Warning message
PPPoE Termination on Cisco 1921
I have cisco router model 1921 , how can i terminate my existing pppoe connection to 1921, so that my other LAN users can use internet.
What i have already done ,
1- One cable (RJ45) which is comming from ONT has connected with Integrated WAN Port on router.
2- One cable (RJ45) which going to my LAN switch has connected with Integrated LAN Port on router.
Now i need to configure my router, so that i can give internet access to my LAN users. I red cisco's guides but not clear regarding configurations, because in guides they use modules to configure pppoe. But i am not using any module, i am simply connecting one cable for WAN and one for LAN.
Please if anyone can help me on this....Thanks.
paolo bevilacqua Thu, 04/19/2012 - 09:11
  • Hall of Fame,
    Founding Member
It woul be better if you have a reputable consultant, or certified Cisco partner, do the configurations for you.
Otherwise you can search for examples and documenation using the search box on cisco.com
