VRF import-map
Answered Question
Apr 12th, 2012
Hello!
I have configured VRF with the same RD and RT across the few Catalyst6500 and try to use import-map for modifing imported routes (set metric) but it doesn't work.
Config of VRF:
vrf definition VRF
  rd 1:1
  route-target import 1:1
  route-target export 1:1
address-family ipv4
  import map VRF-import
exit-address-family
route-map VRF-import permit 1
  set metric 1000
end
The result: imported route hasn't metric 1000
6500#sh ip bgp vpnv4 vrf VRF
Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 1:1 (default for vrf VRF)
*>iA.B.C.D/24    1.1.1.1 0 100      0 ?
After that I have changed VRF RD on this PE:
vrf definition VRF
  rd 1:2
The result: everything is OK now
Route Distinguisher: 1:2 (default for vrf VRF)
*>iA.B.C.D/24    1.1.1.1 1000 100      0 ?
I assumed there is no any connection between RD and import-map but this result confused me. Is it bug or feature?
RGDS
Correct Answer by Kishore Chennupati about 4 years 10 months ago
Hi Vlad,
AFAIK there isnt a relation between the RD and the metric.Have you tried logging this with TAC? Its probably some sort of a bug. The import statement is a bit finicky thing and not always works the way u intend it to.
Ivan,
Can we request you to please see if this is a bug. I know you helped someone else in the past in regards to a similay import map issue
https://supportforums.cisco.com/thread/2045075
Kishore
Overall Rating: 5 (2 ratings)
Ivan Krimmel Thu, 04/12/2012 - 23:05
Hi Vladimir,
it looks like changing RD has triggered the route to be re-learned. Please try to change metric and re-inject the route.
HTH,
Ivan.
Vladimir Troitskiy Thu, 04/12/2012 - 23:35
Hi Ivan,
Thanks for your answer.
It looks like even 6500 reload hasn't triggered the route to be re-learned and doesn't sovle the problem =)
I've tried to change the RD several times and the result was the same - 1:2 is OK, go back to 1:1 - import-map doesn't work.
Correct Answer
Kishore Chennupati Fri, 04/13/2012 - 18:58
Hi Vlad,
Ivan,
Kishore
Ivan Krimmel Sat, 04/14/2012 - 03:23
Kishore,
I am glad you keep the records :)
Privet Vlad,
can you reproduce this behavior under any arbitrary taken vrf using any RD value? or it fails with one particular vrf/RD?
if it is reproducible I can have look locally, though couldn't find any defects on the fly.
Let me know,
Ivan.
Vladimir Troitskiy Mon, 04/16/2012 - 05:01
Privet Ivan,
yes, I can reproduce this situation with another vrf.
I've done some additional tests:
set metric 1000
1. rd x:x, route-target both x:x - metric 0 for x:x
2. rd x:x, route-target both x:x + route-target import x:y - metric 1000 for x:y and 0 for x:x
3. rd x:z, route-target both x:x - metric 1000 for x:x
Looks like a bug...
