Warning message
How to know if a PSTN transferred call has been answered?
Apr 18th, 2012
When no agents are logged on contactac certer, script trasfer calls to an external phone (PSTN) Are there any possibility to know if transferred call has been answared?
The platform are composed for ICM 7.5 and IP IVR 7.0.
Thank you in advance
Chris Deren Wed, 04/18/2012 - 09:58
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
How are you transferring the call? In the ICM script via Label or in IVR script?
Chris
Emilio Manzaneque Wed, 04/18/2012 - 10:10
Hi Chris,
I could do it in either, via script or via label, but in both ways, I do not know how know the result of the transfer.
What do you recommend me?
Abhiram Kramadhati Wed, 04/18/2012 - 17:09
  • Cisco Employee,
Hi Emilio,
You can use the "Call Consult Transfer" step for this purpose. This step also provides you the ability to pass DTMF once the call has been answered:
From the scripting guide:
"Use the Call Consult Transfer step to perform a supervised transfer. The step can be used to outpulse DTMF digits once the destination answers. The transfer will be completed on the destination answering the call and DTMF outpulsing complete (if DTMF digits are specified)."
I have attached a very basic script with this stes used in it (no variables have been populated).
Abhiram Kramadhati
Abhiram Kramadhati Wed, 04/18/2012 - 17:12
  • Cisco Employee,
Please note that the above mentioned procedure is for transferring using an IVR script.
Abhiram Kramadhati
Emilio Manzaneque Thu, 04/19/2012 - 06:36
Hi Abhiram,
Thank you for your answer...
I tried to transfer calls with consult call transfer node, but I have two problems:
First, called person seeing the number of the CTI port as calling number, instead of original calling party number, and second, in WebView reports, transferred calls appears as abandoned calls.
How I can avoid these disadvantages?
Thank you
Abhiram Kramadhati Thu, 04/19/2012 - 06:48
  • Cisco Employee,
Hi Emilio,
You might find this post useful: https://supportforums.cisco.com/thread/2058072
Please note that currently UCCX behaves in the following way for a consult transfer:
  • During the transfer, it displays the transfer number (CTI port)
  • After the transfer is completed successfully, the original calling number is displayed.
Currenlty, there is no option to display the original calling number during the transfer from UCCX.
Abhiram Kramadhati
Emilio Manzaneque Thu, 04/19/2012 - 07:05
Hi Abhiram,
Chris has mentioned something about do transfer with sending a label, but in this case, I do not know how to know if transferred call has been answered or not.
Do you know how a could get this information?
Thank you
Abhiram Kramadhati Thu, 04/19/2012 - 07:16
  • Cisco Employee,
Hi Emilio,
Like i mentioned, the Consult Call transfer lets you have the functionality that you require. If the call is answered, the contrl will go to the "Successful" branch of the step.
Abhiram Kramadhati
Emilio Manzaneque Sat, 04/21/2012 - 13:14
Yes, but in spite of I mark call as "handled" For ICM is abandoned like I can see in webWiew reports.
And is not possible show original calling numbers in alerting state.. Therefore I should consider other option.
Sen a label at CUCM could be interesting but only if I can check out if call has been answered..
Related Content
