"was DCE, now set to DCE"
Hi all
I have two 1941 routers both with HWIC-1T and HWIC-3G-HSPA interfaces.
I set these up to talk over frame relay in a lab using a cross over cable.  Once I got this working, the routers were shipped to their respective homes, about 100km apart and 2000km from my desk.
The routers are connected to Telstra NTU-4S boxes and are supposed to be able to talke to each over.  Both routers report s0/0/0 as down and down.  With 'deb serial int' both routers are repeating 'wic_mbrd_sync_mode_reg_init:: was DCE, now set to DCE' every 30 seconds.
Both routers have 'clock rate 2000000' in their configs and I've been unable to remove this line.  Both routers have had 'frame intf dte' typed in the config (frame intf doesn't show in show run).
I'm stumped.  Any one got any ideas on this?
Thanks in advance.
CC
Richard Burts Thu, 04/12/2012 - 04:17
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
CC
When the connection was a cross over cable you obviously need the serial controller to be DCE. Now that the connection is not cross over cable but is Telestra I guess that the serial controller needs to be DTE.
As a note about this there is a DTE/DCE distinction for the serial controller that is different from the DTE/DCE for the frame relay interface configuration.
Rick
Hi Rick
Yes, you're right.  The Telstra NTU is the DCE so the Cisco 1941's must be DTE.
One thing I forgot to mention is that 'show controller s0/0/0' states that the serial cable is not connected.
The Telstra techs claim that the line is OK (they can talk to their NTUs) but they don't have LMI (can't talk to the 1941's).
CC
Richard Burts Thu, 04/12/2012 - 07:30
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
CC
If the show controller output says that the cable is not connected then there is some kind of problem between the router and the Telstra and you need to find and solve that before we worry about anything else. It could be as simple as the cable not connected or not connected correctly. Or it might be something more complex.
Is the Telstra connection a Frame Relay service? (Does the connection through Telstra really connect to a Frame Relay switch?)
It may be obvious but I will point out anyway that there probably are some things that you needed to configure when the connection was routers back to back that you do not need when the connection is to real Frame Relay.
Rick
Hi Rick
kununurra#show run int s0/0/0
Building configuration...
Current configuration : 178 bytes
interface Serial0/0/0
ip address 192.168.57.1 255.255.255.0
encapsulation frame-relay
clock rate 2000000
frame-relay interface-dlci 16
frame-relay lmi-type ansi
end
How do I force the physical (and the frame-relay) interface to be DTE?
Also, does it matter that 'clock rate 2000000' is in the config?
CC
Yes and yes.
I spent quite a while on the phone with a L2 Telstra tech and about another half hour with an L3 Telstra Tech yesterday afternoon.
Briefly, the history here is that there were Nortel routers in place but the two sites (Kununurra and Wyndham) have been unable to communicate since a lightning strike a few weeks ago.  Our own tech has been on site and took screen shots of the Nortel routers config.  Telstra have been on site and replaced the NTU-4S at both sites.
The decision was made to replace the Nortels due to age and the fact that our tech was unabkle to get them to talk to the NTUs.  The cables the Cisco 1941s are using are brand new (smart serial to X21 - db15).  Multiple people have confirmed the cables are connected properly between the Cisco and NTU.
CC
Hmm, I wonder if this is my problem.
The cables connecting the 1941's to the NTUs are http://www.blackbox.com.au/PRODUCT.cfm?PARTNUMBER=EHC260-0010
The description is "CISCO SMART SERIAL CABLE X21/DB15M DTE 3M".  Does this mean DTE at the X21 end?  Does it matter?
I'm now looking at
http://www.blackbox.com.au/PRODUCT.cfm?PARTNUMBER=EHC270-0010 for which the description is "CISCO SMART SERIAL CABLE X21/DB15F DCE 3M", of course then we'd need a DB15 gender bender as the NTU needs male cables.
Thoughts?
Richard Burts Thu, 04/12/2012 - 20:13
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
CC
I am not sure, but I would think that the DTE cable would be what you want.
I wonder about the fact that the config still has the clock rate command. In my experience of IOS routers that command only shows up when the controller believes that it is connected using DCE cables. So if the command is still in the config then it could be part of the problem.
I am not familiar with the Telstra equipment. Could you ask them if they can specify what they expect to be configured on your end of the connection?
It might also help us if you would post the output of show inventory and/or show diag to help us identify the card for the serial connection. And the output of show controller might also be helpful.
Rick
Not sure how much detail is needed so apologies in advance if I'm providing too much.
Telstra are definately expecting our end to be DTE.  Is that what you were asking?
kununurra#show control s 0/0/0
Interface Serial0/0/0
Hardware is SCC
No serial cable attached
idb at 0x2857CEA0, driver data structure at 0x3054CF8C
wic_info 0x28583DBC
WIC Serial Global Registers: (0x10490000)
sti_errintr_en      (0004): 0x00000000  scc_ctrl_regs       (1004): 0x0020
mgmt_intr_status    (1010): 0x0010      netio_intr_status   (1012): 0x0000
mgmt_intr_enable    (1020): 0x00CA      netio_intr_enable   (1022): 0x0001
timer_0_7_enable    (1024): 0x0000      timer_16_19_enable  (1026): 0x0000
timer_0_1_program   (1030): 0x0000      timer_2_3_program   (1032): 0x0000
timer_4_5_program   (1034): 0x0000      timer_6_7_program   (1036): 0x0000
timer_16_program    (1040): 0x0000      timer_17_program    (1042): 0x0000
timer_18_program    (1044): 0x0000      timer_19_program    (1046): 0x0000
WIC Serial SCC Registers: (0)
ch_mode_cfg         (1100): 0x08019031  ch_flag_cfg         (1104): 0x007E
ch_flwctrl_cfg      (1108): 0x0000      ch_intr_enable      (110C): 0x09FF
ch_cmd_stat         (110E): 0x0048
WIC Serial DMA Registers:
Rx ring_start_ptr   (2000): 0x0EC55B00  Rx ring_mask_index  (2004): 0x00F80000
internal_desc_stat  (2008): 0x0400060C  internal_buff_addr  (200C): 0x0EC650E0
internal_context    (2010): 0x00000000  internal_fifo_data  (2014): 0x0EC650E0
Tx ring_start_ptr   (2200): 0x0EC57080  Tx ring_mask_index  (2204): 0x03F80000
internal_desc_stat  (2208): 0x00000000  internal_buff_addr  (220C): 0x00000000
internal_context    (2210): 0x00000001  internal_fifo_data  (2214): 0x00000000
WIC Serial Interface Registers:
intf_ctrl           (3000): 0x1001      modem_ctrl          (3002): 0xE1D8
flow_ctrl           (3004): 0x7000      brg dvdr            (3006): 0x0005
WIC TDM/FREQ Counter Registers:
tdm_control         (3100): 0x0000      tdm_a_8k_divider    (3102): 0x0000
tdm_b_8k_divider    (3104): 0x0000
freq_count_port_sel (310A): 0           freq_count          (310C):        0
TDM Control Registers:
  tmdsw_ctl                              (addr 0x104B0040): 0x00000001
  vmcr[0]                                (addr 0x104B0060): 0x00000001
  vmcr[1]                                (addr 0x104B0064): 0x00000001
  vmcr[2]                                (addr 0x104B0068): 0x00000001
  vmcr[3]                                (addr 0x104B006C): 0x00000001
  ntr_cr0                                (addr 0x104B0078): 0x00000001
  ntr_cr1                                (addr 0x104B0080): 0x00000001
  tpllr_cr                               (addr 0x104B0088): 0x25100000
  sm_tdm_cr                              (addr 0x104B0070): 0x00000001
  pvdm_tdm_cr                            (addr 0x104B0074): 0x00000001
0 input aborts on receiving flag sequence
0 throttles, 0 enables
0 overruns
0 transmitter underruns
0 transmitter CTS losts
0 rxintr, 0 txintr, 0 rxerr, 0 txerr
0 tx_abort 0 tx_reset
tx_limited = 1(2) tx_count = 0
Receive Ring
rxr head (0)(0x0EC55B00), rxr tail (0)(0x0EC55B00)
  rmd(EC55B00): stats_len 8400060C buff_addr EC650E0
  rmd(EC55B08): stats_len 8400060C buff_addr EC65740
  rmd(EC55B10): stats_len 8400060C buff_addr EC65DA0
  rmd(EC55B18): stats_len 8400060C buff_addr EC66400
  rmd(EC55B20): stats_len 8400060C buff_addr EC66A60
  rmd(EC55B28): stats_len 8400060C buff_addr EC670C0
  rmd(EC55B30): stats_len 8400060C buff_addr EC67720
  rmd(EC55B38): stats_len 8400060C buff_addr EC67D80
  rmd(EC55B40): stats_len 8400060C buff_addr EC683E0
  rmd(EC55B48): stats_len 8400060C buff_addr EC68A40
  rmd(EC55B50): stats_len 8400060C buff_addr EC690A0
  rmd(EC55B58): stats_len 8400060C buff_addr EC69700
  rmd(EC55B60): stats_len 8400060C buff_addr EC69D60
  rmd(EC55B68): stats_len 8400060C buff_addr EC6A3C0
  rmd(EC55B70): stats_len 8400060C buff_addr EC6AA20
  rmd(EC55B78): stats_len 8400060C buff_addr EC6B080
  rmd(EC55B80): stats_len 8400060C buff_addr EC6B6E0
  rmd(EC55B88): stats_len 8400060C buff_addr EC6BD40
  rmd(EC55B90): stats_len 8400060C buff_addr EC6C3A0
  rmd(EC55B98): stats_len 8400060C buff_addr EC6CA00
  rmd(EC55BA0): stats_len 8400060C buff_addr EC6D060
  rmd(EC55BA8): stats_len 8400060C buff_addr EC6D6C0
  rmd(EC55BB0): stats_len 8400060C buff_addr EC6DD20
  rmd(EC55BB8): stats_len 8400060C buff_addr EC6E380
  rmd(EC55BC0): stats_len 8400060C buff_addr EC6E9E0
  rmd(EC55BC8): stats_len 8400060C buff_addr EC6F040
  rmd(EC55BD0): stats_len 8400060C buff_addr EC6F6A0
  rmd(EC55BD8): stats_len 8400060C buff_addr EC6FD00
  rmd(EC55BE0): stats_len 8400060C buff_addr EC70360
  rmd(EC55BE8): stats_len 8400060C buff_addr EC709C0
  rmd(EC55BF0): stats_len 8400060C buff_addr EC71020
  rmd(EC55BF8): stats_len 8400060C buff_addr EC71680
Transmit Ring
txr head (0)(0x0EC57080), txr tail (0)(0x0EC57080)
  tmd(EC57080): sts_len 00000000 buf_addr 0
  tmd(EC57088): sts_len 00000000 buf_addr 0
  tmd(EC57090): sts_len 00000000 buf_addr 0
  tmd(EC57098): sts_len 00000000 buf_addr 0
  tmd(EC570A0): sts_len 00000000 buf_addr 0
  tmd(EC570A8): sts_len 00000000 buf_addr 0
  tmd(EC570B0): sts_len 00000000 buf_addr 0
  tmd(EC570B8): sts_len 00000000 buf_addr 0
  tmd(EC570C0): sts_len 00000000 buf_addr 0
  tmd(EC570C8): sts_len 00000000 buf_addr 0
  tmd(EC570D0): sts_len 00000000 buf_addr 0
  tmd(EC570D8): sts_len 00000000 buf_addr 0
  tmd(EC570E0): sts_len 00000000 buf_addr 0
  tmd(EC570E8): sts_len 00000000 buf_addr 0
  tmd(EC570F0): sts_len 00000000 buf_addr 0
  tmd(EC570F8): sts_len 00000000 buf_addr 0
  tmd(EC57100): sts_len 00000000 buf_addr 0
  tmd(EC57108): sts_len 00000000 buf_addr 0
  tmd(EC57110): sts_len 00000000 buf_addr 0
  tmd(EC57118): sts_len 00000000 buf_addr 0
  tmd(EC57120): sts_len 00000000 buf_addr 0
  tmd(EC57128): sts_len 00000000 buf_addr 0
  tmd(EC57130): sts_len 00000000 buf_addr 0
  tmd(EC57138): sts_len 00000000 buf_addr 0
  tmd(EC57140): sts_len 00000000 buf_addr 0
  tmd(EC57148): sts_len 00000000 buf_addr 0
  tmd(EC57150): sts_len 00000000 buf_addr 0
  tmd(EC57158): sts_len 00000000 buf_addr 0
  tmd(EC57160): sts_len 00000000 buf_addr 0
  tmd(EC57168): sts_len 00000000 buf_addr 0
  tmd(EC57170): sts_len 00000000 buf_addr 0
  tmd(EC57178): sts_len 00000000 buf_addr 0
  tmd(EC57180): sts_len 00000000 buf_addr 0
  tmd(EC57188): sts_len 00000000 buf_addr 0
  tmd(EC57190): sts_len 00000000 buf_addr 0
  tmd(EC57198): sts_len 00000000 buf_addr 0
  tmd(EC571A0): sts_len 00000000 buf_addr 0
  tmd(EC571A8): sts_len 00000000 buf_addr 0
  tmd(EC571B0): sts_len 00000000 buf_addr 0
  tmd(EC571B8): sts_len 00000000 buf_addr 0
  tmd(EC571C0): sts_len 00000000 buf_addr 0
  tmd(EC571C8): sts_len 00000000 buf_addr 0
  tmd(EC571D0): sts_len 00000000 buf_addr 0
  tmd(EC571D8): sts_len 00000000 buf_addr 0
  tmd(EC571E0): sts_len 00000000 buf_addr 0
  tmd(EC571E8): sts_len 00000000 buf_addr 0
  tmd(EC571F0): sts_len 00000000 buf_addr 0
  tmd(EC571F8): sts_len 00000000 buf_addr 0
  tmd(EC57200): sts_len 00000000 buf_addr 0
  tmd(EC57208): sts_len 00000000 buf_addr 0
  tmd(EC57210): sts_len 00000000 buf_addr 0
  tmd(EC57218): sts_len 00000000 buf_addr 0
  tmd(EC57220): sts_len 00000000 buf_addr 0
  tmd(EC57228): sts_len 00000000 buf_addr 0
  tmd(EC57230): sts_len 00000000 buf_addr 0
  tmd(EC57238): sts_len 00000000 buf_addr 0
  tmd(EC57240): sts_len 00000000 buf_addr 0
  tmd(EC57248): sts_len 00000000 buf_addr 0
  tmd(EC57250): sts_len 00000000 buf_addr 0
  tmd(EC57258): sts_len 00000000 buf_addr 0
  tmd(EC57260): sts_len 00000000 buf_addr 0
  tmd(EC57268): sts_len 00000000 buf_addr 0
  tmd(EC57270): sts_len 00000000 buf_addr 0
  tmd(EC57278): sts_len 00000000 buf_addr 0
  tmd(EC57280): sts_len 00000000 buf_addr 0
  tmd(EC57288): sts_len 00000000 buf_addr 0
  tmd(EC57290): sts_len 00000000 buf_addr 0
  tmd(EC57298): sts_len 00000000 buf_addr 0
  tmd(EC572A0): sts_len 00000000 buf_addr 0
  tmd(EC572A8): sts_len 00000000 buf_addr 0
  tmd(EC572B0): sts_len 00000000 buf_addr 0
  tmd(EC572B8): sts_len 00000000 buf_addr 0
  tmd(EC572C0): sts_len 00000000 buf_addr 0
  tmd(EC572C8): sts_len 00000000 buf_addr 0
  tmd(EC572D0): sts_len 00000000 buf_addr 0
  tmd(EC572D8): sts_len 00000000 buf_addr 0
  tmd(EC572E0): sts_len 00000000 buf_addr 0
  tmd(EC572E8): sts_len 00000000 buf_addr 0
  tmd(EC572F0): sts_len 00000000 buf_addr 0
  tmd(EC572F8): sts_len 00000000 buf_addr 0
  tmd(EC57300): sts_len 00000000 buf_addr 0
  tmd(EC57308): sts_len 00000000 buf_addr 0
  tmd(EC57310): sts_len 00000000 buf_addr 0
  tmd(EC57318): sts_len 00000000 buf_addr 0
  tmd(EC57320): sts_len 00000000 buf_addr 0
  tmd(EC57328): sts_len 00000000 buf_addr 0
  tmd(EC57330): sts_len 00000000 buf_addr 0
  tmd(EC57338): sts_len 00000000 buf_addr 0
  tmd(EC57340): sts_len 00000000 buf_addr 0
  tmd(EC57348): sts_len 00000000 buf_addr 0
  tmd(EC57350): sts_len 00000000 buf_addr 0
  tmd(EC57358): sts_len 00000000 buf_addr 0
  tmd(EC57360): sts_len 00000000 buf_addr 0
  tmd(EC57368): sts_len 00000000 buf_addr 0
  tmd(EC57370): sts_len 00000000 buf_addr 0
  tmd(EC57378): sts_len 00000000 buf_addr 0
  tmd(EC57380): sts_len 00000000 buf_addr 0
  tmd(EC57388): sts_len 00000000 buf_addr 0
  tmd(EC57390): sts_len 00000000 buf_addr 0
  tmd(EC57398): sts_len 00000000 buf_addr 0
  tmd(EC573A0): sts_len 00000000 buf_addr 0
  tmd(EC573A8): sts_len 00000000 buf_addr 0
  tmd(EC573B0): sts_len 00000000 buf_addr 0
  tmd(EC573B8): sts_len 00000000 buf_addr 0
  tmd(EC573C0): sts_len 00000000 buf_addr 0
  tmd(EC573C8): sts_len 00000000 buf_addr 0
  tmd(EC573D0): sts_len 00000000 buf_addr 0
  tmd(EC573D8): sts_len 00000000 buf_addr 0
  tmd(EC573E0): sts_len 00000000 buf_addr 0
  tmd(EC573E8): sts_len 00000000 buf_addr 0
  tmd(EC573F0): sts_len 00000000 buf_addr 0
  tmd(EC573F8): sts_len 00000000 buf_addr 0
  tmd(EC57400): sts_len 00000000 buf_addr 0
  tmd(EC57408): sts_len 00000000 buf_addr 0
  tmd(EC57410): sts_len 00000000 buf_addr 0
  tmd(EC57418): sts_len 00000000 buf_addr 0
  tmd(EC57420): sts_len 00000000 buf_addr 0
  tmd(EC57428): sts_len 00000000 buf_addr 0
  tmd(EC57430): sts_len 00000000 buf_addr 0
  tmd(EC57438): sts_len 00000000 buf_addr 0
  tmd(EC57440): sts_len 00000000 buf_addr 0
  tmd(EC57448): sts_len 00000000 buf_addr 0
  tmd(EC57450): sts_len 00000000 buf_addr 0
  tmd(EC57458): sts_len 00000000 buf_addr 0
  tmd(EC57460): sts_len 00000000 buf_addr 0
  tmd(EC57468): sts_len 00000000 buf_addr 0
  tmd(EC57470): sts_len 00000000 buf_addr 0
  tmd(EC57478): sts_len 00000000 buf_addr 0
buffer size 1524
kununurra#show inv
NAME: "CISCO1941/K9 chassis", DESCR: "CISCO1941/K9 chassis"
PID: CISCO1941/K9      , VID: V03 , SN: FGL15432435
NAME: "WAN Interface Card - HWIC Serial 1T on Slot 0 SubSlot 0", DESCR: "WAN Interface Card - HWIC Serial 1T"
PID: HWIC-1T           , VID: V04 , SN: FOC15466RGY
NAME: "3G WWAN HWIC-HSPA/UMTS/EDGE/GPRS-850/900/1800/1900/2100MHz on Slot 0 SubSlot 1", DESCR: "3G WWAN HWIC-HSPA/UMTS/EDGE/GPRS-850/900/1800/1900/2100MHz"
PID: HWIC-3G-HSPA      , VID: V02 , SN: FOC16024B38
NAME: "Modem 0 on Cellular0/1/0", DESCR: "Sierra Wireless MC8790"
PID: MC8790            , VID: 1.0, SN: 011955005213295
NAME: "C1941/C2901 AC Power Supply", DESCR: "C1941/C2901 AC Power Supply"
PID: PWR-1941-2901-AC  , VID:    , SN:
kununurra#
kununurra#sh diag 0
Slot 0:
        C1941 Mother board 2GE, integrated VPN and 2W Port adapter, 4 ports
        Port adapter is analyzed
        Port adapter insertion time 2d01h ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC153573DH
        Hardware Revision        : 1.0
        Part Number              : 73-14318-01
        Top Assy. Part Number    : 800-36881-01
        Board Revision           : B0
        Deviation Number         : 121225
        Fab Version              : 01
        Product (FRU) Number     : CISCO1941/K9
        Version Identifier       : V03
        CLEI Code                : CMMBS00ARB
        Processor type           : C8
        Chassis Serial Number    : FGL15432435
        Chassis MAC Address      : ccef.48b6.9960
        MAC Address block size   : 96
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 35 33 35 37 33 44 48 40
          0x10: 06 19 41 01 00 82 49 37 EE 01 C0 46 03 20 00 90
          0x20: 11 01 42 42 30 88 00 01 D9 89 02 01 CB 8C 43 49
          0x30: 53 43 4F 31 39 34 31 2F 4B 39 89 56 30 33 20 D9
          0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 42 53 30 30 41 52
          0x50: 42 09 C8 C2 8B 46 47 4C 31 35 34 33 32 34 33 35
          0x60: C3 06 CC EF 48 B6 99 60 43 00 60 C4 08 00 00 00
          0x70: 00 00 00 00 00 F3 00 65 40 00 91 41 00 87 42 00
          0x80: 00 F8 00 28 03 E8 1C 89 07 D0 20 21 0B B8 20 93
          0x90: 0F A0 21 2F 13 88 21 83 17 70 21 A8 1B 58 21 B0
          0xA0: 1F 40 21 AB 23 28 21 79 27 10 21 78 41 00 EB 42
          0xB0: 00 00 F8 00 28 03 E8 1C 20 07 D0 1F 40 0B B8 20
          0xC0: 6C 0F A0 21 34 13 88 21 34 17 70 21 98 1B 58 21
          0xD0: 98 1F 40 21 98 23 28 21 34 27 10 21 34 FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 0:
        HWIC Serial 1T WAN daughter card
        Top Assy. Part Number    : 800-34377-02
        Board Revision           : B0
        Deviation Number         : 0
        Fab Version              : 01
        PCB Serial Number        : FOC15466RGY
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Fab Part Number          : 28-8141-01
        Product (FRU) Number     : HWIC-1T
        Version Identifier       : V04
        CLEI Code                : COUIA8SCAA
          0x00: 04 FF 40 05 88 41 01 00 C0 46 03 20 00 86 49 02
          0x10: 42 42 30 88 00 00 00 00 02 01 C1 8B 46 4F 43 31
          0x20: 35 34 36 36 52 47 59 03 00 81 00 00 00 00 04 00
          0x30: 85 1C 1F CD 01 CB 87 48 57 49 43 2D 31 54 89 56
          0x40: 30 34 20 C6 8A 43 4F 55 49 41 38 53 43 41 41 D9
          0x50: 02 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 1:
        Part Number              : 73-11671-02
        Top Assy. Part Number    : 800-30450-02
        Board Revision           : C0
        Deviation Number         : 124008
        Fab Version              : 04
        PCB Serial Number        : FOC16024B38
        RMA History              : 00
        Product (FRU) Number     : HWIC-3G-HSPA
        Version Identifier       : V02
        CLEI Code                : COUIA29CAA
          0x00: 04 FF 40 06 1D 41 01 00 82 49 2D 97 02 C0 46 03
          0x10: 20 00 76 F2 02 42 43 30 88 00 01 E4 68 02 04 C1
          0x20: 8B 46 4F 43 31 36 30 32 34 42 33 38 03 00 81 00
          0x30: 00 00 00 04 00 CB 8C 48 57 49 43 2D 33 47 2D 48
          0x40: 53 50 41 89 56 30 32 20 D9 02 40 C1 C6 8A 43 4F
          0x50: 55 49 41 32 39 43 41 41 C4 08 00 00 00 00 00 00
          0x60: 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Embedded Service Engine 0/0 :
  Total platform memory : 524288K bytes
  Total 2nd core memory : 0K bytes
kununurra#sh diag
Slot 0:
        Board Revision           : B0
        Fab Version              : 01
        Processor type           : C8
        WIC Slot 0:
        Board Revision           : B0
        Fab Version              : 01
        RMA History              : 00
        WIC Slot 1:
        Board Revision           : C0
        Fab Version              : 04
        RMA History              : 00
  Start of physical address for 2nd core : 0x80000000
  Virtual address start of 2nd core memory : 0x0 - 0x0
  2nd core configured disabled
  L2 cache ways for 2nd core : 0
I've powered up an old 1721 that I had laying around. It has a WIC-1T (DB60) interface.
1) No cable attached:
Interface Serial0
Hardware is PowerQUICC MPC860
idb at 0x815C8B94, driver data structure at 0x815D0698
2) DCE end of DTE/DCE crossover cable attached (nothing on other end of cable)
Interface Serial0
DCE V.35, no clock
3) DTE end of DTE/DCE crossover cable attached (nothing on other end of cable)
Interface Serial0
DTE V.35 clocks stopped.
Given the above, is it reasonable to think that the cables on the 1941's are faulty as the routers should be at least recognising that something is plugged in?
CC
Richard Burts Fri, 04/13/2012 - 02:36
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
CC
Thank you for the additional information. I hoped that it might point at an issue but I do not see anything obvious in it.
I would think that faulty cables would certainly be a possibility to investigate since the router is not recognizing the cables.
I am not familiar with the Telstra NTU-4S and wonder if there is anything that needs to be done on it to activate the connection to the router?
Rick
Hi Rick
Thank you for the help with this.  We've organised for those smart serial to X21 cables to be sent back to us for testing.  I'll post back when I have a result.
According to Telstra, Cisco routers don't require special settings to talk to these NTU.
Umm, apologies if this is bad form, but could I ask you to cast your eye over
https://supportforums.cisco.com/thread/2143193 (routing between 3g interfaces)?
Many thanks
CC
Richard Burts Fri, 04/13/2012 - 11:28
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
CC
not bad form. I have posted a response to it.
Rick
