Warning message
Barcode printers disassociation
Apr 13th, 2012
Having a problem wih intermec PM4i barcode printers with wireless network cards  disassociating from a 5508 controller in a production plant, The printers have ip address that have a static IP address that is from vlan 2 ( wlan that the printers connect to) while the AP that they are connecting to the network is on vlan 201. The printer once connected will stay connected for about 1 hour then lose association, once they are powered cycle they come back up with the proper connections.
Leo Laohoo Fri, 04/13/2012 - 17:31
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Do you have 802.11b low-speed data rates enabled?
Is your printer SSID broadcasting?
Are you using OPEN authentication?
Amjad Abdullah Sat, 04/14/2012 - 00:27
  • Red, 2250 points or more
Stacey:
- Were your printers working fine before? if yes; when the problem exactly started to appear?
- What are the APs model you have?
- Do your intermec devices have latest firmware? if not you can consider upgrading them to the latest.
- Why do your devices disconnect at the first place? is that because the session-timeout that is configured under your SSID? what is the configured session-timeout under your SSID?
- What is the code version you are running?
Amjad
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
