Radios on 1242AG stay down with Injector and Cat6509
Apr 19th, 2012
Dear all,
i noticed that the 1242AG does not bring up the Radios, when there is a Power Injector connected.
I see in the Logs of the AP:
%CDP_PD-2-POWER_LOW: All radios disabled - NEGOTIATED WS-C6509 <Switchport MAC Add>
The Module in the 6500 is a   WS-X6348-RJ-45
The Option "Power Injector installed" on the WLC is also enabled, with the MAC Address from the Switchport, but no change.
When i disable CDP on the mentioned Switch Port and reload the AP, it comes up and runs fine.
Any ideas, what is causing this problem?
BR.
stefan
Scott Fella Thu, 04/19/2012 - 04:40
Isn't there another option on the wlc in regards to the power. IIRC, there are two options, try checking the other option.
sbreuercc Thu, 04/19/2012 - 07:55
the other option is "override" in the field "Power Injector State".
but this didn't change the problem.
sbreuercc Thu, 04/19/2012 - 23:32
WLC Soft is  7.0.116.0
AP Soft is  12.4(23c)JA2    / Boot Version 12.3.7.1
Leo Laohoo Thu, 04/19/2012 - 23:37
Is this the only WAP that's having a problem or are there more.
If this is the only WAP then check your cables.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
