Warning message
Audit all configuration changes
Answered Question
Apr 17th, 2012
Greetings,
we are using radius and active directory to authenticate to the switches. All syslog messages are sent to a LMS 3.2 server.
How can i configure auditing so that command on the running config from every user is reported via syslog?
Thank you.
C.
Correct Answer by Vasileios Boulo... about 5 years 4 months ago
Hi Christian,
This feature could be configured under the archive configuration mode with the log config command and notify syslog to enable
the sending of notifications of configuration changes to your remote syslog.
The configuration could be the next
archive
log config
  logging enable 50
  notify syslog
  hidekeys
If you need to log all the commands and not only the config commands then the following configuration should be
executed on the router.
event manager applet CLIaccounting
event cli pattern ".*" sync no skip no
action 1.0 syslog priority informational msg "$_cli_msg"
set 2.0 _exit_status
Read the next link for more details
http://blog.ioshints.info/2006/11/cli-command-logging-without-tacacs.html
Hope that helps!
Vasilis
Overall Rating: 5 (1 ratings)
Correct Answer
Vasileios Boulo... Tue, 04/17/2012 - 15:01
  • Silver, 250 points or more
Hi Christian,
archive
log config
  logging enable 50
  notify syslog
  hidekeys
Hope that helps!
Vasilis
