Warning message
problem in cisco boot
Apr 17th, 2012
I faced with a general problem ,
I have loaded an IOS in as5350 and boot the system with it , but as my device does not support it ,
my gateway is restarted continually and I couldnt access it even I couid not use reset factory .
what should I do is it correct with power off/on ?
medhat elsaeed Tue, 04/17/2012 - 13:58
Hi all,
reload the device, if the boot doesn't work again
then reload it and push it the ROMMON, then fix the boot image.
let me know if that solved your problem.
