upgrading a Cius
Tommer Catlin
What is the process to upgrade a Cius?   I cant seem to figure it out. The CCO download is a ZIP file and it has a few files in.  Do you leave the ZIP and upload that to CUCM from the OS page or?   Its a little odd it seems like.  Thanks!
Jaime Valencia
There's a cop file you download, it's the exact same thing as with a phone. Latest one is:
cmterm-cius.9-2-3-143.cop.sgn
Download it, install it via OS admin and CIUS should download it. Once it's downloaded you'll get a message a new FW is going to be installed and to reboot now or delay it.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
7 Replies 7
Jaime Valencia
java
java
Thanks Java... yeah,  i saw the COP file and didnt put 2 and 2 together.  I kept looking at the firmware ZIP file and couldnt figure out what to do with it.
where do you find the OS admin? Is this option on the table?
CUCM OS admin and I have no idea what table you're talking about.
java
java
Sorry, for my mistake. I meant to ask if the cius tablet can be update directly or does the tablet gets os updates directly from call manager.
CIUS is just like any other phone, you install the FW on CUCM and it will download it from there.
java
java
