1552E not able to connect to the WLC
Answered Question
We purchased cisco AIR-CAP1552E-A-K9 and it has IOS c1520-k9w8-mx.124-23c.JA2. WLC with the lastest firmware 7.0.116.0 is not able to connect to the Cisco 1552E. 1552E log show that it can see the WLC but unable to connect. We have devices for both U.S and Australia domain.
Why are the 1552E not able to connect to the WLC?
Correct Answer by Amjad Abdullah about 4 years 10 months ago
Francis:
Yes you can.
However, If APs on different WLC's can hear each other then the RF groups may not be formed although same RF group name is configured on two WLCs.
For RF-Groups to work among multiple WLCs it needs same countries to be configured on all WLCs with same order. see multiple countries guildlines:
http://www.cisco.com/en/US/docs/wireless/controller/7.0/configuration/guide/c70lwap.html#wp1147755
If your 1552 APs are not on same location as othe APs on the other WLC (each WLC has its APs in different locations and APs from first WLC do not hear signals from APs on second WLC) then you can do it safely by dedicating one WLC for the mesh APs while that WLC is configured with one country only.
Amjad
Correct Answer by Surendra BG about 4 years 10 months ago
No!! 1552 AP are mesh only APs and we cannot turn off the feature.
aahha!! thats the problem!! the mesh is not supported on multiple country codes.. if you change the same the MESH ap will register back right away.. and there is no work around for this problem since this is how cisco designed the mesh
Surendra
ok!! If we have multiple country selected on the WLC, then the mesh APs will not join the WLC and its a ground rule.. if you have rest of the APs in the mesh and still joined then its a strange behaviour !!
Check if the multiple countries are chekced in the WLC..
WLC >> Wireless >> Country >> See what all countries are enabled.. there should be only 1 allowed)
Surendra
Overall Rating: 5 (4 ratings)
Surendra BG Wed, 04/11/2012 - 20:07
is the MAC address of the Mesh AP addedd on the AP policies on the WLC??
Yes. Getting the following messages
*Apr 12 11:22:54.627: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.x.x.x peer_port: 5246
% CDP is not supported on this interface, or for this encapsulation
Translating "CISCO-LWAPP-CONTROLLER"...domain server (255.255.255.255)
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
*Apr 12 11:22:54.623: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.x.x.x peer_port: 5246
*Apr 12 11:22:54.623: %CAPWAP-5-SENDJOIN: sending Join Request to 10x.x.x
*Apr 12 11:22:54.623: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Apr 12 11:22:54.623: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.x.x.x
*Apr 12 11:22:54.623: %DTLS-5-PEER_DISCONNECT: Peer 10.x.x.x has closed connection.
*Apr 12 11:22:54.623: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.x.x.x:5246
*Apr 12 11:22:54.663: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Apr 12 11:22:56.323:  status of voice_diag_test from WLC is false
Surendra BG Wed, 04/11/2012 - 20:24
Just make sure multiple country codes are not allowed on the WLC and i hope you have confiugred option 43 to get the AP the ip address and  the WLC ip..
Surendra
Scott Fella Wed, 04/11/2012 - 20:08
What does the log show? Did you add the mac address to the wlc?
Scott Fella
Sent from my iPhone
Yes, added the MAC to the WLC. Getting the following messages
Correct Answer
Surendra BG Wed, 04/11/2012 - 20:36
Surendra
Correct Answer
Surendra BG Wed, 04/11/2012 - 21:55
Surendra
Correct Answer
Surendra BG Wed, 04/11/2012 - 22:06
Surendra BG Wed, 04/11/2012 - 22:13
Hmmm... Yeah u can do that but this may resul in getting the A radio down or something but work a try!!
Surendra
Correct Answer
Amjad Abdullah Sun, 04/15/2012 - 02:42
Francis:
Yes you can.
Amjad
MD KAFINUZZAMAN Fri, 08/08/2014 - 23:33
I have wlc 5760 and my AIR-CAP1552E-C-K9  ios c1520-k9w8-xx.152-4.JA1 not joing to controller
show log
*Aug  9 12:37:19.999: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_connection_db.c:2134 Max retransmission count reached!
*Aug  9 12:37:26.047: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.2.2.5:5246
*Aug  9 12:37:26.047: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Aug  9 12:37:26.047: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Aug  9 12:36:50.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.2.2.5 peer_port: 5246
*Aug  9 12:36:50.327: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.2.2.5 peer_port: 5246
*Aug  9 12:36:50.327: %CAPWAP-5-SENDJOIN: sending
% CDP is not supported on this interface, or for this encapsulationJoin Request to 10.2.2.5
*Aug  9 12:36:50.335: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.2.2.5
*Aug  9 12:36:50.335: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.2.2.5:5246
*Aug  9 12:36:50.339: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Aug  9 12:36:50.331: %CAPWAP-5-SENDJOIN: sending Join Request to 10.2.2.5
*Aug  9 12:36:50.379: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
Waiting for response.......
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
