Small Business Router for Skype QoS
Answered Question
Apr 12th, 2012
Hello
I heard something about Cisco technologies for Skype traffic recognition long time ago and now I need prioritize Skype traffic in my network.
Will these technologies work for actual version of Skype?
Are there any Small Business Routers suitable for my task?
Correct Answer by rocater about 5 years 1 month ago
Hello Alexandr,
The 800, 1900 and 2900 series routers are marketed toward small to large businesses but are handled by our enterprise team. The small business class devices such as the RV series are very different. Currently at this time the small business devices (such as RV series) do not support dynamic QoS for Skype.
It might be worth while to look into the IOS based routers you mentioned. Find a local partner or if you are a partner check with partner assistance.
Overall Rating: 5 (1 ratings)
rmanthey Fri, 04/13/2012 - 06:46
  • Bronze, 100 points or more
Alexandr,
I am pretty sure Skype uses the SIP protocol for its voice traffic, and yes we can on most of our device provide QoS to that SIP traffic and provide priority to the traffic on your network.
I need to let you know though as soon as the traffic leaves your network and is on the internet cloud, the ISP will usually not prioritize your traffic the same way. You only have control over your equipment for priority.
Cisco Small Business Support Center
Randy Manthey
CCNA, CCNA - Security
panos.asproulis Sat, 04/14/2012 - 00:53
Skype is not using the SIP protocol but a proprietary one.
alexandrfedchenko Sat, 04/14/2012 - 04:21
Yes.
And I need prioritize this proprietary protocol.
panos.asproulis Sun, 04/15/2012 - 12:19
There is no way a SMB router can identify the Skype stream. I know that Cisco IOS routers can do that using NBAR but I am not sure whether they can handle the current Skype protocol. There is a way to specify a custom port for Skype to use and if you do that then you can give a specific priority to that port in the router's QoS settings.
panos.asproulis Mon, 04/16/2012 - 07:21
The point is that non-IOS based routers do not have the facility to identify Skype packets.
alexandrfedchenko Mon, 04/16/2012 - 10:51
800, 1900 and 2900 series routers are IOS based and even have NBAR feature which you refer to.
Correct Answer
rocater Mon, 04/16/2012 - 12:50
Hello Alexandr,
