04-16-2012 05:58 AM - edited 03-11-2019 03:54 PM
Whenever I use the following command I get an invalid input error
ciscoasa#conf t
ciscoasa (config) # crypto isakmp enable outside
ciscoasa (config) #object network net-local
ciscoasa (config-network) # subnet 192.168.101.0 255.255.255.0
I have reset the firewall (cisco 5505) to factory default. The marker ^ is under the subnet
Any input from you would be greatly appreciated.
Thank you
04-17-2012 05:16 AM
Hi Jayesh,
What version are you using on the ASA??
Varun
04-17-2012 05:24 AM
Hi ,
have you tried :
network-object 192.168.101.0 255.255.255.0
Dan
04-17-2012 06:03 AM
Hello Jayesh
if you wanted to give subnet option, u need to be in "hostname(config-network-object)" prompt.
from the output you gave , i belive you need to use
'network-object' command instead of subnet since the asa version is different.
hope this helps
Harish.
04-17-2012 06:08 AM
Think your reset might have removed the following command
"boot system flash:
Which means there is no certain software image to boot from after reload.
And this has in turn booted the ASA with older version software on the ASA and not the latest 8.3 or 8.4 software you were running.
Use the command "show version" to check which software it has booted with.
To choose the software you want the ASA to boot with always, use the command
boot system flash:/
For ASDM image use the following
asdm image flash:/
The ASDM command might give you some version warning but ignore it. Its just because your running software might not match the ASDM version.
- Jouni
04-17-2012 06:13 AM
Hi Jouni,
From Cisco ASA 5500 Series Command Reference, 8.4, 8.5, and 8.6 :
hostname(config)# object-group network sjj_eng_ftp_servers
hostname(config-network-object-group)# network-object host sjj.eng.ftp
hostname(config-network-object-group)# network-object host 172.16.56.195
hostname(config-network-object-group)# network-object 192.168.1.0 255.255.255.224
hostname(config-network-object-group)# group-object sjc_eng_ftp_servers
hostname(config-network-object-group)# quit
http://www.cisco.com/en/US/docs/security/asa/asa84/command/reference/no.html#wp1814597
Can you tell us the details regarding the difference cli commands ?
Dan
04-17-2012 06:17 AM
I just imagine that he was using the CLI like normal in 8.3 and 8.4 version and would enter the command
object network
But as the booted software might be 8.2 or below the ASA would understand the above command the same as he was writing
This as there is no other command starting with "object" in 8.2 and pre software versions. So the ASA would presume this was the command intended.
- Jouni
04-17-2012 06:41 AM
Regarding to the network objects I do not see any differences from 7.0 -> 8.0 -> 8.4
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/no.html#wp1749092
http://www.cisco.com/en/US/docs/security/asa/asa70/command/reference/mr.html#wp1584782
Dan
04-17-2012 07:17 AM
Seems we are talking about 2 totally different things
After 8.3 software there has been 2 different type of "object" that contain IP addresses
The one that has excisted always (?) is the "object-group network
The one that was added in 8.3 is "object network
The configuration references you have linked there refer to the objects inside a "object-group network
Example of both objects
object-group network LAN
network-object 10.10.10.0 255.255.255.0
object network LAN
subnet 10.10.10.0 255.255.255.0
And referring to the orignal problem with the poster.
He said he had just returned the ASA to factory default configuration. This would probably mean that any configuration reference to the software image used to boot the ASA was also removed. Now if this is true and he has several old software images on the ASAs flash memory, the ASA might boot with old software.
Now when hes running an ASA that has booted with old 8.2 and pre software, when he issues the command "object network
And this is why his "subnet" parameter isnt accepted on the CLI.
Because hes under the "object-group network" configuration mode and not under the "object network" configuration mode (As it doesnt exist in that software).
- Jouni
04-17-2012 07:30 AM
Yes, you are right. I found in the command reference the "object network" command.
object network object name [rename new_obj_name] {host ip_addr | subnet net_addr net_mask | range ip_addr_1 ip_addr2} description text
Do be sincer, I did not know about this change between the versions.
I do not understand this kind of changes , as I do not understand the reason for changing NAT syntax .
Dan
04-17-2012 07:37 AM
I guess the "object network" is mainly there for the changes in NAT and access-lists.
Though that doesnt stop you from using either "object network" or "object-group network" in your NAT and ACL configurations.
Certain NAT configurations naturally require the use of "object network" instead of "object-group network"
- Jouni
