Warning message
BGP_down due to service policy
Apr 11th, 2012
After upgrade from 10 Mbps to 20 Mbps BGP down,if we remove the  services policy immediately BGP came up.
class-map match-any COS3
match ip dscp cs1
class-map match-any COS2
match ip dscp cs4
match ip dscp af21
match access-group name COS2_LIST
class-map match-any COS1
match ip dscp cs6
match ip dscp ef
match ip dscp af31
match ip dscp cs3
policy-map pune-troy-qos
class COS1
  set ip dscp cs5
    priority percent 25
class COS2
  set ip dscp cs4
    bandwidth percent 20
class COS3
  set ip dscp cs2
    bandwidth percent 5
     random-detect dscp-based
class class-default
  set ip dscp default
    fair-queue
policy-map shape-zzz-20
class class-default
    shape average 20480000
  service-policy pune-troy-qos
if we remove service policy output shape-zzz-20  from WAN interface immediately BGP came up.
Overall Rating: 5 (1 ratings)
Vasileios Boulo... Fri, 04/13/2012 - 02:37
  • Silver, 250 points or more
Hi Karthikeyan,
Does the BGP flap only during traffic congestion?
If yes, I would recommend to match to the class COS1 also the IP prec = 6 value.
This is the default value that is used for BGP packets and you can cross check this by running the sh ip bgp neighbor command. So, the BGP (network Control traffic) is prioritized to the LLQ class.
Apply again the Service Policy and check if the Class matchs IP-Prec traffic and hopefully BGP will not flap anymore.
Hope that helps!
Vasilis
searskarthik Fri, 04/13/2012 - 03:23
Thansks  Vasilis,
even witout traffic BGP not up,if I removed service policy from Int Gi0/1 immediately BGP came up.
#sh policy-map shape-ZZZ-10
  Policy Map shape-ZZZ-10
    Class class-default
      Average Rate Traffic Shaping
      cir 10240000 (bps)
#sh policy-map  pune-troy-qos
  Policy Map pune-troy-qos
    Class COS1
      set ip dscp cs5
      priority 25 (%)
    Class COS2
      set ip dscp cs4
      bandwidth 20 (%)
    Class COS3
      set ip dscp cs2
      bandwidth 5 (%)
       packet-based wred, exponential weight 9
      dscp    min-threshold    max-threshold    mark-probablity
      default (0)   -                -                1/10
    Class class-default
      set ip dscp default
      fair-queue
#sh class-map COS1
Class Map match-any COS1 (id 3)
   Match ip  dscp cs6 (48)
   Match ip  dscp ef (46)
   Match ip  dscp af31 (26)
   Match ip  dscp cs3 (24)
#sh class-map COS2
Class Map match-any COS2 (id 2)
   Match ip  dscp cs4 (32)
   Match ip  dscp af21 (18)
   Match access-group name COS2_LIST
Ivan Krimmel Fri, 04/13/2012 - 03:32
  • Gold, 750 points or more
Hi Karthikeyan,
while in the problem state, could you provide:
sh policy-map int wan_int output
sh policy-map int wan_int output class
please?
Ivan.
Kishore Chennupati Fri, 04/13/2012 - 19:08
Karthik,
Let me ask you a question. Did this work when you had the same policy for 10Mbps. I mean all you did was to upgrade the link from 10Mbs to 20Mbps right? or is it the first time you are applying Qos
Regards Kishore
Vasileios Boulo... Fri, 04/13/2012 - 02:46
I assume that you do not have errors/drop/CRC to your interface and any Control plane policy configured in this router.
Vasilis
Related Content
