Warning message
LMS 4.0.1, all devices are unknown after device update.
Answered Question
Hello.
After successfully install a device update for Common Services, all devices are reported as unknown.
Number of Packages Selected for Install : 2
For Product(s) : Common Services
Install Invoked by user : ameconi
The Package(s) Selected for Install :
Mdf_NonCisco, Mdf
Successfully installed packages (2):
Mdf(1.64) ,Mdf_NonCisco(1.2)
Installation Completed for : Common Services
Any ideas?
When I try to install other updates these fail because MDF is version 1.59.
Thanks.
Andrea
Correct Answer by Michel Hegeraat about 5 years 4 months ago
Possible, I also received some reports from customer that device package updates are hanging or failing.
Thanks for letting us know.
Cheers,
Michel
Overall Rating: 5 (1 ratings)
Michel Hegeraat Mon, 04/16/2012 - 10:30
  • Gold, 750 points or more
Did you by mistake uninstall some packages? Or something went wrong installing Mdf(1.64).
Due to the inter-package dependecy misery in previous LMS versions I now always install the lot, each available package.
In a number of cases I found when things no longer work in the GUI they still work on cli.
So try to download and install all cmf rme cvw cm and dfm packages using psucli in CSCOpx\bin
psucli /? tells you all you need to know.
Cheers,
Michel
Michel Hegeraat Tue, 04/17/2012 - 13:09
So you install Mdf(1.64) and the error you get when trying to install something else is that the Mdf(1.64) dependency is not met because it still sees 1.59 as installed.
I guess you then should try to uninstall Mdf(1.64) or install it again as it is clearly not completely installed
If you are able to uninstall it try to add all other packages so it can't catch you in some any dependency scenario
Cheers,
Michel
Correct Answer
Michel Hegeraat Wed, 04/18/2012 - 04:49
Cheers,
Michel
savic.marija Fri, 04/20/2012 - 14:48
Hello, I have the same problem but with LMS 4.1 ( but in my case it says i have mdf  version 1.53). Device updates are hanging or failing.
Did you happen to know what is exactly wrong and how to fix it?
Thanks!
Michel Hegeraat Sat, 04/21/2012 - 01:37
As Andrea said, there is an issue on cco, cisco.com where lms tries to download the packages.
I'll post a message where I'm told it is fixed.
Cheers,
Michel
savic.marija Thu, 04/26/2012 - 02:36
Thanks for letting us know!
So now it should be working without need to uninstall MDF?
Regards,Marija
eng.malak Thu, 06/28/2012 - 04:58
Hello Andrea
could you please provide the pacckage
Karim.elwardany Thu, 06/28/2012 - 10:05
Hello Andrea,
i am also facing the same issue and would be pleased if you provide me the file.
