Confused with the results in my lab . someone please explain.
Apr 14th, 2012
i have a cucm (version 7.1.5) on a MCS server CUCM_PUB (192.168.61.1) connected to switch in vlan 61 . a phone registered with it is phone C (1000)
i have a router H_MGCP connected to switch in vlan 61 . which is  an mgcp router controlled by CUCM_PUB . EIGRP is enabled.
I have a router B_CME connected to switch in vlan 62 .it also has a serial link to H_MGCP.     this router is a CME . a phone registered with it is phone B (4000). EIGRP is enabled.
The switch has inter vlan routing enabled .
2 gateways are registered in CUCM_PUB .
one of them is MGCP gateway H_MGCP.   status (registered)
other one is H323 gateway B_CME .
there is  a dial peer in B_CME:
dial-peer voice 1 voip
destination-pattern 1...                                             (to phone C)
session-target ipv4:192.168.61.1
CUCM_PUB has a route pattern 4XXX pointing to B_CME.                                       (to phone B)
call is going from phone C to phone B . but call is not going from B to C .
all gateways , CUCM , switch ... are able to ping each other .
traceroute from B_CME to CUCM_PUB ....shows result that packet is going via H_MGCP (due to EIGRP's path selection)...although it can directly go via switch also.
traceroute from CUCM_PUB to B_CME ....shows result that packet is going  via H_MGCP (due to default gateway in CUCM_PUB is H_MGCP)...
what i did : created a static route on B_CME .. to reach CUCM_PUB (61.1) ...next hop address ..switche's IP address (for vlan 62) .
result : CALL from C to B as well as from B to C successful .
can someone please explain why call was not going from B to C via H_MGCP ??
according to 'someone' .. in case of call originating on B_CME ...  the CME searches an ethernet path ... whereas the Path to CUCM_PUB learnt by B_CME is through serial port . so call fails.  I am unaware of this , so i got more confused . someone please help .
Sorry for no screenshots ..but i guess i explained the problem .
Related Content
