Cisco AnyConnect not established connection to ASA 5510: not IPv4!
Apr 13th, 2012
Hi, I have a Cisco ASA 5510 and 2 laptops. With the same VPN user account (locally configured into the ASA)  and AnyConnect install on both laptpos, I get connected with one laptop,  but not with the other one. I am showing the result of "debug webvpn  anyconnect 255" command when the connection fails:
webvpn_login_transcend_cer
t_auth_cookie: tg_cookie = NULL, tg_name = IT_Tercat
webvpn_login_set_auth_group_type: WEBVPN_AUTH_GROUP_TYPE = 4
webvpn_login_transcend_cert_auth_cookie: tg_cookie = NULL, tg_name = IT_Tercat
ATTR_FILTER_ID: Name: AccesoITTERCAT, Id: 21, refcnt: 5
Not calling vpn_remove_uauth: not IPv4!
webvpn_svc_np_tear_down: acl_id: 21
webvpn_svc_np_tear_down: ACL refcnt: 4
webvpn_svc_np_tear_down: no IPv6 ACL
Also the messages that appear on AnyConnect client windows are:
Message 1)      AnyConnect was not able to establish a connection to the specified secure gateway. Please try connecting again
Message 2)      The VPN client is unable to establish a connection
Any idea? Thanks
Agustin J Sanchez Sat, 04/21/2012 - 00:28
I found the problem. Antivirus Kaspersky 6.0 was inspecting HTTPS/SSL traffic, that caused AnyConnect not able to establish a connection. Once I disabled HTTPS inspection from Kaspersky I got connected.
Related Content
