Meet-Me Number and Pattern
Answered Question
Apr 12th, 2012
I wanted to know if anyone has step-by-step directions on how to setup Meet-Me Number/Pattern on Cisco Callmanager 7.1.5.
Thank you
Correct Answer by Gajanan Pande about 5 years 2 weeks ago
As Chris mentioned, there is nothing much but here you go with the document " Meet-Me Number/Pattern Configuration "
GP.
Pls rate helpful posts by clicking on stars below the post !!
Correct Answer by Chris Deren about 5 years 2 weeks ago
Check you Administrator Guide for step by step directions, but there is very little to it, you go to Meet Me Patterns and define the range using default wildcards i.e. 55XX and assign partition to it.
HTH,
Chris
Overall Rating: 4.7 (9 ratings)
Correct Answer
Chris Deren Thu, 04/12/2012 - 13:32
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
HTH,
Chris
vipankapur1 Tue, 04/17/2012 - 10:15
I have created a extension pool as per the link provided by Gajanan.  I have added the 1st number in the pool to a phone (7945), but I can't dial in from 2 different phones.  Am I doing something wrong or have I forgotten a step?
Chris Deren Tue, 04/17/2012 - 10:19
  • Hall of Fame,
What do you mean by:
You define these ranges, then to start MeetMe you press MeetMe softkey on the phone and enter a number from this range, i.e. 7526 to start the MeetMe conference, then other calls dial 7526 to join it. Is this what you are doing?
Chris
vipankapur1 Tue, 04/17/2012 - 11:11
Chris,
I assigned 7526 to a phone. When I press the MeetMe softkey from another phone, I get 2 quick beeps. I dial the 7526 number and it connects to 7526. But when I dial 7526 from another phone, in order to answer it the 1st phone gets put on hold.
Chris Deren Tue, 04/17/2012 - 11:16
  • Hall of Fame,
You cannot assign overlapping DNs with MeetMe numbers to phones. You created a conflict. You can assign them as speed dials if you want, but not DNs.
HTH, please rate all useful posts!
Chris
Rob Huffman Tue, 04/17/2012 - 11:17
  • Hall of Fame,
    Founding Member
    2017 IP Telephony, Unified Communications
Hi there,
Just to add a note to the great tips from Chris and Gajanan (+5)
- Remove 7526 from the 7945
- go to any phone press new call > MeetMe > 7526 (this will start the conference)
- from other phones dial 7526 and they will be added to meetme conference
Cheers!
Rob
vipankapur1 Tue, 04/17/2012 - 11:58
Thank you all for your help.  I also wanted to know if it is possible when someone joins there is a beep or announce a name?
Rob Huffman Tue, 04/17/2012 - 12:14
  • Hall of Fame,
    Founding Member
Hi there,
I believe this is what you are looking for;
Service Parameters Configuration > Clusterwide Parameters (Feature - General)
Party Entrance Tone - True
Cheers!
Rob
vipankapur1 Tue, 04/17/2012 - 12:57
Thanks Rob,
That worked perfectly.  Is there any option to announe the name of the person joingin the conf.?  I didn't see anything in the Clusterwide Parameters.
Joseph Martini Tue, 04/17/2012 - 17:22
  • Cisco Employee,
You can announce the name of the caller entering by sending all other callers except for the initiator to a unity connection call handler to ask who is calling and then perform a supervised transfer to the meet me conference number. Alternatively you could use a contact center script to do the same thing as unity connection.
vipankapur1 Fri, 04/20/2012 - 07:52
Joe,
I setup a transfer rule (see screenshot) but all I get is a beep when callers enter or leave the conf.  It is not asking them for a name.  Is there anything wrong with the configuration?
Also, when callers call the dial-in number, it places then into the conf. call without any rings.  Can that be changed?
Thank you,
Joseph Martini Fri, 04/20/2012 - 08:46
  • Cisco Employee,
That's how I usually configure things except I usually use the Standard Transfer rule, not the alternate unless you have the alternate enabled (which you do from the screenshot).  As for ringback, the call will be put on hold by the VM port so the network hold audio source could be a ringback file to play ringback.
vipankapur1 Fri, 04/20/2012 - 10:31
Joe,
I  was able to get it working.  I had to setup a DN (7540) that is dialed  and the call gets forwared to the conf. call number 7526.  It does ask  the caller for their name and then transfer the caller.
I also had to setup a Forwarded Routing Rule so when a caller dials 7540, it knows to transfer the call to 7526.
Will I have to setup a 2nd number for every MeetMe number that I want to create.
ex: Dial-in # 7527, needs another DN = 7541
ex: Dial-in # 7528, needs another DN = 7542
Joseph Martini Fri, 04/20/2012 - 11:22
  • Cisco Employee,
Right you'll need a CTI RP to CFA to VM to hit that call handler.  Depending on your requirements you could use the same DN in different partitions for the call so that users who want to join would hit the DN in the partition assigned to the CTI RP to forward through unity connection.  This setup would assume that only certain users would initiate the meet-me conference since they would have to be able to directly dial the meet-me pattern.  It might be best if you setup different numbers but had something like *7527 as the meet-me number, and then users dial in using 7527.  That would be easy for a user to remember to start a meet-me press the softkey and then dial * plus the number, otherwise just dial the number without * to join.
