Warning message
Which is best cisco 891 or 892
Answered Question
Apr 14th, 2012
Which router is better 891 or 892, what is the difference between them and which one is cheaper and by how much ?
My requirement is to run about 10-20 computers from each router.
Mero
Correct Answer by Leo Laohoo about 5 years 4 months ago
The difference between the two is the backup services.
892 has ISDN dial backup while the 891 is for V.92.
What to get depends entire upon what you require.
Cisco 890 Series Integrated Services Routers
Overall Rating: 5 (5 ratings)
Correct Answer
Leo Laohoo Sat, 04/14/2012 - 22:36
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Mero Cisco Sat, 04/14/2012 - 22:45
Thanks Leolahoo,
I don't need any of those backup links, I want the cheaper one, what do you suggest ?
Leo Laohoo Sat, 04/14/2012 - 22:55
  • Hall of Fame,
    2017 LAN, Wireless
What are you trying to do?
890 has an 8-port switch so you'll need to buy a Layer-2 switch.
If a router is what you need and you have a tight budget, try Cisco Refurbished.  How many VLANs are you planning to use?
Leo Laohoo Sun, 04/15/2012 - 01:07
  • Hall of Fame,
    2017 LAN, Wireless
3-4 VLANs only?  Try the 860.
anooshoks Sun, 04/15/2012 - 02:52
Good
Leo Laohoo Sun, 04/15/2012 - 04:10
  • Hall of Fame,
    2017 LAN, Wireless
And what is your WAN bandwidth link?
Mero Cisco Sun, 04/15/2012 - 04:15
256 kbps to 1 mbps depends on site.
Actually I am looking for router with 1-2 routing ports and 16-24 managable switching ports in the same box and it must support IPsec, any suggestion
