Problem with NAT
Answered Question
Apr 12th, 2012
I'm trying to use the NAT dynamic translation and here is the example that I use to test it and understand it! Unfortunately It doesn't run...!
Could someone help me?
hostname ACE2
interface gigabitEthernet 1/1
  switchport access vlan 1000
  no shutdown
interface gigabitEthernet 1/2
  shutdown
interface gigabitEthernet 1/3
  shutdown
interface gigabitEthernet 1/4
  shutdown
access-list ACL1 line 8 extended permit tcp any eq www any
class-map type management match-any L4_REMOTE-ACCESS_CLASS
  2 match protocol icmp any
  3 match protocol http any
  4 match protocol ssh any
  5 match protocol https any
  6 match protocol xml-https any
class-map match-all L_CLASS
  2 match source-address 192.168.10.88 255.255.255.0
policy-map type management first-match L4_REMOTE-ACCESS_MATCH
  class L4_REMOTE-ACCESS_CLASS
    permit
policy-map multi-match L4_POLICY
  class L_CLASS
    nat dynamic 1 vlan 1000
interface vlan 1000
  ip address 192.168.10.252 255.255.255.0
  nat-pool 1 192.168.10.205 192.168.10.205 netmask 255.255.255.0
  service-policy input L4_REMOTE-ACCESS_MATCH
  service-policy input L4_POLICY
  no shutdown
ip route 0.0.0.0 0.0.0.0 192.168.10.1
username admin password 5 $1$yGY2HM8q$fSl.uxYYOlmtUPe/6uUnA.  role Admin domain
default-domain
username www password 5 $1$i/TshwS6$WdMVudA/tn.ER6dR.33r7/  role Admin domain de
fault-domain
ssh key dsa 1024 force
When I'm connected with SSH  it is always the same IP Adresse for my computer :
ACE2/Admin# sh conn
conn-id    np dir proto vlan source                destination           state
43         1  in  TCP   1000 192.168.10.88:50263   192.168.10.252:22     ESTAB
30         1  out TCP   1000 192.168.10.252:22     192.168.10.88:50263   ESTAB
Correct Answer by andrew-travis about 2 years 1 week ago
blankguy7,
That's great news!  It looks like NAT is working as expected for you.
When you SSH to the ACE appliance (192.168.10.249), you are not being NAT'd since there isn't a need.  You are terminating the SSH connection on the ACE itself for managment.  If you needed to SSH to the web servers through the load-balancer, you will need another class-map to match 192.168.10.250 on tcp eq ssh.
Please let me know if that is confusing or not.  Thank you.
Andrew
Average Rating: 5 (1 ratings)
blankguy7 Thu, 04/12/2012 - 01:44
Thanks Sandeep for the links and infos!
But I would like to know where is the problem in my configuration...
sandkum5 Thu, 04/12/2012 - 02:22
The NAT configuration looks ok but the translated destination IP cannot be a ACE IP.
Additionally, you need the following configurations to make this work:
- You should apply the ACL on the vlan 1000 interface using the access-group command to allow the traffic.
The configured acl will allow only www traffic.
- You should configure rserver and serverfarm configurations to forward the traffic to the respective server. Else, how will ACE know where to forward the traffic.
Please refer the previously provided link regarding one arm mode configuration on ACE for more info on the setup.
If you need more info, please provide complete setup info on what exactly you are trying to acheive along with IP details.
Hope this answers your question.
Sandeep
andrew-travis Thu, 04/12/2012 - 05:52
blankguy7,
A couple of things stand out that could be causing you issues:
- Since you're only translating to one IP address, you'll want to add "pat" to the end of the NAT statement to do port address translation.
     nat-pool 1 192.168.10.205 192.168.10.205 netmask 255.255.255.0 pat
- Interface VLAN 1000 has an implicit deny any any on it unless otherwise specified.  You'll need to add an access-group to that interface.
     access-list everyone line 8 extended permit ip any any
     access-list everyone line 16 extended permit icmp any any
     interface vlan 1000
          access-group input everyone
          access-group output everyone
- You don't have any serverfarms or real servers to load-balance traffic to.
     rserver ________
          inservice
     serverfarm _________
          rserver _________
               inservice
          class L_CLASS
               serverfarm ________
Any of those things could be why your SSH connection is not load-balanced through the ACE.  I would recommend looking through the links that Sandeep posted so that you can complete your configuration.
Andrew
blankguy7 Thu, 04/12/2012 - 06:17
Hi Andrew
Thanks for your reply!
So, I've corrected the error (except this:
          class L_CLASS
               serverfarm ________
because there're not possibility to add serverfarm)
Now, I'll read the doc again because it doesn't really run...
Here's config again:
switch/GAAS# sh run
Generating configuration....
access-list PERMIT-ALL line 8 extended permit ip any any
access-list PERMIT-ALL line 16 extended permit icmp any any
rserver redirect REDIRECT
  webhost-redirection http://192.168.0.33%p
  inservice
serverfarm redirect REDIRECT-OURWEBSITE
  rserver REDIRECT
    inservice
class-map type management match-any CONTEXT-ACCESS_CLASS
  4 match protocol https any
  5 match protocol ssh any
class-map type http loadbalance match-all MATCH-OURWEBSITE
  2 match http header Host header-value "192.168.10.250"
class-map match-all VIP-OURWEBSITE
  2 match virtual-address 192.168.10.250 tcp eq www
policy-map type management first-match CONTEXT-ACCESS_MAP
  class CONTEXT-ACCESS_CLASS
    permit
policy-map type loadbalance first-match LB-OURWEBSITE
  class MATCH-OURWEBSITE
    serverfarm REDIRECT-OURWEBSITE
policy-map multi-match VIP-SERVICE-POLICY
  class VIP-OURWEBSITE
    loadbalance vip inservice
    loadbalance policy LB-OURWEBSITE
    loadbalance vip icmp-reply active
    nat dynamic 1 vlan 500
interface vlan 500
  ip address 192.168.10.249 255.255.255.0
  no normalization
  no icmp-guard
  access-group input PERMIT-ALL
  nat-pool 1 192.168.10.253 192.168.10.253 netmask 255.255.255.0 pat
  service-policy input CONTEXT-ACCESS_MAP
  service-policy input VIP-SERVICE-POLICY
  no shutdown
domain D1
  add-object interface vlan 500
  add-object serverfarm REDIRECT-OURWEBSITE
  add-object rserver REDIRECT
  add-object access-list extended PERMIT-ALL
role R1
  rule 1 permit create feature interface
  rule 2 permit create feature loadbalance
  rule 3 permit create feature real-inservice
  rule 4 permit create feature rserver
  rule 5 permit create feature serverfarm
username USER1 password 5 $1$lB1AQmxN$uH70ynfEN6X8GycrlitfP/  role R1 domain D1
andrew-travis Thu, 04/12/2012 - 06:27
blankguy7, what are the symptoms exactly?  When you hit the VIP (192.168.10.250) in your web browser, what happens?
A couple of other things to check are:
- Typo on the redirection URL (missing the / before the %p), should be: http://192.168.0.33/%p
- Missing access-group on outgoing traffic (necessary since using ACE in One Arm Mode): access-group output PERMIT-ALL
As you've pointed out, with the redirect serverfarm you won't need to create a different serverfarm.  What you have for that should work (minus the typo on the redirect URL).
Please let me know the results of those two changes.
Thanks.
Andrew
blankguy7 Thu, 04/12/2012 - 06:45
Hi Andrew,
Oh, sorry! I'm working on two ACE at the same time.. but it does not matter! On this side, when I give
192.168.10.250 on my website, I will be redirect to http://192.168.0.33 that's mean it's work BUT I've sniffed the network and I see that after the redirection the communication run between the website and my pc and not between the wesite and the ACE. The ACE send to the website the IP address from my PC and not the NAT...
I want to enable NAT because I want that the communication goes always through the ACE!
bg
andrew-travis Thu, 04/12/2012 - 07:06
blankguy7,
Ahh, now I understand what you really want to do and what the issue is.  You want to redirect traffic to a real server, but you want the traffic to go through the ACE.  Source NAT will force return traffic through the ACE, but if the ACE is simply redirecting you (and not load-balancing you) to another IP address, there is no way to force the traffic flow through the ACE.  We're just going about this the wrong way.  For what you want, you need a serverfarm so that you can load-balance the traffic to it (this load-balancing does the redirection that you want).  Try this:
rserver host web-server
  ip address 192.168.0.33
  inservice
serverfarm host web-serverfarm
  rserver web-server
    inservice
  class class-default
    serverfarm web-serverfarm
From your configs and requirements, I don't believe you need to do any URL redirection, you just need to load-balanced web traffic to a real server (in a serverfarm).  Try that and lemme know how it goes.
Andrew
blankguy7 Fri, 04/13/2012 - 00:08
Hi Andrew,
Yes, you're right! It's exactly what I want but my english is not perfect to explain that.... and sometimes I found the
cisco litterature too big or difficult to find what reallya I need!
Now, I understood and I configured like your example and the "load-balancing" is running well (yeah) and I think that the nat is running well too!
So, I don't see the ip nat on "sniffer" on the client side (PC) but, when I've made a telnet session on this serverfarm from command line on my PC:
C:\>telnet 192.168.10.250 80
than I see :
switch/Admin# sh xlate
TCP PAT from vlan500:192.168.10.88/51230 to vlan500:192.168.10.253/1029
switch/Admin#
switch/Admin# sh nat-fabric src-nat 1 3
        NAT object ID:2 mapped_if:3 policy_id:1 type:DYNAMIC IPv4/6: 1/0 nat_poo
l_id:2
                Pool ID:2 PAT:1 pool_id:1 mapped_if:3 Ref_count:1 binding:all
                lower:192.168.10.253 upper:192.168.10.253 Bitmap-ID:33
                List of NAT object IDs: 2
switch/Admin# sh service-policy VIP-SERVICE-POLICY
Status     : ACTIVE
Interface: vlan 1 500
  service-policy: VIP-SERVICE-POLICY
    class: VIP-OURWEBSITE
      nat:
        curr conns       : 1         , hit count        : 5
        dropped conns    : 0
        client pkt count : 34        , client byte count: 3883
        server pkt count : 37        , server byte count: 27263
        conn-rate-limit      : 0         , drop-count : 0
        bandwidth-rate-limit : 0         , drop-count : 0
      loadbalance:
        L7 loadbalance policy: LB-OURWEBSITE
I think that's all right!
Just another question: actually the ACE run NAT only in case of "loasd-balancing" but not in a ssh connection on vlan500?
Yeah, a great thanks to your help and have a nice day,
Correct Answer
andrew-travis Fri, 04/13/2012 - 05:39
blankguy7,
Andrew
blankguy7 Fri, 04/13/2012 - 06:01
Hi Andrew
Yes, it's a great news...
Thanks for your SSH explanations, it's now ok for me and not more confusing!
Now, I could continue my configuration. I'll programm tcl on ACE...
Thanks a lot again for your help... was great!
Login or Register to take actions
Posted April 12, 2012 at 12:20 AM
Stats:
Replies:11 Avg. Rating:5
Views:522 Votes:0
Shares:0
Tags: No tags.
Discussions Leaderboard
Rank Username Points
1 1,551
2 369
3 333
4 228
5 212
