Subnetting ip range question
Answered Question
Apr 19th, 2012
I'm from belgium, starting to get my way around Cisco and IT networking.
For the moment i'm at chapter 6 discussing subnets.
You got the network part of the bits and the host part.
If you want to create 4 subnets you take the fist 2 bits of the host part.
Than you have 62 addresses free for hosts and 4 subnets.
My question is here: what if for example, your HQ has 80 hosts that need an address.
You have the 62 addresses for one sunet, do you need to use the 2 subnets or can you combine one subnet?
Correct Answer by Richard Burts about 4 years 11 months ago
Tom
I am glad that my answer was helpful. Subnetting is a topic with lots of aspects and can be confusing, especially in the beginning. As you get more experience and a better understanding it does get easier.
Your understanding is correct in terms of traditional subnetting. As subnetting was developed one of the principles was that within a particular network all subnets would be the same size, and as you state the size is driven by the requirements of the largest subnet. This did lead to some inefficiencies, as you note.
To address these inefficiencies a new approach to subnetting was developed. This is frequently referred to as VLSM, which is Variable Length Subnet Masking. Traditional subnetting with all subnets the same size was simple but not so efficient. VLSM changed the basic principle that all subnets need to be the same size and gave us flexibility and increased efficiency in subnetting by allowing subnets within a network to be different sizes. So in your case we can say that one site with 80 requires a /25 subnet (255.255.255.128) but the site which requires only 15 could then have a subnet of /27 (255.255.255.224) and that the remaining address space could then be used somewhere else.
You still can not say the subnet is from 1 to 100 and reserve 101 through 127. If the mask is /25 then all 127 addresses are in the same subnet. But now you can say that the smaller site can use a mask that more closely reflects its needs.  Earlier routing protocols enforced the requirements of Fixed Length Subnet Masking while more recent routing protocols like OSPF and EIGRP support VLSM.
Good luck in learning more about subnetting.
Rick
Tom
While it would seem logical to say that the subnet was 192.168.0.1 to 192.168.0.100 and the remaining addresses in reserve, that is not how IP subnetting works. IP subnetting works on bit boundaries. If you need at least 80 hosts then you would use the first bit of the fourth octet as the subnet bit and then the seven remaining bits are all host bits within that subnet. It does not work to try to use some of those host bits in a subnet somewhere else.
Rick
Overall Rating: 5 (2 ratings)
susdas Thu, 04/19/2012 - 21:14
In order to have 80 hosts, you need to have 7 bits in the host part of the IP address(64<80<128). Hence, if its a class C address, only 1 subnet bit would exist in addition to the 24 network bits.
You can refer to the following document to understand subnetting better:
   https://learningnetwork.cisco.com/servlet/JiveServlet/previewBody/6014-102-1-19236/Subnetting%20Examples.pdf
Sush
yonimeeus Mon, 04/23/2012 - 01:35
Thank for the responce, the part of the bits that jou need for the host part i get.
What i am refferring to is actually this: Site A has 80 hosts and site B with 15 hosts.
If you want them to be on the same subnet (ex:192.168.1.0) does every site have to have 80 host addresses because site A has 80 hosts?
Why the question, in the course cisco says if you take 1 bit of the host part you get 2 subnets
subnet 1 is 0 to 127
subnet 2 is 128 to 255
But if you only need 80 addresses for site A you don't need the full 127 availeble addresses, let alone yet another 127 availeble addresses for a site that has only 15 hosts...?
Can't you actually say site a is from 192.168.0.1 to 192.168.0.100 and the remaining addresses in reserve and site B is 192.168.1.101 to 192.168.1.120 and the rest as reserve?
The course on that item is not realistic explained.
Tom
Correct Answer
Richard Burts Mon, 04/23/2012 - 04:54
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Tom
Rick
yonimeeus Mon, 04/23/2012 - 05:05
Hi Rick,
Thanks for the quick reply.
So subnetting is, as i may assume, that the site with the most hosts determine the range of the subnets for all other sites disregarding their number of hosts. Site A has 80 hosts so  the other sites, disregarding their number of hosts, have X amount of ip addresses unused because site A need 80 addresses.
Like oldschool computers with ATA cdroms en harddrives on the same cable, the slowest device sets the speed for all others attached to the same cable.
Correct me if i'm wrong, if not thanks for clearing that up for me, it was kind of confusing.
Thanks in advance,
Tom
Correct Answer
Richard Burts Mon, 04/23/2012 - 05:41
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Tom
Rick
