Old famous problem - AP LAP1142N can't join the controller - 4402, please participate, let's make a good guide!
Answered Question
Apr 12th, 2012
Hello folks,
I really feel sorry for bringing up this discussion again. I wouldn't dare to ask this question if I find someone's clear cut suggestion/solution or an overview giving a detailed step-by-step procedure. People just suggest jumping through so many  hoops like resetting the AP or converting it back to standalone mode and then back to LWAPP.
Hence I have so many questions and hope that we can make a good guide covering all possible problems.
1) AP was originally running a standalone image.  I booted it into a so-called ROMMON or AP mode (ESC is the right key to make it boot into this mode)
I found a recovery image in its flash - c1140-rcvk9w8-mx. I made the AP boot from it by using "set" command and I see that it start booting using this recovery image. Here goes the question. Do all AP settings matter ? E.g. when I run "set" command from AP I see the following:
ap: set
DEFAULT_ROUTER=10.0.0.1
Default_router=10.9.99.1
ENABLE_BREAK=yes
IP_ADDR=10.0.0.1
IP_AddR=10.9.99.9
MANUAL_BOOT=no
NETMASK=255.255.255.224
NEW_IMAGE=yes
PWR_INJECTOR_DETECT=0016.c7fa.b394
RELOAD_REASON=9
ROM_PERSISTENT_UTC=1014941470
TERMLINES=0
netmask=255.255.255.0
2) How would do something like "write erase" or even recover the enable password while being in AP mode? Do I really need to do it ? What I see next makes me believe there's something with the AP configuration (particularly SSH) that prevents an AP join WLC.
3) The AP is powered on, connected to the switchport on the same L2 VLAN where WLC management interface. Then it boots and gets an IP address from the DHCP server located on the other switch.
*Mar  1 00:00:08.695: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:00:08.705: %CDP_PD-2-POWER_LOW: All radios disabled - AC_ADAPTOR  (0000.0000.0000)
*Mar  1 00:00:09.629: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:17.534: %DHCP-6-ADDRESS_ASSIGN: Interface GigabitEthernet0 assigned DHCP address 192.168.1.122, mask 255.255.255.0, hostname AP2
Here comes the question, why do I see this on the console (pay attention at "transport input ssh" line)? Does it have anything to do  with an error for DTLS ?
*Apr 12 12:44:21.034: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Apr 12 12:44:31.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.1.141 peer_port: 5246
*Apr 12 12:44:55.000: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:1924 Max retransmission count reached!
*Apr 12 12:44:55.000: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for 192.168.1.141 is reached.
transport input ssh
% Invalid input detected at '^' marker.
4) Do I have to connect the controller ap-manager interface to the network or I can rely on the AP find the WLC via its management interface. I have never worked with 4400 series controllers. Just started with 5500 and they don't have the ap-manager interface.
Cisco guide says: "The management interface is also used for layer two communications between the WLC and access points", so I can safely assume that it is enough. Moreover I can ping the AP from the WLC while connected to WLC via SSH and its management interface.
5) And finally, what's wrong with the discovery? This is what I see on the controller while debugging capwap packets:
(Cisco Controller) debug>*spamReceiveTask: Apr 12 12:53:52.253: <<<<  Start of CAPWAP Packet  >>>>
*spamReceiveTask: Apr 12 12:53:52.253: CAPWAP Control mesg Recd from 192.168.1.122, Port 57046
*spamReceiveTask: Apr 12 12:53:52.253:          HLEN 4,   Radio ID 0,    WBID 1
*spamReceiveTask: Apr 12 12:53:52.253:          Msg Type   :   CAPWAP_DISCOVERY_REQUEST
*spamReceiveTask: Apr 12 12:53:52.253:          Msg Length : 29
*spamReceiveTask: Apr 12 12:53:52.253:          Msg SeqNum : 0
*spamReceiveTask: Apr 12 12:53:52.253:   Type : CAPWAP_MSGELE_DISCOVERY_TYPE, Length 1
*spamReceiveTask: Apr 12 12:53:52.253:          Discovery Type : CAPWAP_DISCOVERY_TYPE_UNKNOWN
*spamReceiveTask: Apr 12 12:53:52.253:   Type : CAPWAP_MSGELE_WTP_FRAME_TUNNEL, Length 1
*spamReceiveTask: Apr 12 12:53:52.253:          WTP Frame Tunnel Mode : NATIVE_FRAME_TUNNEL_MODE
*spamReceiveTask: Apr 12 12:53:52.253:   Type : CAPWAP_MSGELE_WTP_MAC_TYPE, Length 1
*spamReceiveTask: Apr 12 12:53:52.253:          WTP Mac Type  : SPLIT_MAC
*spamReceiveTask: Apr 12 12:53:52.253:   Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 10
*spamReceiveTask: Apr 12 12:53:52.253:          Vendor Identifier  : 0x00409600
*spamReceiveTask: Apr 12 12:53:52.254:
What discovery mode are we in? L2 or L3 ?
Correct Answer by weterry about 4 years 10 months ago
just think of the 4402 similar to the 5508. The only difference is that on the 4402 you need to use 2 IP addresses in the management vlan on the same port (1 for Management, 1 for AP-Manager).
You can do as many dynamic interfaces you want on port 1,  its just a trunk port.    But the Management+AP-Manager are the only two that can share a vlan ID.
As far as the rest of this thread going all over the place....:
Can you confirm that the Management Interface and the AP-Manager are both in the same vlan, same subnet, and are configured with the same Port Number?
All this business about 1 SFP and which port to plug in has me concerned you split the ports or something.....
The first logs provided imply the AP couldn't attach to the AP-Manager address (but that the Management Interface discovery was fine)
The second logs provided imply the AP never discovered a WLC at all (no attempt to join)...
But then again, as Leo referenced, the Canada domain I guess is a -A not -N.....  so perhaps that was your original problem all along, and the 3600 won't join just because it isn't compatible.
Overall Rating: 5 (2 ratings)
Leo Laohoo Thu, 04/12/2012 - 15:17
Please post the output to the following command:
1.  WLC:  sh sysinfo
2.  WAP:  sh inventory
3.  Console into the WAP and reboot the WAP.  Post the entire bootup process and the WLC discovery process.
zheka_pefti Thu, 04/12/2012 - 15:39
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.0.230.0
RTOS Version..................................... 7.0.230.0
Bootloader Version............................... 4.0.219.0
Emergency Image Version.......................... N/A
Build Type....................................... DATA + WPS
System Name...................................... Cisco_8b:83:03
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.14179.1.1.4.3
IP Address....................................... 192.168.1.140
System Up Time................................... 0 days 19 hrs 9 mins 20 secs
System Timezone Location.........................
Configured Country............................... CA  - Canada
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +41 C
--More-- or (q)uit
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Burned-in MAC Address............................ 00:23:5E:8B:83:00
Crypto Accelerator 1............................. Absent
Crypto Accelerator 2............................. Absent
Power Supply 1................................... Absent
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 12
"Show inventory" on the AP doesn't give any output. Giving you the "show version" instead omitting some legal stuff
AP2>sh ver
Cisco IOS Software, C1140 Software (C1140-RCVK9W8-M), Version 12.4(18a)JA, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 21-Nov-08 01:28 by prod_rel_team
ROM: Bootstrap program is C1140 boot loader
BOOTLDR: C1140 Boot Loader (C1140-BOOT-M) Version 12.4(18a)JA, RELEASE SOFTWARE (fc4)
AP2 uptime is 1 hour, 42 minutes
System returned to ROM by reload
System image file is "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx"
Last reload reason:
cisco AIR-LAP1142N-N-K9    (PowerPC405ex) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FTX1329S9NB
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from reload
LWAPP image version 3.0.51.0
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:22:BD:18:ED:66
Part Number                          : 73-11451-06
PCA Assembly Number                  : 800-30554-03
PCA Revision Number                  : A0
PCB Serial Number                    : FOC13282UKM
Top Assembly Part Number             : 800-31273-01
Top Assembly Serial Number           : FTX1329S9NB
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1142N-N-K9
Configuration register is 0xF
And the full boot process on WAP:
IOS Bootloader - Starting system.
Xmodem file system is available.
DDR values used from system serial eeprom.
WRDTR,CLKTR: 0x84000800, 0x40000000
RQDC, RFDC : 0x80000038, 0x0000020a
PCIE0: link is up.
PCIE0: VC0 is active
PCIE1: link is up.
PCIE1: VC0 is active
PCIEx: initialization done
flashfs[0]: 149 files, 8 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32385024
flashfs[0]: Bytes used: 7901696
flashfs[0]: Bytes available: 24483328
flashfs[0]: flashfs fsck took 16 seconds.
Reading cookie from system serial eeprom...Done
Base Ethernet MAC address: 00:22:bd:18:ed:66
Ethernet speed is 100 Mb - FULL duplex
Loading "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx"...#############################################################################################################################################################################################################################
File "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx" uncompressed and installed, entry point: 0x4000
executing...
enet halted
Image text-base: 0x00004000, data-base: 0x00430000
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 149 files, 8 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 32385024
flashfs[1]: Bytes used: 7901696
flashfs[1]: Bytes available: 24483328
flashfs[1]: flashfs fsck took 4 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Last reset from power-on
% Please define a domain-name first.
ip ssh version 2
transport input ssh
aaa new-model
aaa authentication login default local
login authentication default
transport input ssh
RS
Press RETURN to get started!
SI IDB null
RSSI IDB null
*Mar  1 00:00:05.992: *** CRASH_LOG = YES
Base Ethernet MAC address: 00:22:BD:18:ED:66
*Mar  1 00:00:06.203: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 1024 messages)
*Mar  1 00:00:08.251: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:08.292: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:08.318: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:00:08.327: %CDP_PD-2-POWER_LOW: All radios disabled - AC_ADAPTOR  (0000.0000.0000)
*Mar  1 00:00:09.251: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:17.157: %DHCP-6-ADDRESS_ASSIGN: Interface GigabitEthernet0 assigned DHCP address 192.168.1.123, mask 255.255.255.0, hostname AP2
logging origin-id string AP:0022.bd18.ed66
logging 255.255.255.255
logging trap 3
*Mar  1 00:00:27.230: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar  1 00:00:27.343: Logging LWAPP message to 255.255.255.255.
Translating "CISCO-LWAPP-CONTROLLER"...domain server (192.168.1.40)
*Mar  1 00:00:38.267: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:00:39.267: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER
*Apr 12 15:39:49.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.1.141 peer_port: 5246
Scott Fella Thu, 04/12/2012 - 16:30
Well you do need to connect the AP manager to the network and it should also be on the same subnet as the management. The 5508 uses a dynamic ap manager that is enabled on the management interface which is different from the 5508. Configure the AP manager interface and have that on the network and see if the AP joins.
Scott Fella
Sent from my iPhone
zheka_pefti Thu, 04/12/2012 - 17:02
Absolutely no luck at all.
Starting the drill again, reset the AP, had it booted and receive the IP address. Now I don't see the previously shown DTLS errors. This is what I see on the AP console this time:
*Mar  1 00:00:08.314: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:00:09.248: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:17.153: %DHCP-6-ADDRESS_ASSIGN: Interface GigabitEthernet0 assigned DHCP address 192.168.1.124, mask 255.255.255.0, hostname AP2
*Mar  1 00:00:27.228: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar  1 00:00:27.340: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:00:30.256: %CDP_PD-2-POWER_LOW: All radios disabled - NEGOTIATED WS-C3560-8PC (0025.8351.9009)
*Mar  1 00:00:38.272: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:00:39.272: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER
*Mar  1 00:01:30.262: %CDP_PD-2-POWER_LOW: All radios disabled - NEGOTIATED WS-C3560-8PC (0025.8351.9009)
On the other hand the controller does report some activity, see below the output of "debug capwap packets/events enable". But this doesn't go anywhere, the LWAPP discovery requests rotate after validating the request from AP (192.168.1.124)
*spamReceiveTask: Apr 12 16:59:16.394: 00:22:bd:18:ed:66 Received LWAPP DISCOVERY REQUEST to ff:ff:ff:ff:ff:ff on port '2'
*spamReceiveTask: Apr 12 16:59:26.394: 00:22:bd:18:ed:66 Received LWAPP DISCOVERY REQUEST to ff:ff:ff:ff:ff:ff on port '2'
*spamReceiveTask: Apr 12 16:59:46.394: 00:22:bd:18:ed:66 CAPWAP Control Msg Received from 192.168.1.124:57046
*spamReceiveTask: Apr 12 16:59:46.394: 00:22:bd:18:ed:66 packet received of length 53 from 192.168.1.124:57046
*spamReceiveTask: Apr 12 16:59:46.394: <<<<  Start of CAPWAP Packet  >>>>
*spamReceiveTask: Apr 12 16:59:46.394: CAPWAP Control mesg Recd from 192.168.1.124, Port 57046
*spamReceiveTask: Apr 12 16:59:46.394:          HLEN 4,   Radio ID 0,    WBID 1
*spamReceiveTask: Apr 12 16:59:46.394:          Msg Type   :   CAPWAP_DISCOVERY_REQUEST
*spamReceiveTask: Apr 12 16:59:46.394:          Msg Length : 29
*spamReceiveTask: Apr 12 16:59:46.394:          Msg SeqNum : 0
*spamReceiveTask: Apr 12 16:59:46.394:   Type : CAPWAP_MSGELE_DISCOVERY_TYPE, Length 1
*spamReceiveTask: Apr 12 16:59:46.394:          Discovery Type : CAPWAP_DISCOVERY_TYPE_UNKNOWN
*spamReceiveTask: Apr 12 16:59:46.394:   Type : CAPWAP_MSGELE_WTP_FRAME_TUNNEL, Length 1
*spamReceiveTask: Apr 12 16:59:46.394:          WTP Frame Tunnel Mode : NATIVE_FRAME_TUNNEL_MODE
*spamReceiveTask: Apr 12 16:59:46.394:   Type : CAPWAP_MSGELE_WTP_MAC_TYPE, Length 1
*spamReceiveTask: Apr 12 16:59:46.394:          WTP Mac Type  : SPLIT_MAC
*spamReceiveTask: Apr 12 16:59:46.394:   Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 10
*spamReceiveTask: Apr 12 16:59:46.394:          Vendor Identifier  : 0x00409600
IE            :   UNKNOWN IE 207
*spamReceiveTask: Apr 12 16:59:46.394:  IE Length     :   4
*spamReceiveTask: Apr 12 16:59:46.394:  Decode routine not available, Printing Hex Dump
*spamReceiveTask: Apr 12 16:59:46.394: 00000000: 01 00 00 01                                       ....
  *spamReceiveTask: Apr 12 16:59:46.394: <<<<  End of CAPWAP Packet  >>>>
*spamReceiveTask: Apr 12 16:59:46.394: 00:22:bd:18:ed:66 Msg Type = 1 Capwap state = 0
*spamReceiveTask: Apr 12 16:59:46.394: 00:22:bd:18:ed:66 Discovery Request from 192.168.1.124:57046
*spamReceiveTask: Apr 12 16:59:46.394: 00:22:bd:18:ed:66 msgEleLength = 1 msgEleType = 20
*spamReceiveTask: Apr 12 16:59:46.394: 00:22:bd:18:ed:66 Total msgEleLen = 24
*spamReceiveTask: Apr 12 16:59:46.394: 00:22:bd:18:ed:66 msgEleLength = 1 msgEleType = 41
*spamReceiveTask: Apr 12 16:59:46.394: 00:22:bd:18:ed:66 Total msgEleLen = 19
*spamReceiveTask: Apr 12 16:59:46.394: 00:22:bd:18:ed:66 msgEleLength = 1 msgEleType = 44
*spamReceiveTask: Apr 12 16:59:46.394: 00:22:bd:18:ed:66 Total msgEleLen = 14
*spamReceiveTask: Apr 12 16:59:46.394: 00:22:bd:18:ed:66 msgEleLength = 10 msgEleType = 37
*spamReceiveTask: Apr 12 16:59:46.394: 00:22:bd:18:ed:66 Vendor specific payload from AP  00:22:BD:18:ED:66 validated
khalidgulzar Tue, 09/08/2015 - 12:41
Hello
I don't know if someone has already found some other way around  or not..  In my case I tried everything  and troubleshooting several hours,  this is what worked for me.  And I did that 4 global site having similar issues and all working now
These AP's cannot be downgraded, and this version would not register to any WLC below ver 8.0,  so I upgraded Wireless Controllers to 8.0.120.0 which is current stable version , Once its done you will see AP's will start registering .  take 20 to 30 minutes.
Leo Laohoo Thu, 04/12/2012 - 17:43
Here's the reason why.
Country code configured for the WLC is "A" while the WAP is configured for an "N" regulatory domain.
This is in the guide but alot of people don't bother reading the guide.
zheka_pefti Thu, 04/12/2012 - 18:27
The irony is that I grabbed these two devices from our regional Cisco office which is Vancouver BC Canada and we are across the street from them. Why would one even pay attention at these details?
Moreover, I studiously read the following troubleshooting guide
http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a00808f8599.shtml#p2
and didn't find any clue that would prompt me to look at the regulatory domains. I didn't see anything on the debugs.
Thanks, anyway. Let's try the right AP. I have AIR-CAP3602E-A-K6 now running AP3G2-RCVK9W8-M image.
We eliminated all regulatory domain problems, correct?
What the heck is going on now ?
flash is writable
FLASH CHIP:  Spansion Mirrorbit (0001)
flashfs[0]: 4 files, 2 directories
flashfs[0]: Total bytes: 31997952
flashfs[0]: Bytes used: 3359232
flashfs[0]: Bytes available: 28638720
flashfs[0]: flashfs fsck took 12 seconds.
Reading cookie from SEEPROM
Base Ethernet MAC address: 44:d3:ca:42:52:12
Ethernet speed is 100 Mb - FULL Duplex
Loading "flash:/ap3g2-rcvk9w8-mx.124-23c.JY/ap3g2-rcvk9w8-mx.124-23c.JY"...###################################################################################################################################################################
File "flash:/ap3g2-rcvk9w8-mx.124-23c.JY/ap3g2-rcvk9w8-mx.124-23c.JY" uncompressed and installed, entry point: 0x2003000
executing...
Cisco IOS Software, C3600 Software (AP3G2-RCVK9W8-M), Version 12.4(23c)JY, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 26-Oct-11 19:21 by prod_rel_team
flashfs[1]: 4 files, 2 directories
flashfs[1]: Total bytes: 31739904
flashfs[1]: Bytes used: 3359232
flashfs[1]: Bytes available: 28380672
flashfs[1]: flashfs fsck took 7 seconds.
flashfs[2]: 0 files, 1 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 11999232
flashfs[2]: Bytes used: 1024
flashfs[2]: Bytes available: 11998208
flashfs[2]: flashfs fsck took 0 seconds.
flashfs[2]: Initialization complete....done Initializing flashfs.
%Error opening flash:/ap3g2-rcvk9w8-mx/info (No such file or directory)cisco AIR-CAP3602E-A-K9    (PowerPC) processor (revision B0) with 167926K/81920K bytes of memory.
Processor board ID FGL1609P02C
PowerPC CPU at 800Mhz, revision number 0x2151
LWAPP image version 7.0.114.214
Base ethernet MAC Address: 44:D3:CA:42:52:12
Part Number                          : 73-14521-01
PCA Assembly Number                  : 800-37501-01
PCB Serial Number                    : FOC15457BDF
Top Assembly Part Number             : 800-35874-02
Top Assembly Serial Number           : FGL1609P02C
Product/Model Number                 : AIR-CAP3602E-A-K9
*Mar  1 00:00:09.323: %LWAPP-3-CLIENTEVENTLOG: Unable to open event log file flash:/event.log
*Mar  1 00:00:09.323: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 0 messages)
*Mar  1 00:00:11.243: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:11.251: %SYS-5-RESTART: System restarted --
*Nov 18 22:44:30.031: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Nov 18 22:44:30.991: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to downDPAA Initialization Complete
*Nov 18 22:44:32.575: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Nov 18 22:44:33.575: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Nov 18 22:44:43.199: %DHCP-6-ADDRESS_ASSIGN: Interface GigabitEthernet0 assigned DHCP address 192.168.1.131, mask 255.255.255.0, hostname AP44d3.ca42.5212
*Nov 18 22:44:51.991: %CDP_PD-2-POWER_LOW: All radios disabled - NEGOTIATED WS-C3560-8PC (0025.8351.9009)
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (192.168.1.40)
*Nov 18 22:45:50.995: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Nov 18 22:45:51.995: %CDP_PD-2-POWER_LOW: All radios disabled - NEGOTIATED WS-C3560-8PC (0025.8351.9009)
Not in Bound state.
*Nov 18 22:46:01.507: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Nov 18 22:46:01.615: %DHCP-6-ADDRESS_ASSIGN: Interface GigabitEthernet0 assigned DHCP address 192.168.1.132, mask 255.255.255.0, hostname AP44d3.ca42.5212
The AP keeps requesting an IP address from the DHCP server and drops it. How many guides and documents one is supposed to read before bothering other people ?
Scott Fella Thu, 04/12/2012 - 18:38
Can you attach your show run-config an also the switchport configuration the WLC and AP is connected to.
Scott Fella
Sent from my iPhone
Leo Laohoo Thu, 04/12/2012 - 18:41
Ok, now you've eliminated the regulatory domain, can I ask if you can set the CORRECT TIME & DATE of the WLC?
Can I also ask if you can use a power injector please?
zheka_pefti Thu, 04/12/2012 - 20:21
Of course I will try to use the power injector and verify the time and date on the controller tomorrow.
A quick question. How is a power injector going to help? I remember we deployed about 20 AP with 5508 controller and we didn't have to jump through many hoops. The AP just smoothly joined the controller and got primed.
Secondly, the wrong time that we see on outputs for AP is absolutely weird and insane. The new AP boots and we see the time as of 1 March and then it is set to Nov 18. The time on the controller was set correctly when I did a basic setup and the previous output above confirm it.
Leo Laohoo Thu, 04/12/2012 - 20:31
Says in the log that the WAP is plugged into a 3560 with 8 PoE ports.  I don't know what's there but maybe the 3560 may have ran out of power.
I understand the 01 March date and this is expected but the fact that it went to 18 November is weird if you are saying your WLC has time and date set correctly.  Can I ask HOW is the time-and-date of the WLC set?
Another thing, console into the WAP, and enter the commands:
clear capwap private
clear capwap controller ip address
Reboot the WAP.
After the reboot, wait until the WAP gets an IP address and try if you can ping the Management IP address of the WLC.  If you can, then enter this command into the WAP "capwap ap controller ip address ".
You borrowed the the 4402 from Cisco?  I wonder how they were able to load the firmware without loading the bootstrap.  I am not sure if this is related but the output below is from my 4402.
Bootloader Version............................... 7.0.230.0
Emergency Image Version.......................... 7.0.230.0
weterry Thu, 04/12/2012 - 22:35
Never in our life time will you get a  AIR-CAP3602E-A-K6 to join the 4402.  It will only join 7.1 and 7.2+ WLC code.
Correct Answer
weterry Thu, 04/12/2012 - 22:45
zheka_pefti Thu, 04/12/2012 - 23:51
this is a real breakthrough
Thanks to you all!
For now, let me get the right AP that will work with 4402 in terms of compatibility and regulatory domain and then I'll try it again.
As for AP-Manager interface everything is the way you mentioned, Wes, except for the same port. This is my first experience with 4400 series and I thought that two different ports should allocated for two different interfaces. Hence, the management interface is on port 0 and AP Manager interface is on port 1. I'll reconfigure them as well once there's a compatible AP.
Good weekend to everyone and thanks again.
Correct Answer
weterry Thu, 04/12/2012 - 23:55
zheka_pefti Mon, 04/23/2012 - 15:36
Ok, I'm back with the new AP - AIR-LAP1231G-A-K9 which is of course of the right regulatory domain.
I will describe my challenges specific to this controller (4402) and how I resolved them. I hope someone will find it helpful.
1. Regulatory domain mismatch. Unfortunately there has been nothing seen on the debugs on the controller to give me a clue that I face the regulatory issues. I expected to find something similar to:
Wed Oct 24 17:13:47 2007: 00:0b:85:91:c3:c0 AP 00:0b:85:91:c3:c0: 80211bg Regulatory
Domain (-N) does not match with country (US )  reg. domain -AB for the slot 1
Wed Oct 24 17:13:47 2007: spamVerifyRegDomain AP RegDomain check for the country US failed
Wed Oct 24 17:13:47 2007: 00:0b:85:91:c3:c0 AP 00:0b:85:91:c3:c0: Regulatory Domain
check Completely FAILED The AP will not be allowed to join
My lame undestanding was that if I change the country on the controller I can change the regulatory domain. No way. The regulatory domain for this controller always stays the same:
802.11a: -A
802.11bg: -A
2. Since 4402 controller has an AP-management port I had to make sure that both management and AP-management interfaces are on the same physical port (1), on the same L2 vlan (untagged in my case) and in the same L3 subnet.
Again, my lame understanding was limited to the fact that AP-management interface should be on the different controller port and I kept moving the only available SFP from one port (1) to the other one (2) without any success.
3. I had to use "Autonomous to lightweight mode upgrade tool" together with the "Wireless LAN LWAPP Upgrade and Recovery Image for 1200 Series Access Points". The procedure went smoothly even though it looked complicated from the description.
4. Once I connected the AP to the same VLAN where AP-Management and Management intertfaces are I got it joined the controller. The following is the snippet from the AP console output (192.168.1.141 is the IP address of the AP-Management interface):
Translating "CISCO-LWAPP-CONTROLLER"...domain server (255.255.255.255)
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
*Mar  1 00:00:05.286: soap_prepare_new_image_crash: mini ios flash:/c1200-rcvk9w8-mx/c1200-rcvk9w8-mx
*Mar  1 00:00:05.764: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:06.973: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:07.046: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 47 messages)
*Mar  1 00:00:07.075:  status of voice_diag_test from WLC is false
*Mar  1 00:00:08.099:  STUB Called : crypto_ssl_init
*Mar  1 00:00:09.234: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:09.282: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1200 Software (C1200-K9W8-M), Version 12.4(23c)JA4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Fri 27-Jan-12 19:24 by prod_rel_team
*Apr 22 14:04:09.139: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Apr 22 14:04:09.159: %DOT11-6-FREQ_SCAN: Interface Dot11Radio0, Scanning frequencies for 8 seconds
*Apr 22 14:04:09.950: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Apr 22 14:04:10.139: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Apr 22 14:04:10.145: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Apr 22 14:04:10.145: bsnInitRcbSlot: slot 1 has NO radio
*Apr 22 14:04:10.368: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Apr 22 14:04:10.368: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Apr 22 14:04:10.619: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Apr 22 14:04:11.392: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Apr 22 14:04:11.442: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
*Apr 22 14:04:11.466: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Apr 22 14:04:11.865: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Apr 22 14:04:12.400: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Apr 22 14:04:27.913: %PARSER-4-BADCFG: Unexpected end of configuration file.
*Apr 22 14:04:27.913:  status of voice_diag_test from WLC is false
*Apr 22 14:04:27.973: Logging LWAPP message to 255.255.255.255.
*Apr 23 22:13:14.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.1.141 peer_port: 5246
*Apr 23 22:13:15.002: %CAPWAP-5-CHANGED: CAPWAP changed state to
wmmAC status is FALSE
*Apr 23 22:13:16.861: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.1.141 peer_port: 5246
*Apr 23 22:13:16.863: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.1.141
*Apr 23 22:13:16.863: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Apr 23 22:13:17.076: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Apr 23 22:13:17.194: %CAPWAP-5-CHANGED: CAPWAP changed state to UP
*Apr 23 22:13:17.263: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller Cisco_8b:83:03
*Apr 23 22:13:17.339: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
*Apr 23 22:13:17.345: %WIDS-5-ENABLED: IDS Signature is loaded and enabled
*Apr 23 22:13:17.349: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Apr 23 22:13:17.353: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiated
Leo Laohoo Mon, 04/23/2012 - 15:54
And your controller is still running 7.0.X firmware?   If no, then can you post the output to the command "sh sysinfo" from the WLC?
The 1230 is supported only up to the 7.0.230.0 and this model is no longer supported with the 7.1.X and 7.2.X firmware.
zheka_pefti Mon, 04/23/2012 - 15:59
OMG!
Why are there so limitations and restrictions ?
Fortunately the controller software is exactly 7.0.230.0 and now I'm scared of running into another compatibility issue. The whole idea about this exercise was to get WLC and ISE work together and run a pilot project for the customer. Tell me I won't face any other compatibility issues
Thanks to you all, guys! Nice support!
Leo Laohoo Mon, 04/23/2012 - 16:07
Ok, that rules out firmware imcompatibility issue.
How did you convert the 1230 to the controller?  The 1230 is a pain-in-the-proverbial-behind to convert because you need the Cisco Conversion Tool PLUS you need the WLC and the WAP to be in the same subnet.
Scott Fella Thu, 04/12/2012 - 17:07
That is all you have from the console?
Scott Fella
Sent from my iPhone
zheka_pefti Thu, 04/12/2012 - 17:14
That's it, Scott.
No more activity on AP console. Just sits idle after the lines I already posted:
AP2>
A quick question, though. Should I have management interface connected at the same time or not? The thing is that I have only one SFP module and I plugged it into the AP Management interface. There's a PC connected to the Service interface and I can SSH into the controller.
zheka_pefti Mon, 04/23/2012 - 16:12
This is how I connected everything. Didn't even know that such an eloquent description is applicable to 1230 AP
I booted the AP to factory default, assinged its BVI an IP from the WLC management subnet, placed it to the same VLAN, connected the laptop with the conversion tool and recovery image and it seemed to do the trick.
Leo Laohoo Mon, 04/23/2012 - 16:24
Can you please console to the WAP and reboot it?  I would like to see the entire bootup and WLC discovery sequence.
zheka_pefti Mon, 04/23/2012 - 16:31
Here it is:
flashfs[0]: 12 files, 2 directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 3451904
flashfs[0]: Bytes available: 4289536
Reading cookie from flash parameter block...done.
Base ethernet MAC Address: 00:23:04:1a:45:bc
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
Loading "flash:/c1200-k9w8-mx.124-23c.JA4/c1200-k9w8-mx.124-23c.JA4"...##################################################################################################################################################################################################################################################################################
File "flash:/c1200-k9w8-mx.124-23c.JA4/c1200-k9w8-mx.124-23c.JA4" uncompressed and installed, entry point: 0x3000
executing...
flashfs[1]: 12 files, 2 directories
flashfs[1]: Total bytes: 7483392
flashfs[1]: Bytes used: 3451904
flashfs[1]: Bytes available: 4031488
flashfs[1]: flashfs fsck took 2 seconds.
Radio0  present A506 5100 E8000000 A0000000 80000000 3
Radio1 not present 0 0 0 0 0 2
%Error opening flash:/c1200-rcvk9w8-mx/info (No such file or directory)cisco AIR-LAP1231G-A-K9     (PowerPC405GP) processor (revision A0) with 15038K/1336K bytes of memory.
Processor board ID FCW1244Y04P
PowerPC405GP CPU at 196Mhz, revision number 0x0145
LWAPP image version 7.0.230.0
1 FastEthernet interface
1 802.11 Radio(s)
Base ethernet MAC Address: 00:23:04:1A:45:BC
Part Number                          : 73-8704-14
PCA Assembly Number                  : 800-23211-14
PCB Serial Number                    : FOC12422PVB
Top Assembly Part Number             : 800-29026-02
Top Assembly Serial Number           : FCW1244Y04P
Product/Model Number                 : AIR-AP1231G-A-K9
no ip http server
*Mar  1 00:00:04.385: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:05.662: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:05.735: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 47 messages)
*Mar  1 00:00:05.765:  status of voice_diag_test from WLC is false
*Mar  1 00:00:06.790:  STUB Called : crypto_ssl_init
*Mar  1 00:00:07.924: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:07.984: %SYS-5-RESTART: System restarted --
*Apr 22 14:04:09.141: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Apr 22 14:04:09.159: %DOT11-6-FREQ_SCAN: Interface Dot11Radio0, Scanning frequencies for 33 seconds
*Apr 22 14:04:09.938: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Apr 22 14:04:10.144: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Apr 22 14:04:10.230: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Apr 22 14:04:10.430: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Apr 22 14:04:10.430: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Apr 22 14:04:10.733: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Apr 22 14:04:11.478: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Apr 22 14:04:12.481: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Apr 22 14:04:27.902: %PARSER-4-BADCFG: Unexpected end of configuration file.
*Apr 22 14:04:27.902:  status of voice_diag_test from WLC is false
*Apr 22 14:04:27.964: Logging LWAPP message to 255.255.255.255.
*Apr 23 23:28:51.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.1.141 peer_port: 5246
*Apr 23 23:28:52.002: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Apr 23 23:28:53.849: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.1.141 peer_port: 5246
*Apr 23 23:28:53.850: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.1.141
*Apr 23 23:28:53.851: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Apr 23 23:28:54.689: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Apr 23 23:28:54.805: %CAPWAP-5-CHANGED: CAPWAP changed state to UP
*Apr 23 23:28:54.876: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller WLC4402
*Apr 23 23:28:54.950: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
*Apr 23 23:28:54.957: %WIDS-5-ENABLED: IDS Signature is loaded and enabled
*Apr 23 23:28:54.962: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Apr 23 23:28:55.031: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiated
*Apr 23 23:28:55.045: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
User Access Verification
Username:
Leo Laohoo Mon, 04/23/2012 - 17:12
The 1230 seems to have joined.
craig.eyre Fri, 05/18/2012 - 10:17
Hey All,
I'm seeing the same type of issue but was wondering if  the  AP3G2-RCVK9W8-M image is a mesh image? I read somewhere that some of the 3602 ap's got shipped with a mesh image on them. I just consoled into one of the ap's and entered the wlc ip address and it worked fine but isn't a viable option moving forward.
Can anyone confirm if this is a mesh image?
Craig
Leo Laohoo Fri, 05/18/2012 - 23:42
Can you kindly post the output to the following commands:
1.  WLC:  sh sysinfo;
2.  WAP:  sh version;
3.  WAP:  sh inventory
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
