Simulate calls in CUCM
Answered Question
Apr 12th, 2012
I want to do pressure test for UCCX. Can I simulate 300~400 calls to route point in CUCM?
CUCM 8.6.2
UCCX 8.5.1
Correct Answer by anchoudh about 5 years 4 months ago
Hi Robin,
For internal testing in Cisco we use Camelot tool for pumping calls through CUCM.
http://wwwin-vts.cisco.com/camelot/
Its an internal link for this tool.
I am not aware about the 3rd party tools for this purpose.
Hope it helps.
Anand
Please rate helpful posts !!
Overall Rating: 5 (1 ratings)
Robin Zhu Thu, 04/12/2012 - 11:25
Hi Java:
Do you mind to advice if there're other methods like third-party tools, or I have to code script via JTAPI? thx.
Correct Answer
anchoudh Fri, 04/13/2012 - 03:58
  • Red, 2250 points or more
Hi Robin,
Hope it helps.
Anand
Sivakumar Shanmugam Fri, 04/13/2012 - 04:28
  • Cisco Employee,
Honestly speaking , there is no built-in app which does this.Just curious to know the reason behind the testing.
Siva
Robin Zhu Fri, 04/13/2012 - 06:31
Hi Anand:
I cant open the link you attached. Is that for internal only? thx
Robin
anchoudh Fri, 04/13/2012 - 08:41
Hi Robin,
Yes its an internal link.
Anand
Pls rate helpful posts !!
Robert Thomas Fri, 04/13/2012 - 09:22
  • Silver, 250 points or more
Best you can use is sipp, it's an opensource tool that can generate SIP and RTP traffic to fill the system with load.
