Upgraded Stack, but have small error
Apr 13th, 2012
I've updated a small stack containing 2 x 3750 and it is all working, but during the boot up I get this error:
Loading "flash:c3750-ipbase-mz.122-50.SE5/c3750-ipbase-mz.122-50.SE5.bin"...flash:c3750-ipbase-mz.122-50.SE5/c3750-ipbase-mz.122-50.SE5.bin: no such file or directory
Error loading "flash:c3750-ipbase-mz.122-50.SE5/c3750-ipbase-mz.122-50.SE5.bin"
Then
Loading "flash:/c3750-ipbasek9-mz.122-55.SE5.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@
How can I get it to use the right IOS on both switches on boot up?
Some more info:
sh switch
Switch#  Role   Mac Address     Priority Version  State
1       Member a456.304c.f080     1            0          Ready
*2       Master a456.304c.8e00     15           0          Ready
sh flash1
Directory of flash1:/
    2  -rwx        5357  Apr 13 2012 10:39:15 +01:00  config.text
    3  -rwx        3854  Apr 13 2012 10:39:15 +01:00  private-config.text
    4  -rwx        5357  Apr 13 2012 10:39:15 +01:00  config.text.backup
    5  -rwx    12098310   Mar 1 1993 17:10:32 +00:00  c3750-ipbasek9-mz.122-55.SE5.bin
    7  -rwx        3854  Apr 13 2012 10:39:15 +01:00  private-config.text.backup
    8  -rwx         616   Mar 1 1993 00:02:46 +00:00  vlan.dat
    9  -rwx        3096   Mar 1 1993 00:02:57 +00:00  multiple-fs
sh flash2
Directory of flash:/
    2  -rwx        3854  Apr 13 2012 10:39:15 +01:00  private-config.text
    3  -rwx        5357  Apr 13 2012 10:39:15 +01:00  config.text
    4  -rwx         616   Mar 1 1993 00:17:25 +00:00  vlan.dat
    5  -rwx    12098310   Mar 1 1993 17:04:33 +00:00  c3750-ipbasek9-mz.122-55.SE5.bin
    6  -rwx        3096   Mar 1 1993 00:02:51 +00:00  multiple-fs
thanks
hobbe Fri, 04/13/2012 - 03:16
  • Gold, 750 points or more
The command
boot system switch all flash:/c3750-ipbasek9-mz.122-55.SE5.bin
should do the trick.
but to check boot variable run the command
sh boot
This is an error that states that it can not find the ios file that is specified in the boot variable but since it found another one it booted with that one instead.
so its not a big thing but you realy should change it anyway.
this is so that you can have several ios images in the system and choose wich one you want to boot on.
Good thing to have fx when you upgrade the ios and needs to do a rollback to the old version for some reason.
Good luck
