iPhone/iPad certificate authentication by ACS 5.x
mkdccie
Dear All,
Currently the ACS 5 is authenticate the iPhone/iPad by using the MAC address (which is entered manually) and AD user/password, i need to do that with certificate, so it will be scalable.
How i can do that?
Mohammed
Patrick Tran
If you want to deploy certificates on iPhone/iPad automatically, check Mobile Device Management solutions.
http://www.sap.com/campaigns/2011_04_mobility/assets/GartnerReport_MDM_MQ_April2011.pdf
Those certificates could be used for WiFi or VPN authentication.
Patrick
Hi Patrick,
Thanks, but this will not show me how to do it.
Mohammed
