2 ISP Link query
Apr 15th, 2012
HI
Out current infrastructure is simple
Layer3-switch....................Internet-Reuter..............ISP.modem
we got second ISP link which we terminate on another Router, how to send some trafic on ISP link 1 and some traffic on ISP link 2
Second router also connects to Layer3-switch
On L3 switch I have default route pointing to Router 1 only
thanks
CP
Pawan Sharma Sun, 04/15/2012 - 08:03
There multiple ways to do it but I would recommend to keep it as simple as possible. You have two easy options to achieve this -
1. GLBP (Gateway Load Balancing Protocol - For more info on this Plz visit this link
2. PfR (Performance Routing) - Config of this one is bit tricky but this could be the best option to Load balance traffic on multiple WAN links. You can read more about this here
Please let me know if you need any configuration related assistance.
Pawan S
http://www.ebrahma.com
cisco.plus Sun, 04/15/2012 - 08:54
Hi Pawan
so kind to reply.
we plan to route internet traffic on isp link 1 and data vpn traffic on isp link 2
on link 1 down all traffic goto isp link 2
donno if this doable automatically
