Warning message
Event Manager time-range applet
Apr 18th, 2012
How to configure event manager so when interface Tunnel goes down the router will reload only on specific time, when the router clock is between 12 A.M and 16 A.M ?
If interface Tunnel is down and router clock is not between 12 and 16 A.M, it should not reload.
track 1 interface Tunnel0 line-protocol
delay down 180 up 30
event manager applet tunnel-down
event track 1 state down
action 1.0 cli command "enable"
action 2.0 reload"
thanks
Overall Rating: 5 (3 ratings)
Dan-Ciprian Cicioiu Wed, 04/18/2012 - 01:39
  • Gold, 750 points or more
Hi Eugen,
I think that you could specify the exact time of the reload : reload at 04:01.
And you can do another applet if the interface goes UP => reload cancel.
Dan
Eugen Bitca Wed, 04/18/2012 - 02:36
Tha applet should run only when the router time is between 12 and 16 AM.
If Tunnel is down and it is 17 AM the applet should not run.
Dan-Ciprian Cicioiu Wed, 04/18/2012 - 03:36
Hi Eugen ,
I think that event timer together with cron entry is the solution for you.
Dan
Joe Clarke Wed, 04/18/2012 - 06:55
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I think you want to use multiple events here:
event tag track track 1 state down
event tag timer timer cron cron-entry "* 12-16 * * *"
trigger
  correlate event track and event timer
action 2.0 "reload"
Eugen Bitca Wed, 04/18/2012 - 07:08
in this case the applet will run every minute from 12 to 16 h.
If the action 2.0 is not the command reload, but some show commands, than every minute of the specific time range the applet will run.
The apllet should run only once, if for example, the time is 13 o'clock and Tunnel is down, than do some actions.
Joe Clarke Wed, 04/18/2012 - 07:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The applet will only run if both the tunnel is down and the time is between 12 and 16.  That's what the correlate does.  Yes, if the tunnel is still down when the route reloads, it will reload again while the time window is still between 12 and 16.  It will not necessarily run every minute, though.
Eugen Bitca Wed, 04/18/2012 - 07:32
what if I do not use reload but some show command, than every minute the show command will run.
Dan-Ciprian Cicioiu Wed, 04/18/2012 - 07:36
The same is with "reload", after reload if the interface will be down and also the time range will be 12-16 , it will reload again.
Dan
Joe Clarke Wed, 04/18/2012 - 07:39
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No, it will not run every minute.  The track down event is an edge-trigger event.  It will only happen once when the tunnel goes down.  The tunnel would need to come back up and go down again within the 12-16 window for the policy to run again.
Dan-Ciprian Cicioiu Wed, 04/18/2012 - 07:17
Eugen ,
EEM action is triggered by 2 events in this case :
          - time interval - because you want to take actions only between 12 and 16
          - tunnel interface down.
After the applet is applying the actions it will stop, it will not run just once like a daemon, it is more like a script.
So there is the need to run every minute and check if the tunnel is down.
Please correct me if i'm wrong Joseph
Dan
Joe Clarke Wed, 04/18/2012 - 07:20
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Correct.  These are edge-triggered events.  Of course, as I said, if when the router reloads the tunnel is still down, the router will reload again (because the tunnel down event will still occur).
