NX-OS EEM command/pattern option
Answered Question
Apr 11th, 2012
In IOS under EEM action we have command and pattern options to provide an imput based on specific pattern. I can not find that option in NX-OS. Is there any other syntax in NX-OS for similar application? Basically on a specific track down event I need to telnet to other NX-OS sytems and am trying to get it done using EEM on NX-OS. Any suggestions are appreciated.
Thank you.
Correct Answer by Joe Clarke about 4 years 9 months ago
Unfortunately, this is not possible on NX-OS.  EEM on NX-OS is EEM by name only.  The feature is very different than it is on IOS.  What you could do is use an IOS box as a proxy.  That is, send a trap using EEM from your NX-OS box, then have IOS do the telnet to the other NX-OS box to perform the necessary commands.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Wed, 04/11/2012 - 23:43
