Can't transfer call using CUBE
Answered Question
Apr 17th, 2012
I hope someone can help me, this is the problem. I have a CUCM 8.5 whit a CUBE as h323 gateway. CUBE uses SIP to connect to an asterisk system, like this:
CUCM ---h323--- CUBE ---SIP--- Asterisk
Calls work fine, but when i try to transfer a call in CUCM side, it dont work. I was trying modified mtp requiered, but using mtp, i press transfer and nothing happen, if I not use mtp, i press transfer and call get down.
CUBE config is attached, I would really appreciate any help.
Carlos
Correct Answer by Carlo Poggiarelli about 5 years 1 month ago
Hi Carlos.
So i suppose asterisk users are using g729 codec or cube definition has been forced to use this codec.
Configure IOS mtp service on cube to use g729 and assign it to a new media resource group on cucm. assign mrgl to h323 gateway.
Hope this helps.
Carlo
Overall Rating: 5 (1 ratings)
Carlo Poggiarelli Tue, 04/17/2012 - 08:06
  • Green, 3000 points or more
Hi Carlos.
Please post the output of a show sccp connections while in call with an asterisk extension.
Can you also post the asterisk sip.conf portion regarding the connection to the cube?
Leave chcked the "Mtp required" option on the CUCM
Carlo
Carlos Olortiga Tue, 04/17/2012 - 08:49
Hi Carlo, thanks for your answer, this is waht i get
CUBE_CAM#sh sccp connections
sess_id    conn_id      stype mode     codec   sport rport ripaddr
5          6            xcode sendrecv g711u   18956 2000  172.29.129.1
5          5            xcode sendrecv g729    16602 2000  172.29.129.1
Total number of active session(s) 1, and connection(s) 2
MTP requiered is checked.
Asterisk is manage by other people, I ask for the sip.conf, and I will post it as soon I have it.
Carlo Poggiarelli Tue, 04/17/2012 - 08:57
Hi Carlos.
Try to apply g711ulaw codec to all CUBE dialpeers a check if something changes.
Carlo
Carlos Olortiga Tue, 04/17/2012 - 09:08
I apply g711ulaw for all dialpeers, but now, call rings and fall down when other side answer.
Carlos
Correct Answer
Carlo Poggiarelli Tue, 04/17/2012 - 12:06
Hi Carlos.
Hope this helps.
Carlo
Carlos Olortiga Tue, 04/17/2012 - 16:34
Hi Carlo,
Actually CUBE use g711ulaw with Asterisk and g729 with CUCM.
CUCM ---h323(g729)--- CUBE ---SIP(g711u)--- Asterisk
I am using an transcoder configured in CUBE as MTP resource in CUCM, and is aplied in an MRGL which is assign to the h323 gateway (CUBE).
Is there any debug can I make which show me what is happening while I press transfer button?
Carlos
Sivakumar Shanmugam Wed, 04/18/2012 - 02:02
  • Cisco Employee,
Collect CUCM sdi/sdl traces and filter based on transfer number.You can get to know the reason why the transfer fails.
Siva
pls rate if helps you.
Carlos Olortiga Tue, 05/08/2012 - 15:39
Hi Everyone,
Finally I can solve this problem, As Carlo said I just configure an ios MTP g729 on CUBE, and then registered it on CUCM to use in MRGL assigned to h323 gateway. When I try it first time I use an ios transcoder as MTP, but it must to be an ios MTP.
Thanks a lot
