Warning message
ASA 55x0 error connecting to AAA (ACS 5.2)
Apr 17th, 2012
Hi, we encountered a problem between
     CISCO ASA 5510
     CISCO ACS 5.2
If I have a downloadable ACL more long/deep of 68 lines for the user defined inside Identity Manager, it
keep in error.
ASA live log say that is unable to contact AAA
If I delete a line keeping downloadable ACL inside 68 lines, all go fine.
The service used is SSL VPN with Anyconnect 3
is it a referenced bug or is it a limit?
Harish Balakrishnan Tue, 04/17/2012 - 06:16
  • Silver, 250 points or more
Hello Alberto
I think there is a limit of  16 KB for the size of the downloadable acl. In your case , when you add more than 68 lines, it could be crossing the limit. What you can do here, instead of using seperate lines, go ahead and create object-group and use that in your downloadable acl config. something like follows
Harish.
