as an upgrade option so ensure this is the one that will be purchased as there is no switch model dedicated with IP services.
With regards to some BGP features, route-map command "set as-path {tag | prepend as-path-string}"
is not supported under 12.2(55)SE .
Refer: to: http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/12.2_55_se/configuration/guide/swuncli.html#wp1046153
Check if 15.x supports this.
Jay Ocampo
