Conference Station on UC320W-FXO-K9
Answered Question
Apr 18th, 2012
I'm looking to deploy the UC320W at a client's who has also requested for a conference station, like the Polycom IP 6000 Conference IP Phone. Will the conference station work with the UC320W? Are there any other options I can explore?
Femi
Correct Answer by Naum Vitanovski about 4 years 10 months ago
Hi Femi,
I have installed Polycom SoundStation 2 with a UC320W. Because the SoundStation2 is analog, I just plugged it in an fxs port and assigned it an extension. It worked fine.
Naum
Overall Rating: 5 (1 ratings)
Correct Answer
Naum Vitanovski Wed, 04/18/2012 - 16:15
Hi Femi,
Naum
femi.agboade Wed, 04/18/2012 - 22:34
Hello Naum,
Thanks indeed for your comment. I guess this might just be a way out instead of the IP 6000. I had thought that since the IP 6000 was a SIP phone, that the UC320W would be able to work with it and any other Cisco supported SIP phones? Is this the case or not?
Femi
Naum Vitanovski Wed, 04/18/2012 - 22:40
Hi Femi,
I am not sure if the UC320W can communicate with the IP 6000. I have not had any previous experience with this device. Best will be to ask polycom directly.
Cheers,
Naum
rbordner Thu, 04/19/2012 - 10:11
Femi,
The UC320W does not support the IP 6000. The UC320W only supports Cisco Small Buisness IP Phones.
Randy
