Warning message
Standard Access List
Answered Question
Apr 18th, 2012
Guys,
Can you please confirm the commands in order to add any access list in the existing existing standard access list. For an example, there are two actions happening (10, 20) in the standard access list and I need to add a new (permit/deny) action (15) in between then what command will be used.
Thanks.
Correct Answer by Dan-Ciprian Cicioiu about 5 years 4 months ago
Hi Ray:
conf t
ip access-l stan name
15 permit host x.x.x.x
Dan
Overall Rating: 5 (1 ratings)
Correct Answer
Dan-Ciprian Cicioiu Wed, 04/18/2012 - 00:18
  • Gold, 750 points or more
Hi Ray:
conf t
Dan
ray_stone Wed, 04/18/2012 - 00:22
Thanks DAN... I appreciate of your prompt response.
tariqali1 Wed, 04/18/2012 - 03:12
This will create a little problem by introducing an access list in between two access list, Used name ACL.
glen.grant Wed, 04/18/2012 - 04:54
  • Purple, 4500 points or more
  Thats what Dan did , he is correct ...   Just because he used a number does not mean it's not a modifiable acl .  You just put a numbered ACL into acl config mode like Dan did . If you want to modify a numbered ACL you just do it like a named acl,
ip access-list stand 1
15 permit 192.168.2.X
