uccx scipt question
Answered Question
Apr 18th, 2012
I want  to write a script ,
For instance    if   contact info starts with  '053'     I want to redirect a   specified  group of agent ,
if starts with  '021'    redirect another group of agent .
I could get contact info but I couldn't   get contact info if starts a specified number .
Thanks in advance
Correct Answer by Gergely Szabo about 5 years 4 months ago
create a String type variable, named ani for instance, then use the Get Call Contact Info step, where you map the "Calling Number" attribute to the ani variable.
Then just use an If node like if ani.startsWith("022") etc
G.
Overall Rating: 5 (1 ratings)
Tanner Ezell Wed, 04/18/2012 - 05:47
  • Silver, 250 points or more
You'll need premium licensing but you can do:
Switch CallerANI.subString(0,2)
Case "052": Set CSQ == "someCSQ1"
Case "053": Set CSQ == "someCSQ2"
Select Resource (CSQ)
Tanner Ezell
My new book is now available! Get it here: http://amzn.to/GH4NdI
Anthony Holloway Wed, 04/18/2012 - 12:39
  • Purple, 4500 points or more
FEI (for everyone's information) - You don't need Premium licensing to use Java methods.  enhanced and premium will both work fine.
Correct Answer
Gergely Szabo Wed, 04/18/2012 - 07:01
  • Green, 3000 points or more
  • Community Spotlight Award,
    Member's Choice, December 2015
G.
