Warning message
Cisco 7942, procurve switch, multiple vlan support
Apr 13th, 2012
Hey folks,
Have a CUCM 7.1.3 deployment (inherited).  A remote site has a procurve switch (2610-48-PWR).  The switch is carved up with ports 1-24 for data, 25-42 for Voice, 43-48 for "other" devices (wireless stuff primarily). 49-52 are tagged within the other three vlans.
Well, I would like to just have 1-48 with two vlans, Voice and Data.  I have played around with this for three days on a test network, and getting no where fast.  I'm posting here first to determine if CUCM sets a phone to decide if it will be supporting two vlans off of the 7942 switch or not.  The procurve switch config snippet looks like this (note, my TEST network here only has a 24 port switch, 2824 model):
ip default-gateway 192.168.7.1
vlan 1
   name "DEFAULT_VLAN"
   untagged 21-24
   no ip address
   no untagged 1-20
   exit
vlan 20
   name "Data"
   ip address 192.168.8.2 255.255.255.0
   qos priority 0
   ip helper-address 10.2.34.10
   tagged 1-20,24
   exit
vlan 22
   name "Voice"
   untagged 1-20
   ip address 192.168.7.2 255.255.255.0
   qos dscp 011000
   tagged 21-24
   voice
   exit
lldp enable-notification 1-20
When plugging in the phone, it will always grab an IP address from which ever vlan is considered "UNTagged".  The laptop hanging off of the phone port will also get an IP address in the same network.
So, my question comes down to this: Is there something in CUCM that is set to not use multiple vlans on a phone?
James
Denis Pointer Fri, 04/13/2012 - 13:24
Hello James,
  I have looked into this once before, and it should be possible with LLDP-MED (with firmware 8.3(3) and later).
The customer I was working on this with ended out changing their minds before we had an opportunity to implement and test (decided to replace the HP switches with Cisco switches), so I don't have a lot of information, but I do still have some of my notes as follows:
Ensure the phone has LLDP-MED enabled.  if the phone is currently registered with CUCM, scroll down on the device settings to the product specific conf section and ensure "Link Layer Discovery Protocol - Media Endpoint Discover (LLDP-MED): Switch Port" is enabled.
As for the Procurve config, I pulled the following information about LLDP-MED config on the procurve switch from a document on HP's site about Interoperability between Cisco Unified IP 7900 Series phones and ProCurve switches
5.2 Configure LLDP-MED on the ProCurve switch
1. Defining a VLAN as voice VLAN enables LLDP-MED:
(conf)# vlan 70 voice
Enables LLDP-MED
2. Then configure LLDP-MED. LLDP-MED must be configured on the switch to support MED TLVs, in particular
network policy and capabilities:
(conf)# lldp run
(conf)# lldp config medTlvEnable network_policy
(conf)# lldp config medTlvEnable capabilities
3. To obtain information about the phone, issue the command:
show lldp info remote X
jmhunter Fri, 04/13/2012 - 13:41
Thanks for the reply d_pointer.
"Ensure LLDP-MED is enabled" - Yes.
"Procurve interoperability doc" - Yea, I've crawled all over that thing for hte past two plus days.  The test switches I have, Procurve 2810 and 2824, do not seem to have the parameter medTlvEnable that you get from issuing lldp config medTlvEnable network_policy (as well as capabilities).
If I remote into either a 5406zl (my core switch) or the switch I am wishing to reconfigure (2610-48-PWR), then those commands are available.  Since both of those switches support POE, maybe I cannot do this without a POE switch to test with.
Oh, and I am using a cisco brick to power up the phone currently.
jmhunter Mon, 04/16/2012 - 13:46
Is it possible that the phone just isn't negotiating or even implementing LLDP-MED?  Looking at the phone, I see the following:
Load file: SCCP42.8-5-2SR1S
Boot Load ID: tnp42.8-3-1-21a.bin
Device Configuration:
   QoS Configuration
      DSCP for call control: CS3
      DSCP for Configuration: CS3
      DSCP for services: Default
   Network Configuration
      CDP: PC Port Enabled
      CDP: SW Port Enabled
      Peer Firmware Sharing: Disabled
      LLDP: PC Port Enabled
      LLDP-MED: SW Port Enabled
      LLDP POwer Priority: Unkown
      LLDP Asset ID:
   Security Configuration
      Voice VLAN Enabled: Yes
Network Configuration:
   Operational VLAN ID:
   Admin Vlan ID:
   PC Port Configuration: Auto Negotiate
I only listed what I thought of as relavant, although there may be more someone wishes to see that what I listed.  If so, just let me know.
James
