Warning message
block ip phone without extesion mobility
Answered Question
Apr 11th, 2012
Can I to block the cisco IP phone with a password/PIN without use the extension mobility?
thanks.
Correct Answer by Robert Thomas about 5 years 4 months ago
You could use FAC codes for outbound calls, but not for internal calls.
Overall Rating: 5 (1 ratings)
Chris Deren Wed, 04/11/2012 - 08:11
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
No, there is no security setting that would let you do that.  If you are concerned about phone's ability to make outbound calls you can restrict that with proper CSS, you can also lock down access to Settings, etc.
HTH,
Chris
Correct Answer
Robert Thomas Wed, 04/11/2012 - 09:20
  • Silver, 250 points or more
Jean Lofrano Wed, 04/11/2012 - 11:16
Great Robert!!
For example: 44560[7-9]XXXXXXX...
Here the password is 4456!!
thanks.
