rbordner Thu, 04/19/2012 - 10:15
  • Cisco Employee,
Femi,
Would the SPA525G2 be in a wired or wireless configuration? The UC320W supports 24 devices.
Randy
The maximum I would consider would be (5) SPA525G2 phones and all could not be in use at the same time.  I think you could probably use (4) simultaneously without issue.  The constraining factor is that you are using 802.11g on the phone to connect to the voice VLAN.  This limits you to only a 54mbps data rate from the phone to the accesspoint in a best case scenario.
