Warning message
BRI interface not showing in show voice port summary
Answered Question
I have a 2901 with a VIC3-2FXS/DID and a VIC2-2FXO cards.
These two cards work ok.
I bougth a WIC-1B-S/T-V3  to replace the FXO.
There are no voice ports showing for the BRI card after i installed it.
What am i doing wrong or what do i need to enable the voice ports for BRI?
Thank you,
laszlo
Correct Answer by acampbell about 5 years 4 months ago
Your WIC-1B-S/T-V3 card is a DATA WAN element it does NOT support voice.
You will need to consider a VIC2-2BRI-NT/TE
For voice working
Alex
Overall Rating: 5 (1 ratings)
Correct Answer
acampbell Tue, 04/17/2012 - 08:16
  • Green, 3000 points or more
For voice working
Alex
